P0134 Error Code - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS RSX > ECU Tuning RSX
Notices
Reply
Thread Tools
Old 10-16-2004, 07:36 PM   #1
ares650
Member
ares650's Avatar
ares650 is an unknown quantity on c-rsx
Question P0134 Error Code
This past two weeks I have been getting the error code 'P0134 O2 Sensor CKT No Activite Bank1 Sensor1', every other day. I have stock exhaust, stock cat, greddy turbo kit, and the KPro. In the K-Manager software I do not have the CHECK on Disable P0134. What do you think is causing this CEL to come ON?
ares650 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-16-2004, 08:15 PM   #2
hotwheelz
K Builder
hotwheelz is an unknown quantity on c-rsx
I don't know but i got it many times too, i shut the car off and turned it on again and was fine.
Fakin' with honda's so you don't have to!
258whp/207tq dynojet, winterbeater k24 stock bottom
hotwheelz is offline   Reply With Quote
Old 10-16-2004, 08:19 PM   #3
ares650
Member
ares650's Avatar
YEA, me too. But this week that hasn't worked. That is why I am try to solve it. I had to clear it with a sanner or the with the software.
Old 10-16-2004, 08:57 PM   #4
LanceM
Jester of Tortuga
LanceM's Avatar
LanceM is an unknown quantity on c-rsx
I have the same shit. Anyone know?
Lance
Top Down Crew #1
[SIGPIC][/SIGPIC]
Fastest RSX in Louisiana© JRSC 2003 NBP RSX-S 12/28/02-10/8/07 http://www.cardomain.com/ride/751980
LanceM is offline   Reply With Quote
Old 10-16-2004, 09:35 PM   #5
DatFooWitThaRSX
JDM Whore
DatFooWitThaRSX's Avatar
DatFooWitThaRSX is an unknown quantity on c-rsx
i had the exact same problem after i installed all my shit. the wierd part is, when i was running just the dcrh and caspers o2 sim, i had never seen a p0134 code. the second i got hondata itr flash and my cams and other shit put in, the lil bastard light came on.
i cleared it, and like you said, it kept on coming back every other day, so i kept having it cleared by my mechanic. after three times clearing it, it came on again, and this time i was like fuck it....i didnt wanna mess with it. then all of a sudden it turned itself off. that was 4 days ago and counting.....im keeping my fingers crossed and hope it dont come back on.
R.I.P. 2002 Acura RSX Type-S ABP
AEM Cold Air Intake - DC Sports Ceramic Race Header - HKS Hi-Power Exhuast - Mugen Metal Head Gasket - Unorthodox Racing Ultra SS Pulleys - Energy Suspension Motor Mount Inserts - Ingall's Torque Damper - DC5R Red Valve Cover - DC5R Camshafts - DC5R Transmission - DC5R Intake Manifold - Hondata Intake Manifold Gasket - Hondata ITR Flash - S2K F20C Valve Springs - S2K Push Start Button - Fidanza 8lbs. Flywheel - Exedy Cerametallic Stage 2 Clutch - DC5R Emblems - DC5R Rear Wing - DC5R Carbon Fiber Front Lip - DC5R Headlights - DC5R Shift Knob and Boot - XenonDepot 5000K HID Kit - Acura OEM Body Kit - ViS Carbon Fiber Hood - ClubRSX Shifter Bushings - Hurst Import Car Custom Bored-Out Throttle Body - Progress Front and Rear Sway Bars - Eibach Pro-Kit Springs - 5Zigen FN01R-C 17x7 - Yokohama AVS ES100 225/45/ZR17 - Wilwood Big Brake Kit - PowerSlot Rear Slotted Rotors
Feb 23, 2002 - Nov 4, 2004
DatFooWitThaRSX is offline   Reply With Quote
Old 10-17-2004, 12:00 AM   #6
doreamon_snatch
Monkey Magic
doreamon_snatch's Avatar
doreamon_snatch is an unknown quantity on c-rsx
ive had the same problem. are any of you running with OBDII disabled? All I did was turn off the PO134 02 sensor response. I havent gotten the CEL since...the wierd thing is that I was getting the same code but a diff. explenation on the KPRO...I got the error 02 Heater Sensor Error or some shit.
Engine: AEM CAI, Type-R Header, Spoon 2-1 Downpipe, Apex-i N1 Catback, Nology Hotwires
EMS: Hondata KPro
Suspension: Toda 25mm Front Swaybar, Progress 22mm Rear Swaybar, Comptech Sport Springs
Looks: Integra Rear Badge, EP3 Wheels
Misc.: Neuspeed Short Shifter Adapter
Paperweights: Type-R Intake Manifold, Toda Valve Springs, Hondata Intake Manifold Gasket, Toda N2 Cams
doreamon_snatch is offline   Reply With Quote
Old 10-17-2004, 01:29 AM   #7
DavidT
Senior Member
DavidT is an unknown quantity on c-rsx
I get the P1166 code which is primary o2 heater circuit problem...it keeps coming on and off. Will come on for the first 10 or so miles and go away...come on later in the day and go away the next... ? It seems after the computer runs the O2 monitor the 2nd time around it turns off the check engine light. My front o2 also has no readings when the P1166 code is on, but will give readings again once the check eng light goes away.
I've also gotten P0134 once, but I reset my ECU and it hasn't come on since; that was like two months ago. My dash is like a freak'n blinking christmas tree with all the damn lights going on and off
DavidT is offline   Reply With Quote
Old 10-17-2004, 08:27 AM   #8
doreamon_snatch
Monkey Magic
you have the kpro? if so just disble PO134. after i disabled it, i havent had a problem with the primary02 sensor heater circuit error comming back. BTW what are your mods?
EMS: Hondata KPro
Old 10-17-2004, 08:41 AM   #9
ares650
Member
ares650's Avatar
I have the OBDII disabled, but not the P0134. But I don't understand cause, right now I have the stock cat and exhaust.
Old 10-17-2004, 08:48 AM   #10
doreamon_snatch
Monkey Magic
I think it has something to do with OBDII for some reason b/c I only started getting the P0134 error after I disabled OBDII. I simply just disabled the error on the KPRO.
EMS: Hondata KPro
Old 10-17-2004, 11:41 AM   #11
teamxrsx
K series tuning liberator
teamxrsx's Avatar
teamxrsx is an unknown quantity on c-rsx
If you dis-able OBDII functions, you will have to disable the po134 O2S heater response in k-pro. This stops the ECU from running a sensor check on both O2S'. You will notice that when the P0134 DTC pops up, the primary o2S will stop responding completly.
To stop this check process the ECU is running, you must disable po134 as stated above. You will not see this DTC pop up again.
CJ
Originally Posted by clubrsx.com member
I admire you for raising the BS flag on CN and pointing those of us that care in the right direction!
Just wanted to say hi, and give a big thank you!
Dyno Tuner @ Velocity Trends in Jacksonville. If you need some tuning, hit me up!
A.K.A. iTune in the Mistubishi Evolution camp
teamxrsx is offline   Reply With Quote
Old 10-17-2004, 12:36 PM   #12
doreamon_snatch
Monkey Magic
CJ
Thats what I figured but just didnt know for sure. Thanks
EMS: Hondata KPro
Old 10-17-2004, 03:00 PM   #13
teamxrsx
teamxrsx's Avatar
NP
CJ
Old 10-17-2004, 03:43 PM   #14
rsxmachine
Sold July '08
rsxmachine is an unknown quantity on c-rsx
P0134 is a problem with the 1st sensor not responding. here's what I posted in your H-T thread
P0134 is
Air Fuel Ratio (A/F) Sensor (Sensor 1) No Activity Detected
or
Air Fuel Ratio (A/F) Sensor (Sensor 1) Signal Stuck Lean
service manual basically says to check the connection/wiring and reset the ECU. if the code keeps coming back, replace the A/F sensor.
rsxmachine is offline   Reply With Quote
Old 10-17-2004, 03:57 PM   #15
teamxrsx
teamxrsx's Avatar
P0134 is
or
Correct, but when you disable OBDII functions in the k-pro(which is a modified stock ECU), this problem points to a set of checks a balances the ECU carries out to check if both sensors are working. When OBDII functions are disabled, the ECU will see this and realize the secondary O2S is not working(because you manually disabled it), at this time it will throw the P0134 DTC. The primary O2S stops dead in it's tracks as well.
This does not mean you need a new 02S(in the this case, using the k-pro with OBDII functions disabled). This means that the "disable P0134" function is not enabled and the ECU is still running the 02S checks. To solve this simple problem, you must enable the "disable P0134" function to keep the ECU from running the O2S checks. Your primary 02S will not stop responding from this point forward and there will be no more P0134 DTC's because this ECU test will no longer run. If your primary 02S does stop responding no matter what you do, then check wiring and/or replace 02S as needed.
Old 10-17-2004, 07:05 PM   #16
ares650
Member
ares650's Avatar
So if I would uncheck the OBDII, then I shouldn't have anymore problems, right. When I put in my test pipe with 3in exhuast then I should disable the OBDII and P0134, right.
Old 10-17-2004, 09:16 PM   #17
teamxrsx
teamxrsx's Avatar
Correct......if you have OBDII functions still enabled, none of this matters. But, if you disable OBDII functions, disable P0134 as well.
CJ
Old 10-18-2004, 06:59 AM   #18
ares650
Member
ares650's Avatar
CJ
Cool, Thanks everyone. I will try this
Old 10-19-2004, 09:25 AM   #19
ares650
Member
ares650's Avatar
yup, I think that solved the issue...two days and going
Old 10-19-2004, 05:53 PM   #20
teamxrsx
teamxrsx's Avatar
Great! Nice and simple.
Old 11-01-2004, 08:11 AM   #21
ares650
Member
ares650's Avatar
Thumbs down
I did as you said and the error has come back twice since my last post, what do you think of that?
Old 11-01-2004, 03:58 PM   #22
teamxrsx
teamxrsx's Avatar
well, i can attest that this worked for many of our k-pro friends, including me.
Like i said before, "If your primary 02S does stop responding no matter what you do, then check wiring and/or replace 02S as needed." This may be a situation where the O2S is actually bad, or a loose connection. Check wiring, reset ECU and if it keeps happening, even with P0134 disabled, take it to a acura tech and have them look at it and/or replace the O2S. This would be my take on the situation.
Check those things and let us know what you come up with.
CJ
Old 12-18-2004, 08:11 AM   #23
TheSilverBullet
Speedy
TheSilverBullet's Avatar
TheSilverBullet has been a little shit in the past
i had an exhuast leak from my dcrh and was getting the idle, code and noise problems...
http://forums.clubrsx.com/showthread.php?t=221068
2010 g37
2007 SilverStone S2K w/ flashpro, 70mm Berk 3" TP Headerback, AEM V3 cai, JVT header, T1R-Ti ball, CDV delete.
2007 CR-V 4WD EX-L, 2003 S10HyperTech
2002 SatinSilver RSX-S /i/e/rh/kpro/enjo/ss
2002 DesertSilver RSX AUTO Leather
TheSilverBullet is offline   Reply With Quote
Reply
Bookmarks
code , error , p0134
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2012, Club RSX, Inc. All rights reserved worldwide.
