DIY Guide: How to Reset your SRS Light. (Visual Guide) - Club RSX Message Board
Notices
Reply
Thread Tools
Old 08-31-2005, 09:16 PM   #1
KSMatic
Sidemarker Mechanic
KSMatic's Avatar
KSMatic is a jewel in the rough of c-rsx KSMatic is a jewel in the rough of c-rsx KSMatic is a jewel in the rough of c-rsx KSMatic is a jewel in the rough of c-rsx KSMatic is a jewel in the rough of c-rsx KSMatic is a jewel in the rough of c-rsx KSMatic is a jewel in the rough of c-rsx KSMatic is a jewel in the rough of c-rsx KSMatic is a jewel in the rough of c-rsx KSMatic is a jewel in the rough of c-rsx
Our cars are known to have problems with the SRS lights, well basically all Honda/Acura because the system sometimes "hiccups" and causing codes to trip the SRS light.
DISCLAIMER: Please do this at your own risk, i am not responsible for any damages that you may cause by doing this SRS DIY reset. If you do not trust yourself, please take the car to Acura Dealership and have them reset it for you, Warranty will normally cover for reset at FREE of charge. Try this DIY at your own risk.
Note: If your airbag deployed or seats has been removed or anything that may have triggered the SRS, this DIY will not work for you. All you will get is two flashes or more and the light will remain on.
Tools Material Needed:
- Standard Paperclip (or wire)
- Maybe flash light (night job)
Time:
- 1 to 5 minutes
Difficulty:
out of
Your So Cal Friendly Installer: Los Angeles Regional
Need Installation? So Cal Installer here to service the RSX/Import Community
Contact me through facebook.com/ksmaticgarage
KSMatic is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-31-2005, 09:16 PM   #2
KSMatic
Sidemarker Mechanic
KSMatic's Avatar
Back up thread http://www.ksmatic.com/forums/showthread.php?t=44 incase pictures or whatever happens
First make sure your key is out of the ignition.
Step 1:
You can use two options in this step to use to make two contact connect together:
Paper Clip, you can use the paperclip and bend it out to where both ends are next to each other so it can be put in to two pins.
- or -
Regular wires, this is actually the best way to use to complete a circuit.
Step 2:
Remove the bottom panel under the dash, two twist clips which can be easily taken off. (turn counter-clockwise)
Step 3:
After the bottom panel is exposed, locate the fuse box (see drawing for location)
Step 4:
Locate the SRS plug above the fuses in the fuse box panel, you will see a yellow clip in the middle left side. It is also the ONLY plug thats yellow in the fuse box panel.
Step 5:
Unplug the clip. You should see two pin holes that you will be completing the circuit with using the paper clip or wires
Step 6:
plug the paperclip in to the 2-pin clip.
After all the Prep Work is done, here comes the steps you need to take to complete actually reset the light. TIMING MUST BE PERFECT, if the light comes back on, remove the key and repeat steps again. Read these steps first before attempting the reset.
Step 7:
With the paperclip or wires in the pins, place the key in and click to the Ingition On position II and leave it alone throughout the whole step.
Step 8:
You should hear beeps for 3 seconds, and when the beep is gone, the SRS should turn OFF.
Step 9:
QUICKLY, Take the paperclip/wires out and the light should come back on.
Step 10:
When the light comes on, QUICKLY plug the paperclip back in to complete the curcuit again, in a second or so, the SRS light should TURN off
Step 11:
At the final step here, you will remove the paperclip/wire and the light will quickly flash twice and turn off. You should wait a second or two to see if the light comes back, if so, YOU WILL NEED TO REPEAT steps 7-11 again. If not, read step 12
Step 12:
At this point, take the key out of the ignition and put the 2-pin clip back in to the proper place (same place where you took it out). Secure the bottom dash back in to place. Test out the SRS again with the Ignition Position II. It should beep then the SRS should turn off.
Quick Read DIY without pictures:
1. connect clip to yellow clip, turn key to position II
2. wait for the light to go off and remove the paper clip/wire.
3. As soon as the light turns back on, quickly connect the circuit again.
4. The light should turn back off. Remove the paperclip/wire again.
5. The light will wait a second or two before it tells you the follow word.
6. Final word is, 2 quick flashes and SRS light turns off completely.
6-A. two quick flashes and the light remains, you may be too slow or you have a short in your SRS somewhere.
7. turn off ignition and put back the clip.
Congratulations, you have successfully reset your SRS light.
Youtube Video:
The Beginning of the Initial Set Up
http://www.youtube.com/watch?v=cbuFD2TKnYY
Troubleshoot:
Most of the errors can cause by removing items such as steering wheel, seats, seatbelts and airbags. Its very rare for a sensor in the front to go bad but if you have been in to an accident and your airbag didn't deploy but the seatbelt locked, YOU MUST replace the SRS module.
If you have aftermarket steering wheel or seats, there is a resistor that you can purchase from Radio Shack where you stick in between those where the airbag or seats suppose to be and act to complete the circuit.
For people that have aftermarket/Non-Airbag Seats, please read this guide to bypass the SRS light issue.
http://forums.clubrsx.com/showthread...ermarket+seats
NOTE: You will not hear the beep if you have your driver side seatbelt on.
Old 08-31-2005, 09:20 PM   #3
l98vette85
Hi Hater.
l98vette85's Avatar
l98vette85 has a clean start l98vette85 has a clean start l98vette85 has a clean start
pff like this does me any help but good job nonetheless
LETSGO LAKERS!Morning Post Crew #2LETS GO ANGELSDrive Slow Homie #36
<3 RIP PICKLE
|Canon 40D|BGE2|Tokina 12-24 F4|Tamron 28-75 F2.8|
Originally Posted by StuDizzle View Post
I like having sex with my wife but if you do too, I'm going to have to cut you
l98vette85 is offline   Reply With Quote
Old 08-31-2005, 09:20 PM   #4
FutureITR
Bye bye BOOST, i-Vtec now
FutureITR's Avatar
FutureITR might be well recognized one day on c-rsx FutureITR might be well recognized one day on c-rsx FutureITR might be well recognized one day on c-rsx FutureITR might be well recognized one day on c-rsx FutureITR might be well recognized one day on c-rsx FutureITR might be well recognized one day on c-rsx FutureITR might be well recognized one day on c-rsx FutureITR might be well recognized one day on c-rsx
pro dawg =D
The last form of my 2003 SSM Type S
Suspension: Ohlins DFV
Made 235hp/173trq Z1 cams + Bolt Ons.
FutureITR is offline   Reply With Quote
Old 08-31-2005, 09:26 PM   #5
KSMatic
Sidemarker Mechanic
KSMatic's Avatar
Next DIY Visual Guide: How to turn on your OEM fog light with parking light
Old 08-31-2005, 10:27 PM   #6
PrivateDonut
M&amp;M Avy Crew
PrivateDonut's Avatar
PrivateDonut is an unknown quantity on c-rsx
nice write up
PrivateDonut is offline   Reply With Quote
Old 08-31-2005, 10:45 PM   #7
asiangodofyours
Master Member
asiangodofyours's Avatar
asiangodofyours is an unknown quantity on c-rsx
so if i swapped out aftermarket seats where the srs would normally come on, this wont help me right? lol
asiangodofyours is offline   Reply With Quote
Old 08-31-2005, 10:53 PM   #8
KSMatic
Sidemarker Mechanic
KSMatic's Avatar
put a resistor on the seat's srs clip.
Old 08-31-2005, 11:04 PM   #9
~KP-RSX~
Grand Master Member
~KP-RSX~ is an unknown quantity on c-rsx
yea..i have same problem when i put my aftermarket seats.....wut do u mean by putting a resistor on the seats's srs clip???
~KP-RSX~ is offline   Reply With Quote
Old 09-01-2005, 12:58 AM   #10
SPEED6
totaled
SPEED6's Avatar
SPEED6 is an unknown quantity on c-rsx
Good write up!
Any known reason why this light comes on anyway?
1993 NSX | Volk | Dunlop | Pride | KW | Procar | Zanardi | ScienceOfSpeed | Uni | TeamVoodoo | Valentine1 |
2013 Civic Si | WeatherTech |
SPEED6 is offline   Reply With Quote
Old 09-01-2005, 01:01 AM   #11
Brusky
B-O-MmMmm
Brusky's Avatar
Brusky is an unknown quantity on c-rsx
Be sure to tell eric_r_fagmo about this...his SRS light has been on foreverrrrr
| Canon Rebel XT | 18-55mm Kit Lens | Canon 28-135 IS USM |
| Brusky's Photography Gallery |
| Brusky: Return of the BoMmMmm Machine |
Brusky is offline   Reply With Quote
Old 09-01-2005, 01:07 AM   #12
goblin
&quot;Ethical&quot; Hacker
goblin's Avatar
goblin is an unknown quantity on c-rsx
and nice write-up
My Member Show-Off Thread
[ 16.045 @ 89.29 (2.560 60') - Stock | 175.24 whp / 128.37 wtq - Stock Dynojet SAE ]
[ 15.397 @ 91.59 (2.525 60') - V2 ]
[ 14.857 @ 95.44 (2.472 60') - V2 / IMG / #4 / Borla ]
[ 14.792 @ 96.44 (2.416 60') - V2 / IMG / Ingalls ETD / #4 / Borla ]
Best 60': 2.416
Best 1/8: 9.668
Best 1/4: 14.792
Best Trap: 96.49
goblin is offline   Reply With Quote
Old 09-01-2005, 01:11 AM   #13
goblin
goblin's Avatar
nevermind...
Best 60': 2.416
Best 1/8: 9.668
Best 1/4: 14.792
Best Trap: 96.49
Old 09-01-2005, 03:21 AM   #14
KSMatic
Sidemarker Mechanic
KSMatic's Avatar
he has a messed up sensor which needs to be replaced. I checked it the other day for him.
He has code 1 which is probably sensor issues
Old 09-01-2005, 05:24 AM   #15
DOHCtor
I love my rally car
DOHCtor's Avatar
DOHCtor is an unknown quantity on c-rsx
nice write up plus neg rep
Vid of me at streets of willow http://youtube.com/watch?v=rWNnDO7EHMw
Join the anti-drag racing crew
20MPG Crew
DOHCtor is offline   Reply With Quote
Old 09-01-2005, 05:52 AM   #16
ombastic
Master Member
ombastic is an unknown quantity on c-rsx
cool. jw but why do you need to reset your SRS light?
ombastic is offline   Reply With Quote
Old 09-01-2005, 06:07 AM   #17
KSMatic
Sidemarker Mechanic
KSMatic's Avatar
you will know when your shit comes on one day
Old 09-07-2005, 10:09 PM   #18
blackscorpion312
Crazy_Ivan
blackscorpion312 is an unknown quantity on c-rsx
My light came on after I bypassed the amp, I checked all the wires when I placed the seat back. The light was still on, so I took off the seat and unplugged and replaced all the wires again and still nothing! So either tonight or tomorrow I'm going to try this, thanks for the help.
The light was driving me crazy.
blackscorpion312 is offline   Reply With Quote
Old 09-11-2005, 07:24 PM   #19
KSMatic
Sidemarker Mechanic
KSMatic's Avatar
let me know how it goes.
Old 09-15-2005, 06:38 PM   #20
Thee See 5
dookie brown DC5
Thee See 5's Avatar
Thee See 5 is an unknown quantity on c-rsx
yea let us know, i jus swapped out my stock seats for some 04 si seats and my srs light came on even though everything is plugged in
2002 DC5 Type S
2007 Yamaha YZF-R6
Thee See 5 is offline   Reply With Quote
Old 09-15-2005, 08:07 PM   #21
?uestion
Mac Pro Ho
?uestion's Avatar
?uestion is an unknown quantity on c-rsx
I don't want to pay acura to find out whats wrong with my srs light so I got a question. nothing has been removed, but I attempted to reset it and I get six beeps and the light does not blink or go off, I plug it back in and get six beeps and the light stays on, what is it? I cant take this anymore!
CRSX DEAD since 2006
?uestion is offline   Reply With Quote
Old 09-15-2005, 09:10 PM   #22
KSMatic
Sidemarker Mechanic
KSMatic's Avatar
hmm, six flashes, who has a helms guide handy? You're car is throwing errors so something is wrong. <heh.
Old 09-16-2005, 02:21 PM   #23
kc&jojo
kc&jojo
kc&jojo is an unknown quantity on c-rsx
didnt work for me i have recaros/.
kc&jojo is offline   Reply With Quote
Old 09-18-2005, 02:08 AM   #24
TGTS2000
JRSC Inside
TGTS2000 is an unknown quantity on c-rsx
this is to RESET the light not shut it off, if you have aftermarket seats it'll stay on.
FREE Return Shipping on all Powder Coating!
Powder Keg Custom Coatings
www.ThePowderCoatStore.com
TGTS2000 is offline   Reply With Quote
Old 09-18-2005, 02:12 AM   #25
busa
o hai
busa's Avatar
busa is an unknown quantity on c-rsx
good shit kev
never underestimate
Originally Posted by KSMatic
tommy > all
busa is offline   Reply With Quote
Reply
Bookmarks
diy , guide , light , reset , srs , visual
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
