One-touch Auto Up/Down Windows (DEI 530T) DIY Guide - Club RSX Message Board
Go Back   Club RSX Message Board > STYLE RSX > Car Audio, Security, & Electronics RSX
Notices
Reply
Thread Tools
Old 07-18-2004, 10:38 AM   #1
bruha
Senior Member
bruha's Avatar
bruha is an unknown quantity on c-rsx
The DEI 530T window module allows you to control 2 different windows in both directions. Specifically, when the unit is installed with an aftermarket alarm (the Compustar 2WSS-AS in this case), the windows will roll up when the alarm is armed. Then with the remote, you can either crack the windows or roll them all the way down.
The 530T adds one-touch auto up and auto down to your windows even if you don't have an aftermarket alarm. This DIY shows how to make both of your windows one-touch from the driver's side controls.
First off, the unit is rather large, measuring 3 1/2" x 4" and about 1" thick. This makes it difficult to install in the driver's side kick panel like the instructions recommend. There are two wiring harnesses, both 3 feet in length. One is a heavier gauge wire (~14 ga.), the other is a lighter gauge (~18 ga.). Since the wires are short, the unit has to be mounted within 12-15Ē of where the wires come into the car from the door.
As for the installation...
bruha is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-18-2004, 10:39 AM   #2
bruha
Senior Member
bruha's Avatar
Removing the driver's side door panel
You need to take off the driver's side door panel to gain access to two wires. Taking the panel off is rather easy, you don't necessarily need a trim panel remover like the Helm's recommends--carefully pry it off with your fingers. Albeit, the tool makes things easier.
Follow the instructions as shown in the Helms:
Once the panel is off, you need to remove the front half of the plastic. A razor blade helps to cut the gum-like adhesive as you pry the plastic back. In the upper right hand corner (circled in red), the plastic is held in with a round black clip. I just cut the plastic with the razor around the clip instead of popping it off.
Old 07-18-2004, 10:40 AM   #3
bruha
Senior Member
bruha's Avatar
Running wires to the door
Next, you need to run 4 wires into the door from the inside of the car. The 4 wires are:
Brown
White
Blue
Green
The brown and white are on the lighter gauge connector, the blue and green on the heavier. The easiest way to run the wires is to run a wire snake (or fish) through the door grommet. The yellow arrow in the picture below shows where the grommet entrance from inside the car is. Run the snake through one of the small holes in the rubber piece above or below the mass of wires coming in. One the door side of the grommet, I pulled the end piece out from inside the door to try to make things easier (circled in red).
You want the connector heads and the rest of the wires to remain inside the car, only the 4 wires go from the inside of the car to the door.
Old 07-18-2004, 10:40 AM   #4
bruha
Senior Member
bruha's Avatar
Driverís side window
Locate the RED/YEL and RED/BLK wires in the door. It follows the dashed green line in the picture below. Cut both wires above and below the blue connector. The RED/YEL and RED/BLK wire actually turn into blue wires on the other side of the blue connector, so just visually follow the wires through the connector to see what colors they become. The wires above the blue connector are a lighter gauge and match up better with the brown and white wires; the wires below the blue connector are a heavier gauge and match up better with the green and blue wires.
Also, cut the wires on the left side of the blue connector closer to the connector than what I did--this will give you a few more inches to play with inside the car.
Connect the wires as follows:
Switch side (to the left in the picture)
RED/YEL -> White
RED/BLK -> Brown
Motor side (to the right and down in the picture)
RED/YEL -> Green
RED/BLK -> Blue
I soldered the connections then used heat-shrink tubing around them, you can use crimps or whatever method you like. Just make sure you have a solid connection, especially on the motor side.
If you are confident in your connections, put the door panel back on and move onto the next step. You can test your connections by running jumpers between the Blue and Brown wires and between the White and Green wires at the harness heads inside the car. Plug the window switch back in, turn the key, and test the windows.
Old 07-18-2004, 10:40 AM   #5
bruha
Senior Member
bruha's Avatar
Passengerís side window
Above the driver's side kick panel, you'll see a grouping of blue, white, and green connectors. Find the blue connector with the BLU/RED and BLU/WHT heavy gauge wires and disconnect it. It should be the connector closest to the engine, and its below a green connector (circled in yellow in the first picture with the connector unplugged).
Peel back as much tape and plastic conduit as you can to expose the wires, and find the BLU/RED and BLU/WHT wires. You are going to cut them and connect them in the same manner as the 2 wires in the door.
Cut and connect as follows:
Blue connector head side (to the left in the picture):
BLU/RED -> Blue/Black
BLU/WHT -> Green/Black
Wires running into the door grommet (to the right in the picture):
BLU/RED -> Brown/Black
BLU/WHT -> White/Black
Old 07-18-2004, 10:41 AM   #6
bruha
Senior Member
bruha's Avatar
Power and grounding
For the Red power wire, connect it to a constant +12V source. I ran a separate power wire for my alarm, radar, and other accessories; so I just used that. Otherwise, look for a constant +12V source in the fusebox and tap into it there.
Connect the Violet, Violet/Black, and Black wires (all on the heavier gauge harness) to ground. I unbolted the 12mm bolt by the dead pedal, put a ring terminal on the end of all three wires combined, and grounded everything there.
Old 07-18-2004, 10:41 AM   #7
bruha
Senior Member
bruha's Avatar
The remaining wires
At this point, all of the wires in the heavy gauge harness should be connected. The only remaining wires should be the Red/White, Orange, and Gray wires in the lighter gauge harness.
Red/White : (-) Auxillary input
Connect this to one of the auxillary outputs of your aftermarket alarm. A single pulse will crack the windows about an inch. If you have the alarm configured to give you a latch output, it takes about 3 seconds for the windows to roll down.
Orange: (-) Ground when armed
Connect this to the negative ground when armed output on your aftermarket alarm. This will roll the windows up when you arm your alarm. If you press your auxillary output on the remote before you arm the alarm, the windows will stay in their current position.
Gray: (-) negative output during activation
I didn't connect this with my Compustar alarm. It is supposed to be used to disable your shock/motion sensors so the alarm doesn't go off when you remotely roll down the windows. I think the Compustar alarm automatically ignores the sensors while performing the remote operations.
Old 07-18-2004, 10:42 AM   #8
bruha
Senior Member
bruha's Avatar
Additional comments
Here is the wiring schematic for the RSX windows:
And the DEI 530T manual can be downloaded from here:
http://www.directed.com/guides/manua...N530T_1-00.pdf
Old 07-18-2004, 10:44 AM   #9
bruha
Senior Member
bruha's Avatar
There you go, if you have any questions post them up here or PM me and I'll do what I can to help you out.
As soon as I get my DEI 529T moonroof module, I'll post up instructions on making your moonroof one-touch auto up/down too!
Old 07-18-2004, 11:13 AM   #10
c0mp|ex
JDM!!!!!!!!
c0mp|ex's Avatar
c0mp|ex is an unknown quantity on c-rsx
great DIY, mods if u can copy it to the DIY garage or bruha make a link in there
My Feedback
c0mp|ex is offline   Reply With Quote
Old 07-18-2004, 12:01 PM   #11
Blaze6257
Master Member
Blaze6257's Avatar
Blaze6257 is an unknown quantity on c-rsx
That was a good DIY im eventually gonna get someone to do it for me!
2004 Arctic Blue Pearl RSX Type-S
WTB: '05-'06 Headlights. Need ASAP. Please PM me
Blaze6257 is offline   Reply With Quote
Old 07-23-2004, 09:48 AM   #12
bruha
Senior Member
bruha's Avatar
It's really not that hard, it was a lot easier than installing the Compustar.
Old 11-13-2004, 07:01 PM   #13
rsx m-3
The Drone
rsx m-3's Avatar
rsx m-3 is an unknown quantity on c-rsx
Dude can you help me out. i can't find the ground when armed wire on the compustar alarm.
rsx m-3 is offline   Reply With Quote
Old 11-13-2004, 07:41 PM   #14
rest
Spicy Raccoon
rest's Avatar
rest is easy..................when it comes to rep rest is easy..................when it comes to rep
rest is easy..................when it comes to rep rest is easy..................when it comes to rep rest is easy..................when it comes to rep rest is easy..................when it comes to rep rest is easy..................when it comes to rep rest is easy..................when it comes to rep rest is easy..................when it comes to rep rest is easy..................when it comes to rep rest is easy..................when it comes to rep rest is easy..................when it comes to rep rest is easy..................when it comes to rep rest is easy..................when it comes to rep rest is easy..................when it comes to rep rest is easy..................when it comes to rep
oooh. nice I can't wait for the moonroof one
Originally Posted by RuizDC5 View Post
carefully, your PM box is fixin to get full... like your asshole
rest is offline   Reply With Quote
Old 11-14-2004, 09:09 AM   #15
bruha
Senior Member
bruha's Avatar
It's in Connector 1, one of the wires pre-wired into a relay. I think its the Purple wire going into the relay (not the Purple pigtail). Use a voltmeter and probe around to see which wire goes to ground when armed.
Old 11-14-2004, 09:21 AM   #16
travanx
Master Member
travanx's Avatar
travanx is an unknown quantity on c-rsx
probably should make a separate post for my clip, but here you go for what can be done. The one touch up and down on each of the windows is actually a lot more convenient than I though it would be.
http://rsxs.cdin.net/images/open.avi
'95 Porsche Carrera 911
Recaro Speed Seat, Wedge Engineering Bracket
18" Work Brombacher in Dark Gold/Polished Lip
KW V3 Coilovers
Stage1 Exhaust Mod with Pretty Tips
travanx is offline   Reply With Quote
Old 02-07-2005, 09:58 PM   #17
Silver RSX-S
Master Member
Silver RSX-S's Avatar
Silver RSX-S is an unknown quantity on c-rsx
back from the dead, but can you wire the sunroof into this also? so all 3 work. or do you have to get the 529T
Silver RSX-S is offline   Reply With Quote
Old 02-07-2005, 11:31 PM   #18
profuse007
\_ \_ the12volt.com _/ _/
profuse007 is an unknown quantity on c-rsx
great DIY from bruha, master of auto security DIY.
it looks like a jungle in there. how many alarm have you install bruha?
Tran- Houston,TX
Mobile Security DIY
"The 2 most common elements in the universe are H+ and stupidity"(Ellison).
profuse007 is offline   Reply With Quote
Old 02-08-2005, 09:01 AM   #19
bruha
Senior Member
bruha's Avatar
I have a 530T and 529T installed. The 530T is for the two front windows, they are one-touch up and down from the driver's side controls. The Compustar outputs can remotely make them go up or down.
For the moonroof, the 529T is only really used in conjunction with the Compustar outputs. The moonroof can open or close using the Compustar. If you want to make the moonroof one-touch up and down using the switch inside, you need to buy a 530T.
Keep in mind the Compustar only has 2 outputs so you can only do two distinct window motions. For example, I have output 1 crack the windows and moonroof. If I keep pressing the output 1, the windows and moonroof will inch open. I have output 2 set to latch instead of pulse, and it will close the windows and moonroof.
Old 07-13-2005, 11:31 PM   #20
QFCK2001
Senior Member
QFCK2001 is an unknown quantity on c-rsx
hi, I want to install a DEI 530T to my car, i check with some alarm store and they charge 200 for it to be installed, do you think it's worth to let them install? this module is only $60 on ebay. Also, did you install your DEI 529T yet? Did you make it one touch as well? Thanks in advance!
QFCK2001 is offline   Reply With Quote
Old 07-17-2005, 10:52 AM   #21
ACRSX03
2005 JGM Type-S
ACRSX03 is an unknown quantity on c-rsx
If follow Bruha's method it is easy to do. It's easier than installing an alarm. Basically you cut the switch wire and attach a 1 side of the 530T(switch side) to one end and attatch the other side( motor side ) to the other. The 530T monitors the draw of the motor and shuts power off automatically. If you installed your alarm or deck you can do the 530T. I used a 530T for my sunroof to make it 1 touch. Run a search, I beleive they added it to the FAQ page.
Jeff
Just a Darn Good DIY'R
ACRSX03 is offline   Reply With Quote
Old 08-08-2005, 09:11 AM   #22
QFCK2001
Senior Member
The blue connector on my 05 has only 4 wires, there isn't a BLU/RED and a BLU/WHT wire, which wires should i connect?
EDIT:
I found out it's the white connector on 05.
2005 PWP RSX Type S
35% Tint all around
TSX projectors retrofit with RL shorub
Old 08-09-2005, 01:18 PM   #23
ACRSX03
2005 JGM Type-S
Sweet!
At least you got it working!
Jeff
Jeff
Old 08-09-2005, 11:05 PM   #24
QFCK2001
Senior Member
Originally Posted by ACRSX03
Sweet!
Jeff
It's not completely working, when i lock the car, the windows will only roll up like 3 inches then stop, they won't close completely. Can anyone help?
2005 PWP RSX Type S
35% Tint all around
Old 08-10-2005, 11:29 AM   #25
ACRSX03
2005 JGM Type-S
Check your grounds? I grabbed all ground wires, terminated them and secured them under the dead pedal on the floor. Did you diode isolate between the roll up module and the ground when armed wire? Check the resistance dip switches too, I have mine set on the #2 setting.
Let me know,
Jeff
Jeff
Reply
Bookmarks
530t , auto , dei , diy , guide , onetouch , up or down , windows
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2012, Club RSX, Inc. All rights reserved worldwide.
