| Sponsored Links | |||
Advertisement | |||
#352 | |
beersnob
![]() Awesome work!
All Motor Crew Member #18 I touch myself at night when my parents go to sleep.
#354 | |
black and yellow ;)
that is so badass, I followed this since day 1, simply amazing.
2001 mustang gt, 99 miata, 04 mountaineer 2000 Ranger 2011 Escape Quote:
#356 | ||
Scotty we need more POWER
If by later model you still mean the same shape as mine then the shell didnt really change through its development and years of production. I am 5'11" and fit just fine, with a helmet on I still dont hit the roll cage and there is a bar running straight over my head, admittedly my seat is a whole lot closer to the floor than in a standard car and can go lower still if needed.
MY K20A2 JRSC SWAP THREAD - COMPLETED PROJECT PICTURES ON PAGES 11 & 12 |
#357 |
I decided to ditch my Acetal thermal gasket as I was concerned about heatsoak when shutting down a hot engine after being on track so I looked deeper into plastics and their respective thermal properties and have decided to use Polytetraflouroethylene (PTFE) as it has amzing heat resistant properties, its good from -260 to +260 Deg C (-436degF to + 500degF) and is readily available in sheet form of many thicknesses. I am going to stick with the Acetal between the charger/aftercooler and the aftercooler/manifold. The PTFE is also much easier to work with if you have limited resources, again I produced the part with a pillar drill, a 4mm drill for chain drilling, a 12mm drill for the top of the ports and then also for smoothing the ports and finally a 9mm drill for the bolt holes. Be warned if using a hand drill the material will pull you into it as it is quite soft material. Unfortunately the only photo I took so far is with the OEM gasket on it being used as a template. ![]() ![]() And I my K24 CP (6.37") in the post on Monday (thanks E.): ![]() .
#358 |
ALSO POSTED IN SUPERCHARGED SECTION
Some more done over the weekend: 1) Crank Pulley replaced. Before I put the new pulley on I decided to weigh it, more out of curiosity thatn anything else and the results were really quite surprising. Below is a photo of the two next to one another and then them seperately on the scales. ![]() K20 original: ![]() K24 6.37": ![]() Yes thats right, 20g's lighter and considerably bigger. 2) Snout Clamp I offered up a paper template of the latest and simplest design, pretty close, just a couple of mm adjustment and we are there. ![]() ![]() 3) Thermal Gasket I got a better photo of the new PTFE Thermal Gasket when I pulled the charger off the motor again.
#360 |
Just went through the whole build, this is one sick car!!
#362 | |
ALSO POSTED IN SUPERCHARGING SECTION:
The cover over the grooved odler is to protect my fuel line that comes in that side of the fuel rail. Latest screen shot: ![]()
#364 |
PRE RAD IS FIXED IN PLACE
I got my pre rad fully fitted into place on saturday, proper chuffed with it, I even got the grille back on and it only fouls a tiny amount, not that anyone would ever notice, unfortunately I dint get any with the grille on but I will in the near future. I am going to see what the engine temps are like before I decide if I need anymore cool air ducting past the pre rad into the engine rad. I ended up with the pre rad upside down to its normal usage position, this might sound odd but it has worked out for the best as its drainage plug is now a bleed screw, perfectly placed to get rid of any air in the system at the top on the drivers side of the rad. By jacking the beast up on the drivers side whilst bleeding out the air will totally get rid of any air in the rad. I havent got it piped yet as I was waiting til I put the engine back in so I have it on ramps to fit the pipework. A few photos of it installed: ![]() ![]() ![]() ![]()
#366 |
Snout Clamp/Support Complete
Posted in SC section also. I'll let the pictures speak for themselves: ![]() ![]() ![]() ![]() ![]() ![]() ![]() Kirk Out...... .
#368 |
NEW THROTTLE CABLE HOLDER
Also posted in Supercharged section. Due to the repositioning of the throttle body I have had to redesign the throttle cable holder, the TB is now 3" more outboard and 3.5" higher, the throtle cable did not have enough extra length in it to be able to meet the old throttle cable holder. So a series of pictures, running from the design in CAD, through the production to the final part: ![]() ![]() ![]() PRODUCTION ![]() ![]() ![]() ![]() ![]() FINAL PART ![]() ![]() ![]()
#369 |
Internet Crack Dealer
on the SC bracket, do you think that will help with belt issues? I would make them if it works.
#370 |
Do you even Feel?
This is one amazing project, looks fantastic!
#371 | |
In answer to your question I beleive it will help with belt slip compared to the setup I had before where the belt went from the CP round the auto tensioner to the BP. I am looking into a restrictor for the auto tensioner, it will allow the tension to go on incase of belt stretch but not allow the tensioner to release tension under load.
#372 |
#373 |
Also posted in SC forum
Fitted new cltuch and flywheel and the weekend and also the new belt (fits like a dream), I also got the motor back in the car so its all go to get it running and ready for a track day on 2nd June. New clutch and flywheel: ![]() new belt: ![]()
| Bookmarks |
| Tags |
| austin, cooper, k20a2, swap |
| Thread Tools | |
