Go Back   Club RSX Message Board > GENERAL > The DIY Garage
Reply
Thread Tools
Old 11-25-2005, 05:54 PM   #1
bayareatypes
Comptechified
bayareatypes's Avatar
DIY: Modified Comptech Icebox
Things you need:
Comptech icebox:
http://www.comptechusa.com/store/330130rsx.html
High temp brake duct:
http://www.pegasusautoracing.com/Pro...p?Product=3620
I got the 2'' ID 6 foot.
ACE 2'' drill bit: see picture
Devcon silicone glue:
http://www.hobbylinc.com/htm/dev/devs-250.htm
Install was pretty easy. The only trouble I had was drilling the hole in the right spot.
Cut your brake duct to size I just eyeballed the length. Next remove the icebox. I'm sure if you have one you know how to do this. You do not need to remove the bottom snorkle just push out the two plastic buttons from the airbox. Then you want to cut a hole in the top bumper mount for the air duct to pick up cool air. On the hood their is some weather stripping which prevents water getting into the engine bay remove a piece where you cut your air duct hole. Then you want to determine where you are going to drill the 2'' hole in your icebox. I drilled mine about 1/2'' to the right from the snorkle hole. I then got my brake duct and put it into the hole and used high temp silicone glue to secure it in place. This stuff is flexible and forms an air tight seal. Start putting your icebox back in and slowly work the brake duct to the front bumper pickup. Good luck if you attempt this DIY. See attachments. What inspired me to do this was the king motorsports acura rsx. See picture for the idea. I noticed some power increase in all rpm ranges and throttle response improved. When driving on the freeway the car now picks up speed alot quicker then before.
bayareatypes is offline   Reply With Quote
Old 11-25-2005, 06:16 PM   #2
etonek
Senior Member
So is the Comptech snorkel still in place?
It seems like you just cut another hole in the Icebox and created another snorkel.
Another idea, if you interested, might be to run that duct from the tip of the original Icebox snorkel out through the foglight hole.
Congrats on the install. I've always been curious if something like this would work and the only way to know is by user opinion.
Knock Knock
etonek is offline   Reply With Quote
Old 11-25-2005, 06:17 PM   #3
Paint
Superbleeder
Paint's Avatar
Pretty nice imaginary +rep
Paint is offline   Reply With Quote
Old 11-25-2005, 07:36 PM   #4
bayareatypes
Comptechified
The Comptech snorkel is still in place.
Old 11-25-2005, 10:52 PM   #5
fatcircles
:P \|/
fatcircles's Avatar
fatcircles has disabled reputation
thats a good diy mod for the icebox, nice job
fatcircles is offline   Reply With Quote
Old 11-27-2005, 02:25 AM   #6
rsxdude
Asian dude
rsxdude's Avatar
Seems like a great mod! I might just have to do it. Except with a smaller cutout. heheh. Just fuking wit ya man! Great pics. Could you get a closer picture of the grill area?
rsxdude is offline   Reply With Quote
Old 11-27-2005, 02:29 AM   #7
aziatiklover
LACOSTE WHORE
aziatiklover's Avatar
nice DIY man u got rep bomb
aziatiklover is offline   Reply With Quote
Old 11-27-2005, 03:11 PM   #8
Frenchy
Master Member
Frenchy's Avatar
Frenchy might be well recognized one day on c-rsxFrenchy might be well recognized one day on c-rsxFrenchy might be well recognized one day on c-rsxFrenchy might be well recognized one day on c-rsxFrenchy might be well recognized one day on c-rsxFrenchy might be well recognized one day on c-rsxFrenchy might be well recognized one day on c-rsx
that looks like a good idea
I've seen that on the Mugen air box as well, a while ago, in racing applications.
On another note, will that opening in the bumper be useful to a Mugen intake for the DC5?
Frenchy is offline   Reply With Quote
Old 11-27-2005, 04:09 PM   #9
bayareatypes
Comptechified
To answer your question Frenchy I think that opening will be useful for the Mugen airbox.
Old 12-01-2005, 01:03 AM   #10
bayareatypes
Comptechified
Also their are two water drain holes in the back bottom part of the icebox, plug those up with some plastic or rubber plugs to increase induction from the snorkel and brake duct.
Ace Drill bit picture:
Old 12-01-2005, 05:34 PM   #11
KCRSXTypeS
K24a2 Swapped
KCRSXTypeS's Avatar
those water drain holes are there for a reason, do not tamper with the design of the box. by installing the new intake ducting you could be messing with the resonance of the box and that is what causes the gain in HP.
"The sea is dangerous and its storms terrible. But these obstacles have never been sufficient reason to remain ashore. Unlike the mediocre, intrepid spirits seek victory over those things that seem impossible. It is with an iron will that they embark, on the most daring of all endeavors, to meet the shadowy future without fear and conquer the unknown." -Ferdinand Magellan, explorer
1973 Honda CB500 Four - Motorcycle Crew Member #6
KCRSXTypeS is offline   Reply With Quote
Old 12-02-2005, 02:32 AM   #12
rsxer63
Low Flying Whore Ron
rsxer63's Avatar
rsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fit
rsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fitrsxer63 probably needs to buy a Wii Fit
why not just disconnect the Comptech intake pipe and run the flex to the fog light area?
Teams: Team Ranthem, SC Crew Member and Infamous Family
RIP Brenda J Aguilar 1964-2002
rsxer63 is offline   Reply With Quote
Old 12-02-2005, 05:15 AM   #13
Frenchy
Master Member
Frenchy's Avatar
running both "snorkles" will allow to bring in more and cooler air
Old 12-02-2005, 05:41 AM   #14
Razathorn
glory to the hypnotoad
Razathorn's Avatar
Razathorn has a clean startRazathorn has a clean startRazathorn has a clean startRazathorn has a clean startRazathorn has a clean start
I'm going to reiterate something hondata clued us in on about the k series motor and intakes. The k series likes a long tube style intake directly after the throttle body. On real cold air intake systems, you will see this token long straight pipe directly after the directional bend right after the throttle body. It's not just the temperature of the air with a cold air intake system, it's the length of this section and the intake resonance it produces. This intake resonance is responsible for a good portion of the CAI's gains in a N/A environment. The peak gain in torque is centered around this resonance point. You're not going to be able to reproduce this with the ducting this mod is utilizing -- you need a good straight pipe section of correct diameter and length that produces the resonance point in the right rpm range.
If this mod indeed lowers intake air temperatures, which you should be able to see via the IAT sensor, then it's a great idea. Just don't be under the impression that you've bridged the gap between a real CAI and the icebox. Lowering intake air temps is a step in the right direction however.
Wayne
[ nbp '03 type-s / jrsc 12psi / methanol injection ]
[ links:
k-pro power tuning w/o dyno | K-Pro Tuning in the Kansas City area ]
Originally Posted by The Wife
Hey, *if* your brother comes to our house this weekend, I'd like for you to take your car parts and blow torch thing out of the livingroom.
Razathorn is offline   Reply With Quote
Old 12-09-2005, 01:40 PM   #15
knightzerox
Senior Member
knightzerox's Avatar
I plan on doing this except without using the icebox snorkel and just the ducting. Similar to a mugen box. Of course I'm sure the mugen box may perform better because of the internal box design, but the icebox is also completely smooth I beleive and just has a filter. I think this would be a great way to make a cheap mugen style box. Any opinions?
NBP 05 Type-S
Mugen Pedals
Alpine F240 powering Polk DB 6500 + Polk DB 650
Alpine F340 Mono amp powering Infinity Reference 1030w
Mugen Replica Front and Rear strut bars
knightzerox is offline   Reply With Quote
Old 12-09-2005, 01:47 PM   #16
Frenchy
Master Member
Frenchy's Avatar
Wayne
in this particular case, the resonance of the air will have no effect since the air hasn't been filtered, so it still has to be filtered before entering the IM.
Old 12-09-2005, 01:59 PM   #17
Razathorn
Razathorn's Avatar
I think it's the air box, not the filter, that would cause the majority of the problem. Just not really possible to build a 'long tube' resonance effect like this. Still, without a doubt, just *oodles* better than an sri if you can get some cold air in there.
[ links:
Old 12-09-2005, 02:25 PM   #18
Frenchy
Master Member
Frenchy's Avatar
the goal of the air box is to keep air pressurized and available as soon as the throttle body gets opened, or as soon as the driver gets on the go pedal to keep it simpler, that mod will only bring cooler air to the box.
Now, what I understood in the previous post is that it would disrupt the air resonnance; since the air still has to be filtered before entering the IM, the resonance of the air isn't an issue because it'll be messed with when the air will go through the filter anyway.
Old 12-09-2005, 03:01 PM   #19
Razathorn
Razathorn's Avatar
Keep the air pressurized? What? I think you're thinking about throttle response as in you don't want to create a vacuum in the intake as you swing the throttle plate wide open -- is that what you're saying?
To be clear, I wasn't saying that you are destroying any resonance, I am saying that adding the 'cold air hose' doesn't provide any resonance.
[ links:
Old 12-09-2005, 03:51 PM   #20
Frenchy
Master Member
Frenchy's Avatar
yup
well, it sounded like it's what you were saying
Old 09-22-2006, 04:26 PM   #21
RSX-S-NY
Dislikes assholes
Do you have a place(link or otherwise) where one can pick up the flex tubing your using?
**Also you have a PM.
RSX-S-NY is offline   Reply With Quote
Reply
Bookmarks
comptech, diy, icebox, modified
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
