Acura RSX Reverse/Backup LED Bulbs! See Installed Comparison Photos! Ships Same-Day! - Club RSX Message Board
Go Back   Club RSX Message Board > Site Sponsors Section > Diode Dynamics
Notices
Reply
Thread Tools
Old 12-17-2014, 04:51 PM   #1
Diode Dynamics
Site Sponsor
Diode Dynamics's Avatar
Diode Dynamics is a jewel in the rough of c-rsx Diode Dynamics is a jewel in the rough of c-rsx Diode Dynamics is a jewel in the rough of c-rsx Diode Dynamics is a jewel in the rough of c-rsx Diode Dynamics is a jewel in the rough of c-rsx Diode Dynamics is a jewel in the rough of c-rsx Diode Dynamics is a jewel in the rough of c-rsx Diode Dynamics is a jewel in the rough of c-rsx
Arrow Acura RSX Reverse/Backup LED Bulbs! See Installed Comparison Photos! Ships Same-Day!
Acura RSX Reverse Light LED
At Diode Dynamics, we carry a full line of LED bulbs, including three different levels of brightness for your reverse light or backup light bulb (921 / 7440 sizes). We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two LED bulbs for perfect fitment in your Acura RSX model year selection.
Bulb Design
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
XP50: Each of the four sides of this bulb contains two 5W-rated chips, and the top is fitted with two more under a projector lens. Housed in an aluminum casing with textured finish for maximum heatsinking properties.
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Fitment.
(2005-2006 Model years) use a quality inject-molded 921 terminal, with a sturdy base connector and proper pin alignment, designed for exact replacement of your factory 921 bulb. You will not need resistors for backup lights. Just replace the factory bulb.
(2002-2004 Model years) use a quality inject-molded 7440 terminal, with a locking base connector and proper pin alignment, designed for exact replacement of your factory 7440 bulb.
Included in your order is TWO BULBS.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP36: (210 lumens) Slightly higher brightness than OEM bulbs.
XP50: (410 lumens) Much brighter than OEM bulbs. These are bright!
HP48: (280 lumens) Similar brightness to OEM
HP11: (310 lumens) Slightly higher brightness than OEM bulbs.
XP80: (510 lumens) Much brighter than OEM bulbs. These are bright!
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Shop Now: 2002-2004 Acura RSX Backup/Reverse Light
Shop Now: 2005-2006 Acura RSX Backup/Reverse Light
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
XP80 Output (510 lumens):
Diode Dynamics is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-18-2014, 03:08 PM   #2
Diode Dynamics
Site Sponsor
http://www.youtube.com/watch?v=iE4ZjQcsSKY
Good vs. Bad LED Bulbs: Testing Current
Old 02-02-2015, 06:40 PM   #3
rizz
Senior Member
rizz is a jewel in the rough of c-rsx rizz is a jewel in the rough of c-rsx rizz is a jewel in the rough of c-rsx rizz is a jewel in the rough of c-rsx rizz is a jewel in the rough of c-rsx rizz is a jewel in the rough of c-rsx rizz is a jewel in the rough of c-rsx rizz is a jewel in the rough of c-rsx rizz is a jewel in the rough of c-rsx
okay I want the brightest leds for my car 2002 acura rsx
how many do i need for ALL interior/exterior and part number with price\
thanks!
rizz is offline   Reply With Quote
Old 02-03-2015, 09:07 AM   #4
Diode Dynamics
Site Sponsor
thanks!
We can help you find the best products for each location, please send an email to: contact@diodedynamics.com
U.S. forum members receive free-shipping as well!
Thanks,
Nick C.
Old 03-03-2015, 07:05 PM   #5
LiL N
Master Member
LiL N's Avatar
LiL N is a jewel in the rough of c-rsx LiL N is a jewel in the rough of c-rsx LiL N is a jewel in the rough of c-rsx LiL N is a jewel in the rough of c-rsx LiL N is a jewel in the rough of c-rsx LiL N is a jewel in the rough of c-rsx LiL N is a jewel in the rough of c-rsx LiL N is a jewel in the rough of c-rsx LiL N is a jewel in the rough of c-rsx
Xp50....$90?
05 RSX Type S/97 Integra Ls Totaled/96' Integra RS Sold!!/94' Integra LS Sold/99' Civic EX Sold/94 Civic EX Sold!
TeXaS RaiSeD N MeXiCaN WayZ!!
LiL N is offline   Reply With Quote
Old 03-04-2015, 08:35 AM   #6
Diode Dynamics
Site Sponsor
Originally Posted by LiL N View Post
Xp50....$90?
It takes a lot of work to achieve 410 lumens of output with a 921-sized LED bulb:
It uses high-end components and advanced construction. We offer a variety of bulb models as well
Nick C.
Old 03-04-2015, 08:40 AM   #7
Overdosedvtec
Senior Member
Overdosedvtec's Avatar
Overdosedvtec is an unknown quantity on c-rsx
Could you please pm me a quote for a 2005 DC5 for interior, reverse and rear license plate. Thanks
05-DC5 SSM N/A 290.2whp/235tq e85 more to come
06-FG2 602.37whp/422.99tq @ 18.5psi 93 octane
1999-Chevy Prizm daily FTW
Overdosedvtec is offline   Reply With Quote
Old 03-04-2015, 08:41 AM   #8
Overdosedvtec
Senior Member
Might also need some for two other vehicles as well. Thanks
Old 03-04-2015, 12:36 PM   #9
Diode Dynamics
Site Sponsor
Our RSX listing can be found here on our site: http://www.diodedynamics.com/store/l...acura/rsx.html
Feel free to give us a call if you have any questions: (314) 205-3033
We appreciate your support!
Thanks,
Nick C.
Old 07-22-2015, 08:16 AM   #10
Diode Dynamics
Site Sponsor
Comparison photos added!
Thanks,
Nick C.
Old 08-19-2015, 07:44 AM   #11
Diode Dynamics
Site Sponsor
The rear sidemarker is easy to swap out, it's a simple 194 bulb. Here's a comparison with our HP3 & HP5 installed
The red is much deeper and nicer looking than the factory incandescent bulb
Nick C.
Old 09-23-2015, 11:05 PM   #12
hargow
***nned
hargow's Avatar
hargow is a jewel in the rough of c-rsx hargow is a jewel in the rough of c-rsx hargow is a jewel in the rough of c-rsx hargow is a jewel in the rough of c-rsx hargow is a jewel in the rough of c-rsx hargow is a jewel in the rough of c-rsx hargow is a jewel in the rough of c-rsx hargow is a jewel in the rough of c-rsx
Damn I wish I saw this earlier. I just bought new reverse/licenseplate led
PWP Aspec 04 TSX w/ Navi
hargow is offline   Reply With Quote
Old 09-29-2015, 04:11 PM   #13
Diode Dynamics
Site Sponsor
Let us know if there is anything else we can do to help @hargow
Nick C.
Old 10-16-2015, 04:46 PM   #14
Diode Dynamics
Site Sponsor
Meet our newest LED bulb replacement, the HP48:
Available in 1156/7 - 3156/7 - 7440/3 sizes
Old 11-17-2015, 08:22 AM   #15
tommycrx
Member
tommycrx is a jewel in the rough of c-rsx tommycrx is a jewel in the rough of c-rsx tommycrx is a jewel in the rough of c-rsx tommycrx is a jewel in the rough of c-rsx tommycrx is a jewel in the rough of c-rsx tommycrx is a jewel in the rough of c-rsx tommycrx is a jewel in the rough of c-rsx tommycrx is a jewel in the rough of c-rsx
Ordered the HP36 bulbs on Tuesday, got 'em on Saturday, and installed last night. Awesome brightness, very happy with them. They did take a little more force going in than I thought they would, but not a big deal.
tommycrx is offline   Reply With Quote
Old 11-17-2015, 08:56 AM   #16
Diode Dynamics
Site Sponsor
Thank you for ordering with us!
Have you taken any comparison photos yet?
Nick C.
Old 11-17-2015, 11:15 AM   #17
tommycrx
Member
I could put one of the old bulbs in this weekend and take some comparison pics.
Old 11-17-2015, 11:16 AM   #18
Diode Dynamics
Site Sponsor
Nick C.
Old 12-08-2015, 09:39 AM   #19
tommycrx
Member
Nick, sorry - friend took pic, then sent me a preview pic, then of course, had already deleted the pic on his phone before I told him it was too grainy.
I'll redo this weekend, and replace the above pic when I do, but even on the pic, you should be able to see how much more defined the light from the HP36 is on the right side. It's also a good bit brighter, but that's lost in the pic.
Replaced the pic; hopefully, the difference in brightness now comes through.
Old 12-08-2015, 09:46 AM   #20
Diode Dynamics
Site Sponsor
Regardless of the quality, thank you for submitting a picture!
Nick C.
Old 12-08-2015, 10:04 AM   #21
tommycrx
Member
Submitting a sh*tty pic is the least I could do.
I also put in your flasher resistor with the extensions; usually hate doing electrical work, but it was a piece of cake, and all turn signals work perfectly; hardest thing was figuring out where to stick the flasher box - ended up double sided taping it to the front of the fusebox where there are no fuses . The internal clicks seem to be a bit louder while the turn signals are on too, which was an unexpected bennie.
So thanks!
Old 12-08-2015, 10:11 AM   #22
Diode Dynamics
Site Sponsor
Nick C.
Old 03-01-2017, 09:10 AM   #23
Diode Dynamics
Site Sponsor
The output from one 6" Stage Series Wide pattern light bar is perfect for auxiliary reverse lighting!
Resz Fabrication
Nick C.
Old 03-02-2017, 01:17 PM   #24
Diode Dynamics
Site Sponsor
Like us on Facebook!
Diode Dynamics Timeline
Nick C.
Old 03-03-2017, 09:30 AM   #25
Diode Dynamics
Site Sponsor
Questions about a product? Need information?
Give us a calll!
(314) 205-3033
Reply
Bookmarks
acura , bright , bulbs , comparison , cree , hipower , installed , led , models , photos , reverse or backup , rsx , sameday , ships
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
