Old 07-01-2005, 09:30 AM   #1
Dubs03RSX
Master Member
Dubs03RSX's Avatar
Coilover gurus help needed!
Ok here I am with no upgrade on suspension! I need some that look good and dont kill me on the street. I do soooo much more drag racing than any left left left (hahaha) drivxing. What coilovers will make me happy. The new omnis look good for me but they dont have the same hookup on them like they do for the civics and dc2s. I am at a standstill. Any mix and match ideas? Any ideas? Help a man out!
95 Civic ex coupe Stolen - 03 NBP RSX on Works GONE - 85 Mazda GLC Lx SOLD
04 WRB STi 300+whp 315+wtq GONE 85 AE86gtsr5 SOLD
05 S2K "the new hawtness"
89 VW Fox wagon
Dubs03RSX is offline   Reply With Quote
Old 07-01-2005, 10:28 AM   #2
robbclark1
My sex is on fire!
robbclark1's Avatar
If you are serious about drag, I would get some Teins with custom high rate rear springs (~800lbs) with normal front ones. High rear springs will help launch faster.
If not, just stick with Tein SS or Omni. I know there are a few others for the DC5 but I am not too well educated on them.
Coilovers - Koni Yellow with GC (400/550): Sways - 25.4mm front, Progress 24mm rear: Strut bars - took the fucking things off!: Bushings - ES front and rear poly: Brakes - ATE Superblue brake/clutch fluid: Camber - SPC camber kit: Race rims - 15x7 Kosei K-1 powdercoated black wrapped in Falken Azenis: Shifter - OBX
robbclark1 is offline   Reply With Quote
Old 07-01-2005, 10:30 AM   #3
wowitztai
13.60's all motor
wowitztai's Avatar
i drag race more..i bet.hehe friday saturday and sunday until 4 in the morngng..none stop
03SSM Rsx powered by hondata
wowitztai is offline   Reply With Quote
Old 07-01-2005, 10:50 AM   #4
Dubs03RSX
Master Member
Dubs03RSX's Avatar
what are you using to keep your car lower? Anyone try the new omni's on their car?
89 VW Fox wagon
Old 07-01-2005, 12:36 PM   #5
WhiZ
N/A to go please...
WhiZ's Avatar
I've been extremely happy with my Megan's and their customer service is first-rate (i.e. zop_type_s.)
As well, when I went drag racing, I was able to play with the dampening and see what helped with my launches.
Peace
WhiZ
'03 ABP RSX Type-S
Go: - Hondata K-Pro running ITR cal , PRC IM, ITR cams, Hondata IMG, Injen CAI, JRRH w/test pipe, Greddy SP2, DIY Grounds
Show and Suspension: - Megan Coilovers, JDM ITR 22mm Rear Sway, Ingalls rear camber kit, 17" SSR Comps w/ 225/45/17 General Exclaim UHPs, Revo ShortShifter (w/ metal bushings), Speed-Source Shifter bushings, Injen IM Cover, Mr. Alex TD, Wilwood BBK
Latest dyno.... SAE 143.6 ft-lbs and 203.4 peak whp
Best 1/4 mile... 13.974 @ 100.91mph with a 2.257 60'
WhiZ is offline   Reply With Quote
Old 07-02-2005, 12:49 AM   #6
KwonBoA
Flyin' Without Wings
what i suggest is check out how your road condition is. if you want streetable that won't be a pain. determine how is your stock shocks feels: is it really comfortable and such. after that look at the coilovers of other company. the spring rate is what you should look at when determine how it going to ride on the street. compare it to stock and you can get an estimate on how harsh it will be.
what you should also look for is how much you want to spend and how adjustable the coilovers are. do you want to be able to control height, adjust dampening rate and adjust camber. their is a thread on spring rates for coilovers. it has a pretty good list of coilovers and their spring rates. if you can run stiffer coilovers because your roads are good then i would suggest higher spring rates.
i also suggest you to upgrade your tires and maybe get strut bars.
Blue Charisma..
KwonBoA is offline   Reply With Quote
Old 07-03-2005, 09:52 PM   #7
sosojeff
Apex Assasin
sosojeff's Avatar
just get springs with shocks
2003 SSM Type-S & 2002 Audi S4
stock.....looking
Who the hell said you have to have JDM to be cool? I think all the people who jump on the JDM bandwagon and think they're cool because of it are nothing but secondary ricers
sosojeff is offline   Reply With Quote
Old 07-04-2005, 03:45 PM   #8
Dubs03RSX
Master Member
Dubs03RSX's Avatar
hmmm thanks +rep for you kwoa
89 VW Fox wagon
Reply
Bookmarks
coilover, gurus, needed
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
