#1 |
Modificato
DC Race Header Check Engine Light
I went to autozone and had the light checked out. It said, " O2 Sensor no activity (bank 1 sensor 1). As I posted in a different thread, I used the anti-fouler trick, do you think I should bore it out a little more, since it is getting absolutely no reading? I don't think the 02 Sensor is damaged, since the light goes on and off, so maybe it is simply loose? Anyone's help would be appreciated.
-Caesar
03 SS Acura RSX-S: AEM CAI, Borla Cat Back Exhaust, Hondata-4, Hondata Intake Manifold Gasket, DC Stainless Steel Racing Header (Brushed), Comptech Sport Springs w/rear Ingall camber kit, Energy Suspension Motor Mounts, DIY Ground Wires, Type R Spoiler, JDM side markers, Satin Silver Painted Stock Grills, Exedy Stage 1 Clutch Last edited by FormidableRSX; 07-24-2005 at 04:33 PM. |
#2 | |
Central PA AMSOIL dealer
FS: 05-06 PRB intake manifold FS: 05-06 TypeS throttle body |
#3 | |
Senior Member
#5 | |
oh no you di'int!
2005 wrb wrx | 1/16/8 - 2002 ssm rsx-s | 6/25/3 - 11/23/7 "Has anyone really been far even as decided to use even go want to do look more like?" NY Jets: 11-8
#7 | |
Modificato
03 SS Acura RSX-S: AEM CAI, Borla Cat Back Exhaust, Hondata-4, Hondata Intake Manifold Gasket, DC Stainless Steel Racing Header (Brushed), Comptech Sport Springs w/rear Ingall camber kit, Energy Suspension Motor Mounts, DIY Ground Wires, Type R Spoiler, JDM side markers, Satin Silver Painted Stock Grills, Exedy Stage 1 Clutch |
#8 | |
Modificato
Hmmmm....interesting. Thanks you helped narrow down the problem. Fuck, I hope I didn't screw it up.
#9 | |
hondata'd
-jared
02 rsx-s satin silver-past 05 s2000 blk/blk-present |
#10 | |
2WD to 4WD
You treat your car like your girlfriend...Tender loving care along with giving her some WOT
#13 |
Central PA's Finest...
pep boys, auto zone, advanced auto...the list goes on...
#15 |
713
your primary is fucked. either ur connector for the primary is not connected or loose or its burnt out. i had mine burnt out, dealer replaced it b/c i found a dealer where they dont care about mods. the o2 sim u made is actually working correctly on the 2nd o2 sensor, be happy about that, but a busted primary is expensive to replace.
i have no CELs now (knock on wood)
st00pified and Kpro'd RSX Base Auto w/ IPT Race Trans 260+whp/235+wtq 2010 BMW 335d w/ Sport Package
#16 | |
Master Member
Engine Mods: Injen CAI, Energy Suspension Motor Mounts, DCRH, KPRO w/ a st00pid tune http://i3.photobucket.com/albums/y71...resisedsig.jpg Best 1/4 time w/CAI: 14.83 @94mph 2.25 60ft Best 1/4 time w/ bald ass tires CAI, ESMM DCRH, tuned kpro : 14.15 @102, 2.3 60ft MY CAR IS BI POLAR |
#17 |
Modificato
I had some guy look at it really fast, cuz i've been so damn busy and haven't had time to seriously look at it. He said my rear O2 sensor is hitting the body and probably loosening it or maybe has damaged it. I'll take it somewhere to check it out. I just don't have time to fully inspect it myself. Thank god for clubrsx!!!
#21 | |
Master Member
#22 |
Member
no problem
they will come in a back of two for like $5... labled 19mm i think. drill one out to 1/2 inch bore, fit your o2 into that one. then screw the nonbored one on the end of the bored one, and swrew the asembly in the cat. there is a good post with photo's here somewhere. do a search for "spark plug non-fowler"
05'-S Injen CAI, DCRH, Greddy SP |
| Bookmarks |
| Tags |
| check, engine, header, light, race |
| Thread Tools | |
