P1259 VTEC System Malfunction (Oil Pressure Switch) - Club RSX Message Board
Old 07-05-2008, 02:48 PM   #1
Islanti
asdf
Islanti's Avatar
Islanti is an unknown quantity on c-rsx
First time starting up the car today since April 23rd and this came up, car is in limp mode too and won't go over 4k RPM. Oil level is good too, what/why did this just come up out of no where? I removed my oil pressure guage thinking it had something to do with it and still no good.
Supercharged Crew Member #12
2002 Acura RSX Type-S
307 horsepower / 231 torque (DynoJet) @ 7psi
Islanti is offline   Reply With Quote
Old 07-05-2008, 04:24 PM   #2
MrHobbers
MrHobbers's Avatar
MrHobbers is an unknown quantity on c-rsx
after googling your odb2 code, because without any info i couldnt even tell you where you look. it looks like
"When diagnosing a trouble code P1259, always look at freeze-frame data. This data will tell you if the code is set at high or low engine rpm. If the code is set below 4,000 to 6,000 rpm (depending on the engine), check the oil pressure switch circuit for a faulty switch/connection or poor ground. When the code sets during VTEC operation, check for an oil pressure or mechanical problem with the VTEC system."
i would check where you hooked up your Oil Pressure Gauge. make sure everythings connected and clean.
MrHobbers is offline   Reply With Quote
Old 07-06-2008, 10:42 AM   #3
Islanti
asdf
Islanti's Avatar
well it sets almost immeditately after starting the car...so it sounds like bad wire/ground. thanks. i'm still curious why this came up outta no where tho!
Old 07-06-2008, 11:55 AM   #4
CBRDC5
Hi there
CBRDC5 is an unknown quantity on c-rsx
Replace the oil pressure switch, the thing should only be 10$. its a good place to start
'02 DSM RSX-S
If i helped then +rep. If i didnt then -rep the person above me
CBRDC5 is offline   Reply With Quote
Old 07-19-2008, 07:46 PM   #5
BlueSleepeR_33
BlueSleepeR_33's Avatar
BlueSleepeR_33 is an unknown quantity on c-rsx
i got this too, but that code was telling me its the air/fuel control...so if any one fix this problem would it be the oil pressure cuz this limp mode goes if im in vtec to long in 5th gear
BlueSleepeR_33 is offline   Reply With Quote
Old 07-21-2008, 11:18 AM   #6
ti86la
ti86la is an unknown quantity on c-rsx
dude...change ur oil to 5w 20 for auto....5w 30 for types ...vtec doesn't work because the oil is too thick...my dad change 10w 30 in my car,,,as a result...two week later ...vtec goes bye bye...the shop want 500 $...I replace my oil with 5w 20...then reset the battery....now everything is good...hope it help u...
ti86la is offline   Reply With Quote
Old 07-21-2008, 11:34 AM   #7
2010 admin
Guest
Posts: n/a
LOL....
Old 07-21-2008, 11:37 AM   #8
juicyjoint316
Boots to Asses
juicyjoint316's Avatar
juicyjoint316 is an unknown quantity on c-rsx
juicyjoint316 is offline   Reply With Quote
Old 07-21-2008, 11:58 AM   #9
02Blktypes
Broke...
02Blktypes is an unknown quantity on c-rsx
considering the put 5w30 even in bases now because the 5w20 was causing cam pitting.. good try tho
02Blktypes is offline   Reply With Quote
Old 07-24-2008, 03:16 PM   #10
BlueSleepeR_33
yea but 5w30 burns like theres no tomorrow, trust me i have a heavy foot...even when i had the 5w30 it would still go into limp mode when im vtec to long
Old 07-24-2008, 03:18 PM   #11
2010 admin
Guest
Posts: n/a
LOL, for the second time in this thread.
Old 07-24-2008, 03:20 PM   #12
DomSim
no longer blown ;(
DomSim's Avatar
DomSim is on a distinguished road DomSim is on a distinguished road
a+ thread, would read again
OHIO CREW
[sigpic][/sigpic]
http://www.cardomain.com/ride/2255290
DomSim is offline   Reply With Quote
Old 07-24-2008, 03:30 PM   #13
mxlu
HONDA PACT
mxlu's Avatar
mxlu is an unknown quantity on c-rsx
this is awesome.
mxlu is offline   Reply With Quote
Old 07-24-2008, 10:32 PM   #14
strikeback03
strikeback03 is an unknown quantity on c-rsx
I was getting the same code when I bought my car - some idiot had gunked RTV into the solenoid, preventing it from moving properly, causing cold start issues. Anyway, the Helms manual has a couple pages of troubleshooting (11-131 to 11-134)
strikeback03 is offline   Reply With Quote
Old 07-25-2008, 09:19 PM   #15
BlueSleepeR_33
yea ima nooob to rsx i had a prelude love that car to death......where can i get that helms manual
Old 07-25-2008, 09:24 PM   #16
BlueSleepeR_33
never mind thanx found site
Old 08-25-2008, 02:48 PM   #17
hose4dub
hose4dub's Avatar
hose4dub has been a little shit in the past
my car is throwing this code up too
hose4dub is offline   Reply With Quote
Old 08-25-2008, 03:37 PM   #18
TypeOne
K-Series Guru
TypeOne's Avatar
TypeOne is an unknown quantity on c-rsx
http://pdftown.com/Acura-RSX-2002-20...ce-Manual.html
Download the service manual.
Search for VTEC system malfunction.
There is a complete section in this manual on how to troubleshoot the VTEC system.
This code is pretty extensive and can be caused by a number of things. The most common would be low oil, however I have seen cars with faulty VTEC pressure switches to faulty VTC actuators.
The best thing to do would be to read the service manual and diagnose the problem yourself, or bring the car to a qualified Honda/Acura mechanic.
________
Ford ltd (north america) picture
TypeOne is offline   Reply With Quote
Old 08-26-2008, 12:27 PM   #19
infraredrsx
Zero Tolerance 4 Retards
infraredrsx's Avatar
infraredrsx is on a distinguished road
W.... T.... F.... is the.... deal.... with... all the... ellipses....?
There are 2 types of people behind the wheel, drivers and operators.
Operators are interested in geting from point A to point B.
Drivers are interested in what's between.
infraredrsx is offline   Reply With Quote
Old 03-17-2010, 06:57 PM   #20
kaynematherne
kaynematherne is a jewel in the rough of c-rsx kaynematherne is a jewel in the rough of c-rsx kaynematherne is a jewel in the rough of c-rsx kaynematherne is a jewel in the rough of c-rsx kaynematherne is a jewel in the rough of c-rsx kaynematherne is a jewel in the rough of c-rsx kaynematherne is a jewel in the rough of c-rsx kaynematherne is a jewel in the rough of c-rsx
could someone please tell me the location of my Oil pressure switch on a '05 RSX Type S, and also if I'll need the special socket or would a metric deep barrel socket work. Thanks
kaynematherne is offline   Reply With Quote
malfunction , oil , p1259 , pressure , switch , system , vtec
