DIY JDM sidemarkers complete installation guide with pics - Club RSX Message Board
Notices
Reply
Thread Tools
Old 08-21-2005, 08:57 PM   #1
Gatekeeper
Master Member
Gatekeeper is an unknown quantity on c-rsx
First off, I would like to thank KevinG for helping out with this install. The time that it took us for this install was roughly around 5 hours, simply because we took our time and did everything the right way.
The tools/supplies that you will need are:
-Flathead screwdriver
-Phillips screwdriver
-Masking tape
-xacto knife/razor
-String
-Sidemarker template
-Dremel with numerous cutting wheels and grinding attachment
-Touch up primer
-Touch up paint
-12' of wire
-wire taps (8)
-wire cutters
-wire strippers
-tie straps (6)
First step is to jack up the car and remove the wheel. Next take off the Phillips head screws and plastic clips holding the fender liner in place.
Next step is to apply masking tape in the area you will be cutting the hole and then pull a string on the curved part of the body from the door across to the front fender. Then put the correct side template over the sting and attach with tape.
After everything is lined up with the body line and fender line, trace the opening with a pencil and it should look like this:
2003 Acura RSX Type S
F.S. rear back seat, leather, in black
Gatekeeper is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-21-2005, 08:58 PM   #2
Gatekeeper
Master Member
Now that everything is marked, the scary part is coming up, cutting into your fender. You will need the dremel and cutting wheels for this. No drill is required, just start out by cutting a square hole and then making numerous relief cuts to get the desired lengths for the notches and curves.
Now that everything is cut out, test fit the sidemarker to make sure the opening is correct and then start applying the primer (2 coats) and then touch up paint (2 coats)
It should look like this when done
Old 08-21-2005, 09:03 PM   #3
Gatekeeper
Master Member
Now that the holes are cut out and ready for the sidemarkers, its time to start with the wiring. Cut off the connector that comes on the sidemarker wiring and attach a 3' piece of wire to each wire using wire taps. Once this is done you can start running the wires in the car body. You will see another hole up in the body and this is where you start running the wires, then find the hole in the pic and pull the wires down through there.
Once you put the grommet into the body, it should look like this.
Now use the tie straps the attach the wires to the hood release cable or another wire and route the wires into the engine and tap them into the turn signal wiring
Test out that the blinkers work with the sidemarker lights before you put everything back together on the car.
Old 08-21-2005, 09:05 PM   #4
AkumaMax
Team-Integra.net
AkumaMax is an unknown quantity on c-rsx
Nice writeup!
Mess With The Max, Get Scrapped Like The Rest!
www.Team-Integra.net (All Integra All The Time)
http://img38.exs.cx/img38/5763/akumamaxavatar0ji.jpg
AkumaMax is offline   Reply With Quote
Old 08-21-2005, 09:09 PM   #5
STLuNaTiC_v34
Master Member
STLuNaTiC_v34's Avatar
STLuNaTiC_v34 is on a distinguished road
Awesome! +rep
ABP Crew Member #34
2004 ABP Acura RSX Type-S
2004 Black MR2 Spyder
http://stlunatic.myminicity.com/
STLuNaTiC_v34 is offline   Reply With Quote
Old 08-21-2005, 09:10 PM   #6
1TZ JENN
Truth doesnt make a noise
1TZ JENN's Avatar
1TZ JENN is an unknown quantity on c-rsx
awwww. i know your happy
Do you honestly believe that I donít have a plan B? And if that fails a plan C and a plan D. You know how the alphabet works donít you?
1TZ JENN is offline   Reply With Quote
Old 08-21-2005, 09:18 PM   #7
KevinG
O.G. '02 RSX-S
KevinG's Avatar
KevinG is an unknown quantity on c-rsx
One more pic.
Car all put together with finished product
Click image for larger version
motorcycle crew # Infinity
2002 Acura RSX-S
1969 Corvette Stingray
KevinG is offline   Reply With Quote
Old 08-22-2005, 01:37 AM   #8
travanx
Master Member
travanx's Avatar
travanx is an unknown quantity on c-rsx
which wheels did you use to cut out the fender? i want to do this mod on tuesday. nice writeup btw.
'95 Porsche Carrera 911
Recaro Speed Seat, Wedge Engineering Bracket
18" Work Brombacher in Dark Gold/Polished Lip
KW V3 Coilovers
Stage1 Exhaust Mod with Pretty Tips
travanx is offline   Reply With Quote
Old 08-22-2005, 01:51 AM   #9
asainjnco
.wow.
asainjnco's Avatar
asainjnco is an unknown quantity on c-rsx
Good job, wouldn't do that myself. I would be too scared! lol +rep
[center]
--05 Black CBR600RR--
asainjnco is offline   Reply With Quote
Old 08-22-2005, 02:07 AM   #10
StcPremium
New Member
StcPremium is an unknown quantity on c-rsx
holy shit im scared to do that myself too man if i could rep you i would for having enough balls to cut into your fenders
StcPremium is offline   Reply With Quote
Old 08-22-2005, 11:12 AM   #11
KevinG
O.G. '02 RSX-S
KevinG's Avatar
The fiberglass cutting wheels that come in the tube of ~50. You will go through about 10 since they wear down pretty quick.
2002 Acura RSX-S
Old 08-22-2005, 11:41 AM   #12
bluej511
Name's Vic
bluej511's Avatar
bluej511 is a hardcore rep whore
bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore
kevin where the hell is there a pic of u helping out lol nice DIY
Armenian crsx crew member #6
02' RSX-S 179k mi, 14.5 @97. Sold after 12years.
13' Trek Madone 5.2. 2012 Swift Sport
bluej511 is offline   Reply With Quote
Old 08-22-2005, 01:14 PM   #13
dbradfordii
Respectable buyer.
dbradfordii's Avatar
dbradfordii is an unknown quantity on c-rsx
Hey when is the next time yall meeting up?
Originally Posted by PCconcepts
quoted for truth
Originally Posted by It's Turtle
should i put down my mouse first or my dick?
Sell me a cwest n-2 front bumper for a good price somebody.
dbradfordii is offline   Reply With Quote
Old 08-22-2005, 01:16 PM   #14
dbradfordii
Respectable buyer.
oh yeah who is going to Nopi nationals in atlanta ga? Me and my team are going next month and we are gonna roll with the super street tour. it would be tight to have some more rsx from this area to roll wit us.
hit me up
quoted for truth
Old 08-22-2005, 03:10 PM   #15
CharmaneStar
Hello
CharmaneStar's Avatar
CharmaneStar is an unknown quantity on c-rsx
FIrst off, NICE write up. This is quality information and pictures. Question(s) though:
1)When u turn the first click on lights, does it light up side marks + wedge bulbs?
2)WHen u turn on headlights, do the sidemarkers stay lit? Or does it only light up when u hit your turn signals?
Tera P
CharmaneStar is offline   Reply With Quote
Old 08-22-2005, 03:26 PM   #16
Gary Waller
Now rollin' 6MT GDurtay5
Gary Waller's Avatar
Gary Waller is an unknown quantity on c-rsx
not bad.
i have them on mine too
Back to a G. lol
Sunglasses F/S:
http://forums.clubrsx.com/showthread.php?t=605794
iPod Shuffle F/S:
http://forums.clubrsx.com/showthread.php?t=606746
Gary Waller is offline   Reply With Quote
Old 08-22-2005, 03:26 PM   #17
soccerman002
Fix it 'til it's broken
soccerman002's Avatar
soccerman002 is an unknown quantity on c-rsx
Get the heavier duty ones, sold in packs of 6 I believe. They last A LOT longer than the lower-grade wheels.
SOLD: 2002 ABP Acura RSX Type-S - 244.5whp, 180wtq
NEW PROJECT: 1999 Mustang SVT Cobra - 4.6L DOHC V8 - 320hp, 317tq
DAILY: 2008 Dodge Ram 1500 Quad Cab Big Horn - 4.7L Magnum V8 w/Flex Fuel - 310hp, 330tq
soccerman002 is offline   Reply With Quote
Old 08-22-2005, 03:33 PM   #18
KevinG
O.G. '02 RSX-S
KevinG's Avatar
Tera P
1.) Yes, when you first click on the turn signals, they come on with each blink thats in the headlight.
2.) No, the sidemarkers do not stay on. I did not get around to testing the wiring, but my guess is if you want that, you would put the negative wire to the parking lights and positive to the turn signals? I connected them to the turn signal wiring only.
2002 Acura RSX-S
Old 08-23-2005, 07:06 AM   #19
dlim4381
임다니엘
dlim4381's Avatar
dlim4381 is an unknown quantity on c-rsx
Nice write up.
2003 Satin Silver RSX-Type S
AEM V2 Intake | DC sports 4-1 Stainless Steel Header | Greddy Evo2 Catback Exhaust | Revo Short Shifter | Type-R JDM Shift Knob | StopTech Slotted Rotors | Type-R Spoiler | Rear JDM Sway Bar | Hondata IMG | Neuspeed X-Brace | Neuspeed Front & Rear Strut Bars | Mugen SS | 225/45WR-17 on Tenzo RS-5 17x7" Gun Metal Rims | Clear Bra & Tint | Pioneer AVIC-N4 w/CDX| MTX Audio Thunder & Eclipse Amps | 2 JL 10' Subs |
dlim4381 is offline   Reply With Quote
Old 08-23-2005, 11:21 AM   #20
captainobvious
Headwinds...giggity....
captainobvious's Avatar
captainobvious is an unknown quantity on c-rsx
nice writeup, looks good!
2003 SSM Acura RSX Type-S
Nikon D300 Shooter
captainobvious is offline   Reply With Quote
Old 08-23-2005, 04:20 PM   #21
gdubb05
blackrsx-s
gdubb05's Avatar
gdubb05 is an unknown quantity on c-rsx
you make it look so easy, +rep
Engine: injen cai, hondata img, Esmm
Suspension/Brakes: Megan coilovers, Ingall camber kit F/R, EBC Green stuff pads
Interior: Sparco shift knob and pedals
Exterior: DIY redouts, debadged rear, headlights, and calipers
Coming soon: tint and jdm window visors
gdubb05 is offline   Reply With Quote
Old 08-23-2005, 04:25 PM   #22
arizonarsx
( ͡į ͜ʖ ͡į)
arizonarsx's Avatar
arizonarsx is cool, not as cool as some though arizonarsx is cool, not as cool as some though arizonarsx is cool, not as cool as some though arizonarsx is cool, not as cool as some though arizonarsx is cool, not as cool as some though arizonarsx is cool, not as cool as some though arizonarsx is cool, not as cool as some though arizonarsx is cool, not as cool as some though arizonarsx is cool, not as cool as some though arizonarsx is cool, not as cool as some though arizonarsx is cool, not as cool as some though arizonarsx is cool, not as cool as some though arizonarsx is cool, not as cool as some though
yeah cutting into the car is the scariest part,... thats where u gotta take your time
arizonarsx is offline   Reply With Quote
Old 08-23-2005, 04:59 PM   #23
metronDC5
Hide & Seek
metronDC5's Avatar
metronDC5 is an unknown quantity on c-rsx
+ rep for success
metronDC5 is offline   Reply With Quote
Old 08-23-2005, 06:56 PM   #24
n7plus1
Four Rings
n7plus1's Avatar
n7plus1 is an unknown quantity on c-rsx
reps sent, great job!
2003 A4 1.8TQM
TRUTH IN ENGINEERING
[08:24] n7plus1: man, i think i may need some tighter pants for tonight
[08:24] smcdowell1977: HAHA
n7plus1 is offline   Reply With Quote
Old 08-23-2005, 08:00 PM   #25
i2ejuv3nator
Nikon D70s
i2ejuv3nator's Avatar
i2ejuv3nator is an unknown quantity on c-rsx
Niiice write up man! Major guts cutting into that fender of yours.
2006 Aspen White STi
Nikon D70s | Nikkor 50mm f/1.8D | Nikkor 18-70mm f/3.5-4.5G | Nikon SB-800 AF Speedlight
i2ejuv3nator is offline   Reply With Quote
Reply
Bookmarks
complete , diy , guide , installation , jdm , pics , sidemarkers
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2012, Club RSX, Inc. All rights reserved worldwide.
