Which turbo kit is right for you? - Page 2 - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS > Turbo
Notices
Reply
Thread Tools
Old 09-29-2005, 03:42 PM   #26
wanka
New Member
wanka is an unknown quantity on c-rsx
whats the most inexpensive way to put a turbo on this car? theres a local shop that builds turbo manifolds. can i throw on a cheap junkyard turbo, throw on some piping? what kind of injectors or fuel management is neccessary?
wanka is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-29-2005, 03:50 PM   #27
Arctic04S
Master Member
Arctic04S is an unknown quantity on c-rsx
junkyard turbo kit = junkyard results
save the cheap fixes for your beater civic; don't ruin a $20,000 car with a cheap setup. They aren't that expensive to begin with. Do it the right way once. If you can afford the car, you can afford to save up for a while to get what you want. If you cannot, then you cannot afford the safety margin you would want to have if you were to go f/i anyway...
Arctic04S is offline   Reply With Quote
Old 09-29-2005, 04:13 PM   #28
wanka
New Member
then whats a cheap turbo kit cost for low boost like 7 psi or so? and do i have to do anything to the motor like low compression pistons? since its a high compression motor
Old 09-29-2005, 04:14 PM   #29
K20A2_S
Monsters of the Midway
K20A2_S's Avatar
K20A2_S is an unknown quantity on c-rsx
Get a used Greddy kit, seen them go for 2000-2500............everything you need to boost a safe moderate level with oppurtunities to upgrade later.
K20A2_S is offline   Reply With Quote
Old 09-29-2005, 04:16 PM   #30
chink4lyfe
www.TeamDC5.com
chink4lyfe is an unknown quantity on c-rsx
no 7psi is safe and u will not need low compression pistons or stronger rods. our motors r built well and can stand up to 18psi without changing any internals but all motors r different and im not telling u to turn ur boost up to 18psi. but up to 10psi is safe daily!!
PWP 04 RSX-S SOLD!
AS 06 EVO IX GSR SOLD!
WDP TL TYPE S
chink4lyfe is offline   Reply With Quote
Old 09-29-2005, 04:32 PM   #31
wanka
New Member
how much HP would I gain from 7-10 psi on the k20a2
Old 11-21-2005, 01:56 PM   #32
xxxpdtn
New Member
xxxpdtn is an unknown quantity on c-rsx
7-10 lbs of boost will give you a 30 percent increase in power
xxxpdtn is offline   Reply With Quote
Old 11-21-2005, 04:24 PM   #33
MrBurner
Traction is for pussies
MrBurner's Avatar
MrBurner is an unknown quantity on c-rsx
where are you getting this from? there are many variables and although the above may be true with some cars, it is not with the rsx...at 10 lbs, people are putting down well over 300 whp...stock is roughly 160-170whp...that is close to a 100% increase in power
also, the s2000 puts down around 200whp while a turbo s2000 on 10 lbs. of boost has seen 400whp
Turbo Forum Moderator
Car is totalled - everything must go
EVERYTHING IS FOR SALE - NEW FOR SALE PAGE JUST CREATED 01/28/06 - TONS OF RSX PARTS FOR SALE OFF MY TOTALLED TURBOCHARGED RSX-S
www.mrburner.com
KPRO IS SOLD
MrBurner is offline   Reply With Quote
Old 11-21-2005, 04:25 PM   #34
MrBurner
MrBurner's Avatar
can i turbo my base rsx or not
yes, this has been covered many times and there are tons of threads on the subject
www.mrburner.com
KPRO IS SOLD
Old 11-28-2005, 11:17 PM   #35
Jsrstreetdemon
Catch me if you can
Jsrstreetdemon's Avatar
Jsrstreetdemon is an unknown quantity on c-rsx
hey guys im pretty new to boosting motors and i just bought a 03 type s and are currently saving for a turbo kit...ive heard rumors that 18 psi on the block is the max... what kit would be good to mess around with at the track and on the street but i could still keep it a daily driver? any help would be greatly greatly appreciated. email me @ jsrstreetdemon@aol.com
-rob
Jsrstreetdemon is offline   Reply With Quote
Old 12-02-2005, 08:57 AM   #36
JMBare
I love Audi Junkie!!!
JMBare's Avatar
JMBare is an unknown quantity on c-rsx
Originally Posted by friend_of_mine
I want to buy the cybernation stage 2 kit. whats the lowest price anyones heard of and from where? how much hp is it going to add? im pretty new with the car i have a young 03 type s with 24000 miles. i need advice
Avoid the Stage 2 kit, and spend the money on a kit of better quality, such as the offerings from Full-Race. Even if you keep your motor stock, if the Full-Race setup, you may end up making more, "safer" reliable power, than the CN stage 2.
-JMS
Moderator -> Turbo
JMBare is offline   Reply With Quote
Old 12-14-2005, 04:45 PM   #37
IWantTypeS
New Member
IWantTypeS is an unknown quantity on c-rsx
normal atmospheric pressure is roughly 14 psi depending on a few variables....put 7 lbs of boost on a stock engine and it will theoretically produce a 50 percent increase in power...obviously no system is 100 percent efficient...so without any upgrading at all...keeping stock injectors, stock intake and exhaust system, you'll gain around 30 percent....but you never see a turbo motor with stock intake and exhaust systems....so you're going to see more of an increase with 7 psi then 30 percent....and 10 psi will make A LOT more power then 30 percent.....
IWantTypeS is offline   Reply With Quote
Old 12-29-2005, 09:20 AM   #38
blkdc5va
DC5 RIP
blkdc5va's Avatar
blkdc5va has been a little shit in the past
whats the diff between turbos
whats the diff between a 60-1 turbo and a 60-2 turbo? which one will be more bang for the buck? Because im tryin to buy a cn stage 1 turbo for my 04 rsx.
blkdc5va is offline   Reply With Quote
Old 12-29-2005, 11:33 AM   #39
JSpecTypeR
I <3 Bewst
JSpecTypeR's Avatar
JSpecTypeR is a jewel in the rough of c-rsx JSpecTypeR is a jewel in the rough of c-rsx JSpecTypeR is a jewel in the rough of c-rsx JSpecTypeR is a jewel in the rough of c-rsx JSpecTypeR is a jewel in the rough of c-rsx JSpecTypeR is a jewel in the rough of c-rsx JSpecTypeR is a jewel in the rough of c-rsx JSpecTypeR is a jewel in the rough of c-rsx JSpecTypeR is a jewel in the rough of c-rsx
I'd go with the 60-1, a lot of people have that setup instead of the t3/t4 it comes with
JSpecTypeR is offline   Reply With Quote
Old 12-30-2005, 07:33 AM   #40
The Great Cornholio
Bmore211
The Great Cornholio's Avatar
The Great Cornholio is an unknown quantity on c-rsx
I just had the Greddy Turbo with an Extreme Motorsports Custom intercoller, Turbosmart BOV, Custom 3" piping into a Thermal 3" Turbo Exhaust installed on my car. So a few questions. After my turbo was installed, I noticed a low idle for the first few mins after startup. This eventually went away. Secondly, I dont know too much about forced induction but when I hit the gas, My RPMs dont go up as fast as they did without the turbo, is this normal? Third how much HP does 7lbs of boost get you? Should there be any measures I should take for protecting my engine? I dont have forged or low compression pistons but Im only running 7lbs. I wanna run it hard against an Evo or a Stang but Im afraid I might screw something up. Somebody help
The Great Cornholio is offline   Reply With Quote
Old 04-10-2006, 05:48 PM   #41
mikapha13
New Member
mikapha13 is an unknown quantity on c-rsx
what kits are for 05 type s
mikapha13 is offline   Reply With Quote
Old 04-15-2006, 12:51 PM   #42
RobShawRSX
New Member
RobShawRSX is an unknown quantity on c-rsx
Does anyone know anything about this turbo kit? I'm not even sure who makes it. http://www.autoasta.com/browse.php/id=9
RobShawRSX is offline   Reply With Quote
Old 04-15-2006, 03:14 PM   #43
blade80
Member
blade80 is an unknown quantity on c-rsx
i think greddy sounds good.
blade80 is offline   Reply With Quote
Old 04-24-2006, 07:25 PM   #44
Turbo_Ae86
Member
Turbo_Ae86 is an unknown quantity on c-rsx
go with hks.hks is always awesome and reliable.
Turbo_Ae86 is offline   Reply With Quote
Old 04-24-2006, 07:32 PM   #45
Tbone
Supreme Overlord
Tbone's Avatar
Tbone is an unknown quantity on c-rsx
HKS is not worth the money. It is pretty much the worst "bang for your buck" kit out there. Sure they make quality products, but the gains shown to date are far from impressive.
2005 Rio S2000
SOLD: 2003 NBP Acura RSX-S w/ K24 swap
Tbone is offline   Reply With Quote
Old 04-24-2006, 07:34 PM   #46
FastFrontier17
Master Member
FastFrontier17 is a jewel in the rough of c-rsx FastFrontier17 is a jewel in the rough of c-rsx FastFrontier17 is a jewel in the rough of c-rsx FastFrontier17 is a jewel in the rough of c-rsx FastFrontier17 is a jewel in the rough of c-rsx FastFrontier17 is a jewel in the rough of c-rsx FastFrontier17 is a jewel in the rough of c-rsx FastFrontier17 is a jewel in the rough of c-rsx FastFrontier17 is a jewel in the rough of c-rsx FastFrontier17 is a jewel in the rough of c-rsx
hks kit is pointless
[SIGPIC][/SIGPIC]
FastFrontier17 is offline   Reply With Quote
Old 04-26-2006, 09:22 AM   #47
blkdc5va
DC5 RIP
blkdc5va's Avatar
350whp too much for stock motor?
im thinking on boosting my rsx-s but dont know if i should get a cn stage1 or cn stage 2 turbo and i wanted to know if a stock rsx engine can safely handle 350whp or will that be too much and blow my motor?
Old 04-26-2006, 12:04 PM   #48
Tbone
Supreme Overlord
Tbone's Avatar
If I'm not mistaken, PSI is a bigger safety factor than HP. But as long as you stay below 12 lbs of boost on a stock block, you should be okay. Don't go CN though. Their quality is crap. Just piece a kit together like I am doing.
2005 Rio S2000
Old 04-26-2006, 01:11 PM   #49
theheat
Jiffy Lube's K20
theheat's Avatar
theheat is an unknown quantity on c-rsx
I was talking to Full Race the other day and they told me i would need to upgrade my axles if i plan to go with their stage 1 prostreet which packs about 450 hp...would this be true and with that much horsepower would my car be a daily driver?
K-Serious 221whp
theheat is offline   Reply With Quote
Old 04-29-2006, 09:14 AM   #50
RXS Jeff
Whats up BERT!!!!!!!
RXS Jeff's Avatar
RXS Jeff is an unknown quantity on c-rsx
What is a good PSI level I can run my base model on........without Killing the Mortor?????????
RXS Jeff is offline   Reply With Quote
Reply
Bookmarks
kit , turbo
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
