Obviously this isn't every DIY on ClubRSX so if you know of one that you want to see up here just let me know and I'll add it to this list :thumbsup: Plus... lets be honest... the DIY section is filled with a bunch of threads asking for DIY's so hopefully this can help filter those out
If you see something in the wrong section feel free to correct me on that as well
Got a CEL and dont have an OBDII reader? Use this method. You want to know whats wrong with your car before attempting any DIY repairs!
Engine
Transmission
Electrical
Suspension
Brakes
Exterior
Interior
Misc/IDK WTF to put these :rotfl:
And last but not least... a copy of the helms manual link: Helms Thread on ClubRSX Obviously, the earlier links were taken down so start looking towards the end of the thread for it! *edit* actually josolanes told me there is a link in his sig so here it is: http://kprotuners.com/forum/files.php?pid=803&aid=827[/B he has it uploaded on his new site, kprotuners.com so take advantage of the file and the info on that site as well. thanks!
Helms for Other Honda/Acura Vehicles
Engine
- Oil Change (Pics Don't Work)
- Oil change mess, no problem
- CAI (Cold Air Intake) Installation
- Exhaust
- Intake Air Bypass Control Thermal Valve
- Intake Air Bypass Control Thermal Valve 2
- Spark Plug Change
- Valve Lash Adjustment
- RBC Install (no pictures)
- RBC Install for Base with Pictures. Note K-Pro Required
- RBC Karcepts Adapter Instructions
- Throttle Body Coolant Bypass
- Shorty Header Install
- Basic Race Header
- DIY Serpentine Belt Change 1
- Guide to Serpentine Belt Change
- Valve Cover Replacement
- Walbro Fuel Pump (start on post 587)
- Walbro Fuel Pump
- Fuel System Upgrade (-6AN Feed/Return/Walbro/Fuel Rail/FPR)
- Primary o2 Sensor Replacement
- Oil Catch Can
- IACV/Throttle Body Removal
- IACV (Idle Air Control Valve) Cleaning
- Valve Adjustment
- Valve Adjustment 2
- Starter (pics don't work)
- Motor Mounts
- K24 Build Up
- Radiator Flush and Hose Replacement
- Camshaft Install
- K24A2 Swap
- Fuel Line Tuck with aftermarket Rail
- Thermostat Replacement
- Timing Chain
- Hondata IMG Install (No Pics)
- DIY: Knock Sensor (& Starter) Replacement - Base Model
Transmission
- Clutch Install
- Clutch 2
- Bleeding Clutch Line
- Buddy Club Short Shifter
- Clutch Master Cylinder (CMC) Replacement
- Manual Transmission Fluid Change
- DIY Omni-Power Clutch Master Cylinder Install
- DIY: CV Axle Shaft Replacement
Electrical
- Battery Relocation
- Headlight Bulbs
- Aftermarket Sub/Amp on Stock Bose System
- Door Actuator
- How to Reset your SRS Light
- Big 3 1/0 Gauge Wiring
- Remote Fuse Panel
Suspension
- Installing Coilovers
- Spring/Coilovers (No Pictures)
- Spring/Coilvers (No Pictures)
- Coilover Adjustment
- Ingalls Camber Kit
Brakes
- Front Pads and Rotors
- Rear Pads (Pics don't work)
- Front Brake Caliper Rebuild
- Base to Type-S Brakes
- SS (Stainless Steel) Brake Lines on EP3 (Same for RSX and RSX-S)
- Rear Caliper Rebuild (pictures from an MR2)
Exterior
- Type-R/Aspec Spoiler
- Fenderliner Removal
- Remove Front Bumper + Headlights for 2002-2004 RSX (The concept should also work for 2005-2006)
- 02-04 to 05-06 Front End Conversion
- 02-04 to 05-06 Rear End Conversion
- 05-06 Rewired Lights on JDM Tail Lights
- Debadge Your Car
- Emblem Adhesive Removal
- Hood Cable Relocation
- Hatch Replacement
- Rattle Can Paint Job
- Cheap License Plate Relocation
- Cheap License Plate Relocation 2
- Blackout Headlights
- Blackout Headlights 2
- Blackout Headlights 3
- Foglight DIY Wiring Guide
- Foglights 2 (No switch harness)
- Foglights 3
- Foglights 4
- Foglights 5
- Foglight Wiring (Turns on in first click)
- Lexan XL10 Foglight Lens Replacement
- Tail Lights
- Paint Wheels (pics don't work)
- Paint Wheels
- Cheap Window Molding Fix
- Headlight Haze Cleaning/Removal
- Cutting Fenders for Sidemarkers
- 05-06 BIXENON Projector Install
- Mini H1 Bi-xenon retrofit video (DIY tutorial)
- Rear Wiper Delete
- Taillight Gasket Replacement
- Door Visor (no pictures)
- Red "H" Centercap almost free
- DIY JDM sidemarkers complete installation guide with pics
- DIY Door visors with pics
- DIY - Window Visor 3M Di Noc Carbon Fiber WRAPPED
- Turning your 02-03 grill into a 05-06
- 2005-2006 front A-Spec under body spoiler installation guide
- DIY: RSX USDM OEM Rear Emblems Rebadge/Install
- DIY: How To Spray Paint And Get Professional Results!
- Aerocatch hood latch- How To
Interior
- Push Start Without Clutch
- S2000 Gauge Cluster
- Painting A-Pillars
- More Interior Painting
- Wrapping your Headliner and Paint Trim
- Steering Wheel Removal
- Aftermarket Steering Wheel Install and Quick Release with Horn Fix
- JDM Steering Wheel Airbag in USDM Car
- NRG Quick Release
- DIY: Aftermarket Steering Wheel SRS Indicator Light Bypass Using Works Bell Resistors
- DIY : JDM DC5 ITR E-Brake Installation
- Garage Opener
- Pedal Covers
- Pedal Covers 2
- Dash
- Aftermarket Navigation
- Door Inserts
- Auto to manual shift boot
- Help Prevent Rattles
- DIY ITR Blue/Red Carpet
- DIY: RSX Trunk Hatch Actuator Replacement
- DIY Make Your Own Shift Boot
- Compression Test
- How to Recharge A/C (Air Conditioning) (done on a 1992 r12 honda civic but its the same for an rsx with r134a)
- Cabin Filter Replacement
- Keyless Entry Programming (starts on post #11)
- Maintenance Light Reset (Please note that step #4 is a joke lol)
- Fiberglass Subwoofer Enclosure
- Full Throttle Shift a DIY w/ Video
- Installing EPS (Electric Power Steering) in your RSX
- Fixing your Power Transistor in your RSX
- DIY: Trunk Hatch Shocks Aftermarket Replacement (Lift Support) No Dremel Required
