Frankenstein K24a1(*CRV) + Type-S Head K20a2 - Club RSX Message Board
Go Back   Club RSX Message Board > ADVANCED PERFORMANCE > K-Series Swaps
Notices
Reply
Thread Tools
Old 06-20-2005, 04:45 PM   #1
MT72
my friend the hustler
MT72's Avatar
MT72 is an unknown quantity on c-rsx
Exclamation Frankenstein K24a1(*CRV) + Type-S Head K20a2
Anybody as info on this swap into rsx
I am putting together the most info possible to build the perfect set up for this swap I already spoke to Brian Crower here's the scoop :
Go .5mm on the valves (int and exh).
CP offers an 87mm bore shelf, you can sleeve up to 91mm on a street
application. 12.5:1 is a good comp ratio.
300 HP is possible with proper tuning. Kpro ...
Any sugestions for this non turbo set-up !!!!
Hit Me Back
T
MT72 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-20-2005, 10:15 PM   #2
inmys2k
Hellooo
inmys2k's Avatar
inmys2k has a clean start inmys2k has a clean start inmys2k has a clean start
wow, that sounds amazing, good luck bro =)
inmys2k is offline   Reply With Quote
Old 06-21-2005, 07:59 PM   #3
silvrsx04
DC5 User
silvrsx04's Avatar
silvrsx04 is an unknown quantity on c-rsx
so its basically a 2.4 liter RSX
very nice
sigs gone..
booo
silvrsx04 is offline   Reply With Quote
Old 06-21-2005, 10:44 PM   #4
MT72
MT72's Avatar
Lightbulb cranshaft for K24a1
2.4 L base engine totaly machined with CP pistons and Type S head ported
I will get you some pics soon this week end !!! I got my clutch Exedy Today with 9 and flywhell this will rock ....
Anyone has ever work with custom cranshaft for K24a1
Old 06-22-2005, 12:43 PM   #5
hondaluver
Bar'd TWICE
hondaluver's Avatar
hondaluver is an unknown quantity on c-rsx
i wish i had the money to upgrade my internals, i will soon enough tho, you will no doubt make 300 with bolt ons and a good tune, get some ips cams as well for your allmotor app
01 SSM em2 built turbo k24 bar'd twice. Old 10:1 NA tune...240.7 hp and 190.9 tq. C38-91 Rotrex build FS Thread
09 Toyota Pruis Full Loaded(Navi and leather) rolling @48.6mpg
hondaluver is offline   Reply With Quote
Old 07-06-2005, 05:39 PM   #6
MT72
MT72's Avatar
engine Support
Anyone as a RSX with k24a1 in it if yes doe the k24a1 fit directly under the hood or we need hassport mounts to fit it
thanks !
Old 07-06-2005, 06:05 PM   #7
silvrsx04
DC5 User
silvrsx04's Avatar
im pretty sure u need the hasport mounts
sigs gone..
booo
Old 07-06-2005, 06:15 PM   #8
Glimpse
Don't TILT
Glimpse's Avatar
Glimpse is an unknown quantity on c-rsx
thanks !
Stock mounts, with a CRV passenger side mount (or custom spacer on the existing passenger side mount). This was discussed recently.
2003 NBP A-Spec Type S
Injen: CAI Hayame: Exhaust Toda: Race Header, Valve Springs, Headgasket, N2 Cams, Front Swaybar Skunk2: SS Valves, Ti Retainers Energy Suspension: MM Bushings Hondata: IMG, K-Pro Unorthodox Racing: Ultra SS Pulleys JDM: ITR IM, ITR FD CRSX: Shift Bushings Exedy: Organic Clutch, Flywheel Quaife: LSD StopTech: BBK PowerSlot: Rear Rotors Techna Fit: SS Lines AXXIS: Metal Master Pads Motul: RBF 600 Xenon Depot: 5000k HID Spoon: Drain Bolts Grillcraft: Lower Grill
I love Pink Rsx
Glimpse is offline   Reply With Quote
Old 07-07-2005, 07:17 PM   #9
MT72
MT72's Avatar
Talking ok thanks here's a quick look of my set up
K20a2 (type-s head ) :
Port & Polish
Crower stage 2: 3/4 Race Cams
Crower Stainless Steel Valves: Exhaust (30.5mm)
Crower Stainless Steel Valves: Intake (35.5mm)
Crower Valve Springs & Titanium Retainers
DC Sport Racing Headers
ITB TWM 50 MM
660 CC injector
Hondata Gasket
K-pro
K24a1 (CRV Base )
Machined block
Crower Maxi-Light Rods: K24
CP Pistons 12:5 -1
Tranny 6 speed RSX
Exedy Organic Clutch
Exedy Light Weight Racing Flywheel
ATS healical limited slip LSD
Buddy Club 2 Spoilers Kit
Give me some feedbacks guys ....
Old 07-07-2005, 07:40 PM   #10
typeS 04
IV ACE
typeS 04's Avatar
typeS 04 is an unknown quantity on c-rsx
why aren't you using the type R tranny?
typeS 04 is offline   Reply With Quote
Old 07-07-2005, 08:20 PM   #11
mavi DC5
x type-s club
mavi DC5's Avatar
mavi DC5 is an unknown quantity on c-rsx
or type s 6 speed tranny?
2008 335i E90
mavi DC5 is offline   Reply With Quote
Old 07-07-2005, 09:41 PM   #12
Sam'sRSX
I LOVE MY ITR TRANNY!!!
Sam'sRSX is an unknown quantity on c-rsx
The gears are too short for that setup. I just bought a type R tranny off a guy with a k24a2 and k20aR head swap in his civic hatch b/c he wanted my stock type s 6 speed. He said he had to launch in second gear at the track and still lost traction in 3rd.
You made the right choice, although I might have wanted the six speed, the five speed is perfect for dragging.
FS:2002 firepepper red rsx-s
FS: Type R Tranny, Exedy Stage 1 Racing Clutch
Car is being parted out! http://forums.clubrsx.com/showthread.php?t=306690
Asking $15,500 in stock trim
FS: JL amp kit (4 gauge) and monster cable xln wires $50 shipped
Sam'sRSX is offline   Reply With Quote
Old 07-08-2005, 08:16 AM   #13
MT72
MT72's Avatar
your Right
I consider getting the type R limited slip LSD .... Anyone as contacts in Japan ?
Old 07-08-2005, 09:27 PM   #14
coolguy
Senior Member
coolguy's Avatar
coolguy is an unknown quantity on c-rsx
I do.. but getting them new is like around $800... may as well get a quaife, shop around I got mine for under 400 (used)
coolguy is offline   Reply With Quote
Old 07-09-2005, 02:43 PM   #15
MT72
MT72's Avatar
Can you check it out 4 me because in Montreal there's no used parts for Quaife
Email me if you see any used one tommyboylol@hotmail.com
T
Old 07-14-2005, 08:27 AM   #16
MT72
MT72's Avatar
ttt
this how bad it's going to be
http://i22.photobucket.com/albums/b3...r/IMG_1124.jpg
Old 07-14-2005, 08:16 PM   #17
blaznazn
will be K20/24 in 07
blaznazn's Avatar
blaznazn is an unknown quantity on c-rsx
what ecu program would you use for this? IM assuming k-pro but is there any alternative other then k-pro?
Im Azn, Im obligated to drive a Honda/Acura.
2004 NHB Rsx-S
Slower then stock, with minor mods.
K24a1 rydah!
blaznazn is offline   Reply With Quote
Old 07-15-2005, 03:56 PM   #18
MT72
MT72's Avatar
Arrow
no k-pro seems to be the most interesting alternative
ttt
Old 07-16-2005, 03:33 AM   #19
civictype-s
fvck turbo's
civictype-s's Avatar
civictype-s is an unknown quantity on c-rsx
nice set up. i will be pretty similar to you. 87.5 mm CP pistons, pauter rods and IPS cams with all the goods. i hope you dont plan on running that daily though. 12.5:1 compression is way high. especially in cali where we only get 91 octane pump gas. i went with 11.5:1 compression. should be done in the next 2 weeks or so.
Good luck and definately post some numbers.
civictype-s is offline   Reply With Quote
Old 07-31-2005, 08:21 PM   #20
MT72
MT72's Avatar
Talking Ok here it goes
EXEDY """
Crowers CAM """
ROD MAXI LIGHT
VALVE """
DC RACING HEADER 421
PISTON CP 12:5:1
Old 08-01-2005, 03:02 AM   #21
hondaluver
Bar'd TWICE
hondaluver's Avatar
isthis ur daily driver? god, this set up looks so so sexy
Old 08-01-2005, 10:04 AM   #22
Glimpse
Don't TILT
Glimpse's Avatar
Pretty sweet. I hope those are stage 3 cams. You will be running into some breathing issues, regardless.
I love Pink Rsx
Old 08-01-2005, 10:11 AM   #23
STLuNaTiC_v34
Master Member
STLuNaTiC_v34's Avatar
STLuNaTiC_v34 is on a distinguished road
Holy damn!! Well, good luck with that...
ABP Crew Member #34
2004 ABP Acura RSX Type-S
2004 Black MR2 Spyder
http://stlunatic.myminicity.com/
STLuNaTiC_v34 is offline   Reply With Quote
Old 08-01-2005, 05:39 PM   #24
MT72
MT72's Avatar
Thanks Guys actually yes it's daily car everyday drive... I will post the dyno result in month or so !
Old 08-01-2005, 08:45 PM   #25
PapiTuyo326
Billy Ball is in effect
PapiTuyo326's Avatar
PapiTuyo326 is on a distinguished road PapiTuyo326 is on a distinguished road PapiTuyo326 is on a distinguished road
VERY nice
Keep us posted with information. Close to 300 hp n/a would be awesome.
-Dave aka Amos
2003 Ep3 - K24A1/K20Z3 - Spoon Certified - Out of Commission
2001 S2000 - Stock and loving it
1987 GN T-Type WE4 - The BEAST
K24 Swapped since 05
PapiTuyo326 is offline   Reply With Quote
Reply
Bookmarks
frankenstein , head , k20a2 , k24a1crv , types
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
