#1 |
US ARMY EOD
megan racing alignment (Camber / toe) questions
okay so ive read about a bunch of people getting really good angles with their setup
i have megan racing coilovers and ingalls rear camber kit, thats realy all that would attribute to the toe and camber settings thats on my car anyways i was aiming for a -2.5 in the front camber degree and -1.5 in the rear and trying to get a 1/16" toe in the front and 0 in the rear the rear was attainable easily...we did that one first and it was at -1.5 and 0 on both sides then we started on the front and thats where some problems came....we were only able to squeeze out -1.8 total camber from both sides...but to do that we could only get 2 of the camber bolts (that go on the pillowball mount) to go in...so we backed it out to -1.5 which got the bolts in....so that was good ... but then the lowest amount of toe we could get with that -1.5 camber in the front was 2" (!!!) so pretty much,..what i wound up doing was bringing the car to a neutral base at 0 camber on both front and rear with 0 toe as well (plus a few hundreths of a degree extra like the rear left toe is 0.01) anyways....what else can i put on there so the front is more adjustable....im guessing to add a front camber kit (the eccentric lobed bolt) so i can bring the camber out to -2.5 .... but then what can i do for toe adjustment...since with the increase in camber brought the increase in toe angle...id have to have a much longer tie rod i think any help is appreciated thanks
A to B: 2006 Jeep Liberty P&S: Nikon S6 dSLR: Nikon D50 Developing Room: MacBook Pro |
#2 |
Master Member
I ran into the same problem you did when I installed mine. I then ordered Ingalls' front camber bolts. I used 1 on one side, and 2 on the other (don't remember which side's which). Yes, 1 camber bolt on one side, 2 camber bolts on the other side. Don't ask me why. It just turned out I couldn't get as much camber on one side for some odd reason. Anyways, I ordered 4 bolts, so I had more than I needed.
Right now, I'm at about -2.5 degrees of front camber with about 1mm toe out. There isn't much you can do about the toe. I'm pretty much at the very end of the threads. I've done some searching and asking around and it seems you need to get J's (the only 1 that comes to mind) tie rod ends to achieve even more toe adjustments. However, seeing your goal is -2.5, I think you'll get away with the stock ones. (At least I did.) Rumour has it that EP3 inner tie rods are shorter, giving you more adjustments... I can't confirm that. |
#3 |
I love my rally car
If you guys have the first version of megan racing coilover you will have this problem. shouldn't be a problem with the revised version.
Vid of me at streets of willow http://youtube.com/watch?v=rWNnDO7EHMw My picture trail Join the anti-drag racing crew
20MPG Crew ![]() |
#5 | |
I love my rally car
20MPG Crew ![]() |
#6 | |
US ARMY EOD
so it should be the newer ones?
#7 |
Poping Locks
yeah i had the same problem the guy at the aligment shop just though my frame was bent. so i can order new camber plates from megan
-Joe SJ OG CREW FOR LIFE |
#10 |
My sex is on fire!
The high mounting steering arm fvcks up the toe bad. The lower you go the worse the toe gets. to get 0 toe, I maxed out at -2.1 camber. You can try inverting your tie rods. You can get custom shortened tie rods to allow more toe, but we are at the mercy of this crappy strut design.
Coilovers - Koni Yellow with GC (400/550): Sways - 25.4mm front, Progress 24mm rear: Strut bars - took the fucking things off!: Bushings - ES front and rear poly: Brakes - ATE Superblue brake/clutch fluid: Camber - SPC camber kit: Race rims - 15x7 Kosei K-1 powdercoated black wrapped in Falken Azenis: Shifter - OBX |
#12 | |
My sex is on fire!
#13 | |
BIG POPPA®
I coulda got more cuz I had the cambolts for the fronts. But I don't like that set up, so I went without them. I'll probably get the J's Racing bits, once I figure out exactly whats needed. The confusing thing is that when I first got aligned, they could only get -1.3. Then I dropped it a bit more, and they got -1.8. Different shops though. And the guy who got -1.8 is a "guru".... I'm guessing the first place didn't want to take it so close to the limit maybe. I'm only looking to get -2 anyway, so I'm right there.
"I think I might of went in the wrong hole" Mike Rowe |
#14 | |
My sex is on fire!
#15 | |
US ARMY EOD
i got it at -1.8 but they couldnt bolt it up... they had to set it at -1.3 thats what i was at....but then the rear was -1.5 i just zeroed it all out till i figure out all the suspension stuff question...how the fuck do you get the drivers side lock ring on the bottom (the height adjusting one) to stay tight...its always coming loose
#16 | |
I love my rally car
I got my front at 1.5 and rear at 1.5. my front had enough room to go up to 1.7.
20MPG Crew ![]() |
#17 | |
My sex is on fire!
#18 |
US ARMY EOD
yeah i do but...theres only so much you can hammer before it starts to rip into the strut housing
#20 | |
Late Apexer
Raise the car up some, it will free up alot of toe adjustment.... (I'm running -2.6 on the nose with a mild drop and 0 toe)
“There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order.” — Ed Howdershelt |
#21 |
305whp 281wtq
This thread is so old...
08 OB Evo X w/ SSS and Aero Kit 300+ whp Base Crew #1 Special Thanks to: Suja1 Motoring and Dave at Whipfactory Base RSX Turbo F/S: http://forums.clubrsx.com/showthread.php?t=672969 |
| Bookmarks |
| Tags |
| alignment, camber, megan, questions, racing, toe |
| Thread Tools | |
