#1 |
hello!!!
NASA South-East Visits Road Atlanta
I have signed up for this event, just wondering if anyone else is interested.. Below is a link... I couldn't miss going to this well known track!!
http://www.nasa-southeast.com/2004Jun19/event.shtml
02 Artic Blue RSX Type S Mods: Performance: AEM ColdAir, JIC Bullet Cat-Back, DC 4-2-1 Header, J's Racing Engine Damper, Hondata #4, Hondata IMG, Exedy Stage 1 clutch, ACT Prolite Flywheel & Quaife LSD Suspension: Mugen Front STB, Spoon Sports Rear STB, Progress Rear Sway w/Tie Bar, Tein S Tech Springs, Koni Yellow Shocks, Goldline Camber Kit, Tanabe Sustec Front lower brace Exterior: OEM Kit and wing, DIY Headlight Housings, RS Limited 17" wheels Others: Revo SS, Acura Aluminum Shift knob, Sparco Grip Pedals and dead pedal, Titanium Trim, Platinum Tinted Windows (35%) JDM Brake Ducts (Custom Grill), Goodridge Brake Lines, Carbotech Panther Plus Front Pads, AXXIS Ultimate Rear Pads |
#3 | |
hello!!!
#4 |
hello!!!
Swwifty, how does that swaybar combo work for ya? I just took off the progress front and but the stock one back on because it was a little to tight for my taste.. The car rotates way better with just the progress rear sway.. but I was looking for another swaybar that would work better for the font..
#5 | |
nice kitty..
huge ass truck: daily black 96' 240sx: track/weekend |
#6 |
hello!!!
Thanks for the info.. I'm more of a track whore!! : ) With both progress sways it turned in nice but from the middle of the corner all the way out it wanted to push out.. The car now is fairly neutral with the progress rear and the stock front bar.. I have 2 deg. of negative camber in front and .8 negative in the rear with 0 toe all around.. (just got it alligned last weekend) This has helped loads and if I let out of the gas when the suspension is fully loaded it will even start to oversteer a little... (very little) I really cannot say how it will do on the track yet though.. I have my crappy tires on and I've done a few things to the suspension since my last track event.. (Koni's and Tanabe underbrace) Atlanta will tell me where I need to go from here. Kind of hard and not safe to test on the steet! : )
<--- cannot wait for Atlanta!!! I have looked into getting a bigger rear bar but I love the progress tie bar for the rear.. Not to fond of getting rid of that beafy peice.. Maybe it will work well with the other bars but havn't looked into that at all...
#7 |
Senior Member
i would like to do that event as well, ive never done a NASA event before (this will be the first event in GA iirc). sucks they dont have IT classes in NASA, i dont think my car is legal for anything else going on that weekend...
#8 | |
hello!!!
I'm looking into building a Pro-7 or spec RX-7 now..
#9 |
party wrecker
I wish I could go... but.. yeah it's uber far for me... even VIR is far enough... lol.. I'm just gonna hit Summit Point in June... I wish they'd finish Shenandoah... lol...
March 2002 - November 2007: 2002 ABP RSX-S (sold) Dec. 2007: 2008 DGM Legacy GT 2008 Suzuki SV650N motorcycle crew#3.14* Last edited by zeroryde; 04-19-2004 at 01:03 PM. |
#10 | |
Senior Member
#11 | |
hello!!!
Do you know or can you build the Rotary's? I have a rebuild kit with new apex seals and all and have taken my current one apart but with all of the little springs and many clearances that have to be measured and in spec I kind of got a little discouraged on rebuilding it myself... and now it's sitting in peices in the garage.. I'm also not sure it the housings would even be in spec.. If not I don't even want to rebuild it because the new housings are soo expensive! I could just buy a new engine..
#12 |
Senior Member
i stack my own 12a's. its really pretty easy once you have done 1 or 2 of em. housings are pretty easy to check, if the plating is not flaking and there is no lip around the edge they are prolly fine. most likely there will be some carbon buildup from blowby on the bump on the plug side, but thats normal. unless you ever overheated your engine the end plates are most likely in spec too, the only thing to check for is the step wear about 1/4" from the edge of the combustion chamber side. i forget the spec for that but its fairly large (maybe .01").
you can spend a shitload of money on building a fast legal motor (like 4-5k), but you can be within 5-10hp of one for around $1000. its all about how fast you wanna go. oh yeah, and get onna these if its legal for your class: http://www.yawpower.com/racecarb.html i can build your motor pretty cheap if you want, there are also alot of legal things you can do to make it more reliable at high rpms. PM me... |
#13 |
hello!!!
So who all is heading out?? Anyone else signed up yet??
#14 | |
nice kitty..
I'm going to do the one in August at Road Atlanta.
#15 |
hello!!!
Two more days!! Can't wait!
#17 |
hello!!!
Road Atlanta rocked the house.. Was lots of fun and a bit scary in some turns.. example turn 12 onto the main strait!
#18 | |
nice kitty..
aww 12 = fun. Glad you had a good time. Wish I could have been there. I plan on doing the August NASA event. Got any pics?
#19 |
hello!!!
Here are some sample pics from a guy that is selling them.. I'll have to get a couple of these off of him
![]() http://www.rdtmotorsports.com/carsamples/rsxand240.htm
#20 |
Senior Member
haha nice those are Ryans pics.
#22 |
hello!!!
Yeah, I'm going to purchase them as soon as the money comes into the bank
Here are a couple more we took:http://forums.clubrsx.com/attachment...hmentid=111732 http://forums.clubrsx.com/attachment...hmentid=111733
| Bookmarks |
| Tags |
| atlanta, nasa, road, southeast, visits |
| Thread Tools | |
