#1 |
k20 valve cover FS!!!!!!!
I got a 05 RSX and just got some HID kits for it.. They are snug fit in the housing with X-clips and the bulbs are straight.
My drivers side headlight is alittle lower than the passenger's light with the factory aiming. I want to aim the driver's alittle higher so I can see alittle better. Right now the drivers side got a cut off point that i don't like. In the helms manual on the crsx site, it shows how to aim for the 02-04, the 05+ design is alittle diff. Do I adjust the screw thingy towards the top of the headlight or I think there is one towards the bottom... I don't wanna mess up my headlight alignment by adjusting the horizontal crap.. Thanks... Need some help ASAP... |
#2 |
I love my Type-Sex
There's a little bronze wheel thingy..spin that I'm not sure which way you spin it but just trial and error it. If it goes down, then spin it the other way to go up
#3 |
Integra DC5S
there is a guide showing u which way to spind the wheel to go up and down, it is on a black panel just next above your head light cover. it goes something liek this D <-------> U but with a curve instead of the straight arrow.
Oh when you spin it, dont expect a huge up and down results, it only move a very little margin so u got to look at it carefully |
#4 |
so, don't mess with the screw adjuster on the top of the headlights?
Where is the spin thingy at? In the back of the headlights toward the bottom or top???? I think I know what ur talking about.... How many are there? Is there 1 for vertical and 1 for horizontal? I don't want to mess with the horizontal or I am screwed.. Its dark now, I am waiting until morning to look at it... |
#6 |
Ok, I got it higher, saw that small direction arrow on top of headlights, spinning counter-clock-wise is up.. Thanks yall.... Can't wait to see how much farther my headlights shine now at night... I'll let you know...
#7 |
Master Member
Make sure you don't aim them too high.
http://forums.clubrsx.com/showthread.php?p=2975809
Some words that you may not use correctly: Should HAVE not should of • THEY'RE = they are • THERE is your fat mom. • THEIR moms are fat. • Brakes stop your car. • Breaks is what happens when your mom sits on something. • Tried not tryed • Paid not payed • Cost not costed How to use Apostrophes • How to use You're and Your correctly |
#11 | |
What did you said?
VisualInstall Guides '02-'04-styled taillight rewire on an '05+ | '05+ Type S FR grille badge install | '05+ Type S RR badge install | "Integra" badge install | '05+OEM fog install | '05+ Type-S high wing install | Touch-up paint basics | HID install | Injen CAI install | Lamin-X your fogs | '05+ A-Spec bodykit install | Daytime running lights on your USDM RSX | Heated power folding mirror: planned | Red "A" emblem: greenlit |
#12 | |
REP TEH BOOBIES!!
edit: n/m I found it!!
Objects in mirror are slower than they appear. Last edited by Speeddemon69; 11-30-2005 at 02:45 AM. |
#13 |
Senior Member
ok here a good question that i need help wif!
i jus got my jdm head light i i bought yellow light bulba and i put then on the high beam (and damn there are bright and fuken high!!!) how do i turn the high beams down? |
| Bookmarks |
| Tags |
| aiming, headlights, hids |
| Thread Tools | |
