K20z1 cams ??? - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS RSX > All Motor RSX
Notices
Reply
Thread Tools
Old 12-28-2016, 02:35 AM   #1
rnb754
New Member
rnb754 is a jewel in the rough of c-rsx rnb754 is a jewel in the rough of c-rsx rnb754 is a jewel in the rough of c-rsx rnb754 is a jewel in the rough of c-rsx rnb754 is a jewel in the rough of c-rsx rnb754 is a jewel in the rough of c-rsx rnb754 is a jewel in the rough of c-rsx rnb754 is a jewel in the rough of c-rsx
K20z1 cams ???
Hey guys,
I'm trying to identify the k20z1 cams. I picked this up for cheap so I figured I try it. I took some pics of my k20a2 cams and the k20z1 cams. What markings or stamp can I look for? I did searching already but the thread is so old that it doesn't show me any pictures.
Thanks for your help
rnb754 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-28-2016, 12:31 PM   #2
remyrounds
Site Sponsor
remyrounds's Avatar
remyrounds is an unknown quantity on c-rsx
They will look just like this
Kseriesparts.com
remyrounds is offline   Reply With Quote
Old 12-28-2016, 03:22 PM   #3
rnb754
New Member
I did some research before posting and everyone said that those would be the type-r and not the k20z1.
Old 12-28-2016, 11:10 PM   #4
koncept88
DC5
koncept88 is a jewel in the rough of c-rsx koncept88 is a jewel in the rough of c-rsx koncept88 is a jewel in the rough of c-rsx koncept88 is a jewel in the rough of c-rsx koncept88 is a jewel in the rough of c-rsx koncept88 is a jewel in the rough of c-rsx koncept88 is a jewel in the rough of c-rsx koncept88 is a jewel in the rough of c-rsx
Not worth swapping into our k20a2, you can measure the cam lobes for the primary, secondary, and vtec lobe, but I bet not really a performance gain.
koncept88 is offline   Reply With Quote
Old 01-05-2017, 11:22 AM   #5
IronGumby
05 Type S RH Reflash LSD
IronGumby's Avatar
IronGumby is a jewel in the rough of c-rsx IronGumby is a jewel in the rough of c-rsx IronGumby is a jewel in the rough of c-rsx IronGumby is a jewel in the rough of c-rsx IronGumby is a jewel in the rough of c-rsx IronGumby is a jewel in the rough of c-rsx IronGumby is a jewel in the rough of c-rsx IronGumby is a jewel in the rough of c-rsx IronGumby is a jewel in the rough of c-rsx
Not jibing, but in your research, didn't you find that the K20Z1 cams are the Type R cams? I mean, not literally part code wise, but spec wise they are known to be like equivalents, and can be tuned exactly the same (no?).
Jesus is Life
IronGumby is offline   Reply With Quote
Old 01-06-2017, 01:02 PM   #6
cblack360
06 RSX TYPE S *bone stock
cblack360 is a jewel in the rough of c-rsx cblack360 is a jewel in the rough of c-rsx cblack360 is a jewel in the rough of c-rsx cblack360 is a jewel in the rough of c-rsx cblack360 is a jewel in the rough of c-rsx cblack360 is a jewel in the rough of c-rsx cblack360 is a jewel in the rough of c-rsx cblack360 is a jewel in the rough of c-rsx
That's what I thought ....
cblack360 is offline   Reply With Quote
Old 01-13-2017, 11:49 PM   #7
glenn.yin6
New Member
glenn.yin6 is a jewel in the rough of c-rsx glenn.yin6 is a jewel in the rough of c-rsx glenn.yin6 is a jewel in the rough of c-rsx glenn.yin6 is a jewel in the rough of c-rsx glenn.yin6 is a jewel in the rough of c-rsx glenn.yin6 is a jewel in the rough of c-rsx glenn.yin6 is a jewel in the rough of c-rsx glenn.yin6 is a jewel in the rough of c-rsx
Yo
Sent from my Z981 using Tapatalk
glenn.yin6 is offline   Reply With Quote
Old 01-24-2017, 09:46 AM   #8
redone13
New Member
redone13's Avatar
redone13 is a jewel in the rough of c-rsx redone13 is a jewel in the rough of c-rsx redone13 is a jewel in the rough of c-rsx redone13 is a jewel in the rough of c-rsx redone13 is a jewel in the rough of c-rsx redone13 is a jewel in the rough of c-rsx redone13 is a jewel in the rough of c-rsx redone13 is a jewel in the rough of c-rsx
From my understanding, the Z1 cams are not as good as the ITR but better than the A2 cams. That is why people usually say either use the ITR or 06+ TSX cams if upgrading to an OEM cam.
2004 RSX Type-S A-Spec
redone13 is offline   Reply With Quote
Old 01-24-2017, 10:08 AM   #9
Kevink121
#Inkpot
Kevink121's Avatar
Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member
K20a>/=K20a2>K20z1
Itr is basically equal to the a2, no real discernible difference or point in paying more for the itr cams. K20z1 is after those two.
I went to go check that I was right on this and I'm not finding anything definitive. (too many threads pointless threads clogging up the search results........)
In any case I always had it in my mind that "K20a>/=K20a2>K20z1" was basically the 01-06 hierarchy of K20 cams.
Annnnnnnd now that I reread the OP I realize my post is off topic anyways. Just ignore me
This little baby car Do you even Miata, bro?
PERMANENT Arcade Champion
Kevink121 is online now   Reply With Quote
Old 01-27-2017, 12:27 PM   #10
dc5cbc05
Master Member
dc5cbc05's Avatar
dc5cbc05 is an unknown quantity on c-rsx
irongumby is right. The ITR and Z1 cams are identical it's been discussed and case closed many of times. and they are a cheap drop in cam alternative for the A2 if you have them laying around and want any bit of gain you can squeeze for a baller on a budget. The TSX cams are a little bit more of a bump but usually have an overrated price tag for OEM cams. My buddy had a base with the type s conversion headwork. made 176 or so on the A2's then 189 on the Z1 cams and then 225 on kelford drop in cams and a few other changes.
dc5cbc05 is offline   Reply With Quote
Old 01-28-2017, 02:13 PM   #11
IronGumby
IronGumby's Avatar
It has always been my understanding the 10hp bump from 1st gen (A2) to 2nd gen (Z1) was the cams and the slightly larger exhaust. There's nothing else that really changed powertrain-wise (excluding the final drive which doesn't affect the dyno), which is why people do cam swaps to the K20A2's instead of buying a whole K20A motor. All you need is a PRC or RBC!
Anyways, can't help the OP on the actual question, lol
Jesus is Life
Old 04-21-2017, 03:43 AM   #12
KillaLude
Need Something 2 wheeled
KillaLude's Avatar
KillaLude is an unknown quantity on c-rsx
Originally Posted by Kevink121 View Post
K20a>/=K20a2>K20z1
you are actually backwards A2 cams are marked PRB Z1 cams are PRC (type R) cams.The cams and bigger exhaust is why in 05 the RSX bumped to 210hp till they revamped the way they figure HP is 06 and dropped it to 201. the only reason the Z1 makes less power then a K20A ITR is it has 11.7:1 ish compression the Z1 has 11:1
To help the OP Z1 cams look just like Type R cams unless my car just cam with Type R cams
KillaLude is offline   Reply With Quote
Old 04-24-2017, 10:52 AM   #13
Koopa Troopa
Senior Member
Koopa Troopa's Avatar
Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx
Due to the better quality of Japanese high octane pump gas (95 AKI), I guarantee you the stock ITR timing map is a little more aggressive than the K20Z1.
Koopa Troopa is offline   Reply With Quote
Old 04-25-2017, 08:52 PM   #14
KillaLude
KillaLude's Avatar
you may be right about the gas but all the info I gather says 93 is the same as 100 in Europe and 95 in japan. But im sure there are tune differences being an ITR is a more aggressive car.
Old 04-26-2017, 10:27 AM   #15
Koopa Troopa
Senior Member
Japanese pump gas is rated in RON (as well as Europe). E85 and 93 would be the closest things to Japanese high octane. Japanese high octane is 100 RON and E85 is 102 RON and 93 would be 98 RON. I'm pretty sure that cars built for the US don't take 93 into account since it is not available throughout the country.
Reply
Bookmarks
cams , k20z1
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
