#1 |
S*O*V*A
Hondata #4 reflash and "box" type intakes (Comptech or Mugen)
I've been thinking of switching from my V2 to either the icebox or Mugen airbox and have been reading a little about a "power dip" when running either of these with the #4 reflash. Right now, I love the way the reflash mates up to my V2... I put down the numbers in my sig with only these two mods on a hot and humid day, which was fine by me. Now, I may switch to either the Comptech or Mugen just because I want to try it out. The V2 sounds good, but it is just a little on the louder side for me.
Just wondering what kind of power changes I should expect... and I'm especially interested in any power dip around 5000 rpms which I've heard about. If someone has run this combo, great. If someone has dyno'ed these two together, that'd be even better. And no... I'm not considering the CAI route even though I know they perform better.
2007 Alpine White BMW 335i w/sport package |
#2 | |
ECU Tuner
Mods: Stage 3 Comptech SC, AEM CAI, Comptech street header, stock cat, modified stock injectors, Hondata K-Pro, Hondata IMG, Fujitsubo PG catback, cat, 225/45-17 Falken Azenis RT-615 on Kazera rims, Mugen SS, Quaife LSD, CT lightweight flywheel and street clutch, ACT heavy-duty pressure plate, CT rear sway/tie bar and titanium front strut brace, Type-R replica wing, CT short shifter, Auto Meter Sport Comp full-sweep boost gauge. Current results: 290 whp on DynaPack. Web: My RSX and K-Pro page. My Blog: ECU Tuning |
#4 |
S*O*V*A
Conrad, thanks for posting the dyno overlays. I notice a few things that are interesting. First, it looks that the icebox + Hondata #4 combo only gained you about 8whp over stock at the peak, although the midrange you gained about 16-18whp (which is very nice). The CAI + K-Pro however looks like you got about a 24whp gain in the mid and close to a 16whp gain peak over stock. Were you running the preloaded CAI cal when you had the K-Pro and CAI only or was that a full tune?
Man, I do need to get K-Pro at some point! Anyway, I would guess that the Comptech or Mugen box would add comparable numbers to my V2 when mated with my Hondata #4. That I would be okay with. The dip in HP is definitely there on the graph... but was it enough to be noticeable when driving? It looks like the dip is immediately before VTEC engages with the #4 reflash, so maybe that had something to do with it?
#5 | |
Master Member
Also, keep in mind that the Icebox will give you colder air than the V2. |
#6 | ||
ECU Tuner
You did notice the large midrange gain, and that is really the most beneficial aspect of Hondata. The lowered VTEC, combined with a good tune, totally transforms the car in everyday driving. There is just so much more torque. As for VTEC points, you probably noticed the black dots on each of the runs. Those are the VTEC points. Quote:
#7 |
S*O*V*A
Gotcha.
Yeah, Hondata #4 really makes quite a difference in the midrange, there is no doubt at all about that. I remember (as all of us probably do) the first time I installed the reflash and took it on the road for a test. I don't want to run a less than optimal system in having the icebox and reflash. Well, I guess I already am because I have Hondata mated to a V2 and not to a true CAI. But I'm thinking that rather than switching intakes, I might just go ahead and get K-Pro and see what I can extract out of my current mods. Then I can get the icebox or Mugen box and tune out any anomalies in my power curve. I'm adding the comptech street header tomorrow.
#8 | |
S*O*V*A
#9 | |
Master Member
Yeah, definitely do the K-pro. Then you really get to see the difference in IATs. |
#10 | |
ECU Tuner
#11 | |
S*O*V*A
I'll post up when I get it all done. And then I'll get K-Pro
| Bookmarks |
| Tags |
| box, comptech, hondata, intakes, mugen, reflash, type |
| Thread Tools | |
