#1 |
2006 mustang GT 5spd
supercharger setups - 5psi vs. 7psi, 9psi, 11psi+
guys -
being at only 5psi with the JR setup and blackbox, i'm starting to wonder if i have an advantage over the higher boosting guys in street racing and practical applications, even though i know those guys have at least a 40whp+ advantage over me. the reason i say this, is because i have a lot less wheel spin while still having quite a bit of whp. to illustrate what i'm saying, let's use an example of me vs. someone with 11psi in a 1/8 mile race from a dig with stock tires: we both launch, and we both spin our wheels. i hook up first because i don't have quite as much power, and start down the track. meanwhile, joe blow with 11psi is spinning all the way through first, second, and the beginning of third gear, not really going anywhere. by the time he hooks up, and can actually put all of his whp to the ground and exercise his advantage, the race is almost over. in the mean time, i cross the finish line first and win. hmm... point is, yes i know higher boost = more whp, but is that necessarily a practical advantage in a fwd torqueless rsx-s? i mean by the time these high boosting people get traction, i'm way out in front. yeah if it's a long race i'll lose, but in the short term i think i have the advantage. it's like i have a lot more whp than stock (by 50whp roughly...im at 225whp), but i haven't lost *that* much traction. so what i'm try to get at is from a dig, i think at least for the rsx-s there is a "perfect" balance of whp/boost, since too much means you are pretty much useless, and too little and you're going too slow. yeah from a roll, or at higher speeds those high boost cars > all, but from a dig, i think i would stand a good chance at beating a lot of those cars in a short race due to traction/torque issues. thoughts/comments?
2006 black ford mustang gt coupe 5spd 3.55 rear axle, IUP, shaker1000 system, 300hp/320tq 2003 s/c debadged pwp rsx-s stock header, stock exhaust, 265whp/186wtq @ 7psi SOLD 7/25/06 |
#2 |
SC Crew #20
in the 1/8th mile you might have more of an argument then the 1/4, just based on the 1/4 mile top ten list. Also, 5 psi on the street (from a roll) will probably get beat pretty badly by 11psi. I think your argument would be more realistic if you compared 7psi (jrsc or 6-8psi ctsc) to 11+ psi. But just based on the 1/4 mile times list your argument is not that well thought out (with people running 12.0-12.5) with slicks and some nos while you are in the low 13's according to your sig. I know Jim has Cams but your argument is that more power is bad for our cars (which i agree to a point).
cliff notes: good thought but according to 1/4 mile times incorrect
S/C Crew Member #20 [Injen] [A-Spec] [Comptech] [Hondata] [Strup] [Exedy] [Autometer] [Pirelli] [WedsSport] [Kumho] |
#3 |
Knowledge is Horsepower
That would apply to those who havent figured out how to launch correctly with their cars, someone who has figured out how to launch and keep traction will still win. Its all about the driver. Thats the same reason why you do have a good chance to beat alot of guys who have not figured out how to launch correctly.
#4 | |
hmm...i wonder when i upgrade to 7psi if i could beat say for example wdsonny with 11psi+ in the 1/8. yes i know in the 1/4 that's enough time for them to put their power down but i guess i was talking more about the 1/8 mile...it'd be interesting to see 1/8 mile times and how that list changes when you do 1/4 mile runs...
#5 |
SC Crew #20
I was having a similar conversation with my cousin who drives a WRX. Stock for Stock our cars (accoring to Car and Driver) run very close in the 1/4 mile. There werent any 1/8 mile stats but I would assume he would get me by .4-.5 in the 1/8th and only like .1-.2 in the 1/4
#6 |
SC Crew #20
also, i thnk black nite had a thread about this between 9 and 11 psi a few days ago, a quick search might do you some good
#7 |
Monsters of the Midway
I'll spin past you
You ran 13.6 @ 102 with slicks. I ran a 12.8@110 with a 1.99 60' time on stock drivetrain. The 100 bucks to upgrad the pulley and couple hundred for the injectors are the best bang fo yo buck for the supercharger when it comes to the WHP to $$ ratio.
Collecting avy's in the NFL thread like Pac Man's rap sheet GO BEARS!! NFC North dominance commences Sep. 09 |
#9 | |
SC Crew #20
#11 | |
Sold My baby!! :(
Well I didn't have street tires I had azenis, but I ran a 8.7 in the 1/8th with 9 psi. I doubt you went faster than that. If you did, then good driving! Jamie |
#12 | |
SS Specialist to the 6th
My Home Page |
#13 | |
www.teamsolo.net
#14 |
GB going all the way!
yeah, I think even in 1/8 mile times...7psi will beat the 5psi. Unless the driver of the higher boosted car just sucks at launching
2005 S2000 -SOS Stage 2 Supercharger with Aftercooler, Competition Stage 4 clutch, HKS Hi-Power exhaust, AEM EMS- |
#16 | |
SC Crew #20
#17 | |
On street tires, with a perfect launch and 2.2 60'. You wouldn't beat me with 5psi. You may have more traction, but who's to say I don't know how to launch at 11psi. Better bring your 'A' Game.
#18 | |
-john
#19 | |
#21 | |
ECU Tuner
Now, say, how can you so knowledgeably speculate about this and then ask something rather marginal like "can I use Hondata 4 on my JRSC" at the same time?
Mods: Stage 3 Comptech SC, AEM CAI, Comptech street header, stock cat, modified stock injectors, Hondata K-Pro, Hondata IMG, Fujitsubo PG catback, cat, 225/45-17 Falken Azenis RT-615 on Kazera rims, Mugen SS, Quaife LSD, CT lightweight flywheel and street clutch, ACT heavy-duty pressure plate, CT rear sway/tie bar and titanium front strut brace, Type-R replica wing, CT short shifter, Auto Meter Sport Comp full-sweep boost gauge. Current results: 290 whp on DynaPack. Web: My RSX and K-Pro page. My Blog: ECU Tuning |
#22 | |
I dropped .3 sec in the 1/4 mile going from 9psi to gasp... 9psi lol. It's with the 11psi pulley though, so the powerband is better for midrange. update the 1/4 mile time post when you can
My Home Page |
#24 |
Master Member
at least 9. don't know about 11 though.
Deaths: Ferrari F40 40-130 by train lengths Bentley Continental GT 60-100 by bus lengths Lexus ISF 60-100 by a bus length Kills:Porsche Cayenne S 0-90 ![]() |
| Bookmarks |
| Tags |
| 11psi, 5psi, 7psi, 9psi, setups, supercharger |
| Thread Tools | |
