#1 |
iBOOST- Do u?
Reverse Lockout..
I've read that if you use the base ECU on a TypeS you will loose the reverse lockout function.
Can someone explain to me what exactly is reverse lockout? is it to prevent you to go into reverse when you move? |
| Sponsored Links | |||
Advertisement | |||
#2 | |
Senior Member
Rich |
#3 |
spicy
not too sure about the swap either, but there is a solenoid there that prevents you from engaging the reverse gear at any measurable moving speed.
About the swap though, i think that would be applicable.. there is no use for this feature on a base model tranny
Motorcycle Crew #17 2007 Pearl White CBR600RR |
#4 |
Playground Legend
there is no reverse lockout on the base ecu. Only on the type s ecu. But seriously, how bad of a driver do you have to be to throw your car in reverse when you are moving forward. It would pretty much have to be intentional for you to damage your car.
Base 5spd |
#6 |
glory to the hypnotoad
Without reverse lockout, going into 5th or 6th is annoying at best. When the lockout is disabled, when you go from 4th to 5th, you will find yourself getting stuck in the reverse horizontal gate as you push 'up and to the right' to get to 5th. When going from 5th to 6th, you keep right pressure applied and pull down on the shifter -- without reverse lockout, you will go into the reverse horizontal gate. You have to have the exact right pressure down or you will go into 4th instead of 6th, or get into the reverse gate.
Basically, without reverse lockout, using 6th and 5th is a frigg'n pain. Try shifting from 4th, to 5th, to 6th while sitting in your driveway in a type-s some time. Gets annoying doesn't it?
[ nbp '03 type-s / jrsc 12psi / methanol injection / aftercooled ] [ links: k-pro power tuning w/o dyno | K-Pro Tuning in the Kansas City area ] |
#8 | |
Senior Citizen
If you don't believe me, go try shifting really fast from 4-5 in a Type S when its at a stop, you'll see what I mean. 9 out of 10 times you'll probably land the far right gate and won't go into 5th. |
#9 |
Now rollin' 6MT GDurtay5
^He's right.
SE-R Spec V's don't have the lockout. People fuck up 4th to 5th all the time.
Back to a G. lol Sunglasses F/S: http://forums.clubrsx.com/showthread.php?t=605794 iPod Shuffle F/S: http://forums.clubrsx.com/showthread.php?t=606746 |
#10 | |
Master Member
and watch out if you ever skip gear and go from 2nd to 6th or 4th to 6th.
#11 |
BIG POPPAź
I had a base ecu in my car for a couple weeks. Without the lockout it, the problem is more that you'll hit 4th instead of 6th when you are upshifting from 5th. Going into reverse isn't the problem, though its what you think about constantly.
Honestly, I go used to the shifting in less than a day. However I wasn't racing or shift extremely fast. But who shifts 5th and 6th really fast anyway. I'd much rather have the lock out there.
"I think I might of went in the wrong hole" Mike Rowe |
#12 | |
#13 |
BIG POPPAź
Yeah, what people don't realize is that without that lockout you have about as much space as there is from 1st to 5th as you do to the right of 5th, maybe more. Its like an enormous no mans land.
So what you end up doing is trying to stay right on the 4-5 upshift and end up in no man's land. Then on the 5-6 upshift you try to stay left to stay away from reverse. And thats when you hit 4th instead. I never had a problem of hitting 4th instead of 6th. I did on a couple occaisions hit no man's land when upshifting to 5th......but its not a big deal. And like I said, it took less than a day to get it into my wrists memory.... And just so you know, I always shift 100rpm before vtec!!!
#14 |
iBOOST- Do u?
Hmm ok, thanks alot guys...
I have a second question. What about engine swap? something like K20A2 engine in EK with 6speed tranny, will the TypeS ECU have the reverse lockout? is the solenoid in the gearbox? something i can fix by adding it? If the TypeS ECU will still remain the reverse lock out i think i'm better off getting the TypeS ECU right? My future plan is to have K20 engine in another car with TypeS 6speed tranny (ofcourse with ITR FD and LSD). So you can get what i'm concerning . Note: my goal to RWD too... If the TypeS ECU still remain the reverse lock out, i'm better off getting the TypeS ECU. If not, there is no point getting one right? Mine is TypeS, its just that i can find Base ECU for lots cheaper due to wreck yard has them instock Thanks again Last edited by MameXP; 01-23-2006 at 05:47 PM. |
#15 | |
If you're getting a k20a2 swap with the type-s 6 speed then you need a type-s ecu to control the reverse lockout. The lockout solenode is in the transmission and is part of the engine harness -> ecu setup if I recall correctly. Wayne
#16 | |
Breast inspector by appt.
'06 black type-s.
#17 | |
iBOOST- Do u?
So you recommend me to get the TypeS ECU then? Its not for my car, but i will use it for a while to get a hold of K-Pro then i proceed with my project of having K20A2 in another chassis and looking to have RWD, so this ECU will then be used for the project car. |
#18 | |
| Bookmarks |
| Tags |
| lockout, reverse |
| Thread Tools | |
