Go Back   Club RSX Message Board > PERFORMANCE BASICS > Turbo
Reply
Thread Tools
Old 10-25-2005, 12:19 PM   #1
PasSNuBye
ASSISTANT MASTER MECHANIC
PasSNuBye's Avatar
Piston Material? 4032 or 2618?
I'm doing some research on piston design and material and came accross the option of having the piston made out of SAE 4032 or 2618.
From what I have read at http://www.pcis.net/thehook/may.htm
it seems like 4032 is the way to go. Anyone got any mor insight they could give me on which is best matrial to use between these two.
PasSNuBye is offline   Reply With Quote
Old 10-25-2005, 12:23 PM   #2
jsimon9633
2008 Project?
jsimon9633's Avatar
never heard of this, heard of rod material but not that
Stock RSX Type S with K24A4 Motor, K20A2 Transmission and K20A3 Engine Harness?
jsimon9633 is offline   Reply With Quote
Old 10-25-2005, 03:50 PM   #3
PasSNuBye
PasSNuBye's Avatar
U read the info in the link? JE pistons offers pistons made in both materials. I asked CP what they used and they said 2618 so then I wanted to know what are the properties of that metal. Titanium is best I guess but between the other alloys i think 2618 is the weakest
Old 10-25-2005, 03:53 PM   #4
bahamian-importz
One of the 1st 500+hp k's
bahamian-importz's Avatar
cp is the way to go, i know a guy who used cp pistons in a 8sec civic for 3 race seasons. the exact same piston he only changed the rings.....
bahamian-importz is offline   Reply With Quote
Old 10-25-2005, 03:58 PM   #5
jsimon9633
2008 Project?
jsimon9633's Avatar
Cp is good so is JE so is many other companies.
forged pistons are good if tuned and done right
Old 10-25-2005, 04:01 PM   #6
jsimon9633
2008 Project?
jsimon9633's Avatar
also from that link you can see that Custom pistons are the best way to go since off the shelf wont necessarily meet your reqs
so whether its custom JE or custom CP you shoudl go custom based off your deck height and with the features you want on there
Old 10-25-2005, 04:17 PM   #7
bahamian-importz
Old 10-25-2005, 08:03 PM   #8
mikestypes
Master Member
mikestypes's Avatar
2618 is what you want for maximum effort race engines, or maximum power production. 4032 is better for daily driver/weekend racer looking for low noise and great engine longevity.
2618 is stronger, but 4032 is better for anything to be used for decent life.
Mike
07 Mazdaspeed3
05 Type-S
mikestypes is offline   Reply With Quote
Old 10-25-2005, 08:25 PM   #9
PasSNuBye
PasSNuBye's Avatar
but from what im reading, the 2618 has less silicone which makes it a weaker metal then 4032...also as for more efficiency, if u have 2618 it expands more in heat which then requires u to have a bigger piston to bore clearance which is less efficient right?
what u want is the smallest piston to bore clearance for max effort
Old 10-25-2005, 08:32 PM   #10
mikestypes
Master Member
mikestypes's Avatar
No, re-read the article. The 2618 is a denser, stronger material than 4032 becuase it has less silicone. Because of this, when heated, it expands more, thus the need for larger piston to wall clearances. Once at operating temperature, the clearances are the same. That does not matter for efficiency anyway. The piston rings do all the sealing of the combustion pressure anyway.
The piston to bore clearance all depends on combustion temperatures. The higher the temperatures, the greater the clearance required. If too tight a clearance in run, the piston will scuff, or worse, seize in the bore.
Mike
07 Mazdaspeed3
05 Type-S
Old 10-25-2005, 08:45 PM   #11
PasSNuBye
PasSNuBye's Avatar
Re-Read...
Tru Tru...I guess 2618 would be better then.....That settles that for me...I'm thinking about going with CP custom or JE custom....
Reply
Bookmarks
2618, 4032, material, piston
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
