This thing is huge but it looks killer, love the black.
Skunk2 is proud to introduce its all-new, 74mm Pro Series Throttle Body for Honda’s K-series engines—the biggest K-series throttle body you can buy. Skunk2’s Pro Series Throttle Bodies are designed to be used with OEM Acura RSX (PRB) or Skunk2 Pro Series Intake Manifolds for bolt-on horsepower and torque gains by optimizing engine airflow (other applications, including ’06+ Civic Si RBC manifolds, require adapter plate).
Skunk2 throttle bodies undergo an extensive design and testing process to produce a unit that doesn’t just provide more flow, but retains smooth drivability and OEM throttle characteristics. Skunk2 Pro-Series Throttle Bodies are designed using the latest CAE (Computer Aided Engineering) tools to produce a unit that exceeds industry standards. Each Pro-Series Throttle Body is CNC-machined from forged, billet 6061-T6 aluminum and hard anodized for durability in Skunk2’s signature Black Series finish. Additionally, Skunk2’s unique K-series throttle pulley design allows for smooth movement and pedal modulation, and the OEM coolant hoses have been eliminated for cooler operation.
A larger throttle body is key to producing additional power throughout the powerband on modified engines with increased airflow demands. Skunk2’s new Pro Series Throttle Bodies feature a 74mm bore, which results in significant horsepower gains throughout the powerband on naturally aspirated applications and even more on forced induction ones.
Skunk2 74mm Pro Series Throttle Bodies for Honda’s K-series are available now at a retail price of $400.90.
FEATURES:
Large 74mm Bore
Compatible With OEM Throttle Cable
CNC-Forged 6061-T6 Billet Aluminum Construction
Sealed Bearings For Smooth Operation
Durable, Corrosion-Resistant Hard-Anodized Finish
Eliminates OEM Water lines For Cooler Operation
Integrated Skunk2 Badge
http://www.clubrsx.com/cr/SK2-309-05-0095.html
FEATURES:
Large 74mm Bore
