Go Back   Club RSX Message Board > PERFORMANCE BASICS > Turbo
Reply
Thread Tools
Old 01-31-2006, 12:50 PM   #1
Djstorm100
Boostifed
Djstorm100's Avatar
Stainless or Alum. piping...hmm..
whats the pros and cons of using Stainless Steel VS Alum? i'm going to redo my ic pipping... if there a right way and a wrong way to do this? as far as flow characteristic goes? I alwasy was thinking about a 2.25 or a 2.5 inch goig to the intercooler form the turbo.. then 2.5 going to a 3 inch (3inch closer to the TB) like rsxracerblack (brandon) did... i was thinking about making it routing like Greddy's .. any word guys?
Motorcycle Crew#11 2008 Harley Davidson NightTrain
1991 Venom Red Mustang 306 76mm Turbo 550hp low boost.
Djstorm100 is offline   Reply With Quote
Old 01-31-2006, 12:54 PM   #2
03DSM-RSX
713
03DSM-RSX's Avatar
03DSM-RSX is on a distinguished road03DSM-RSX is on a distinguished road03DSM-RSX is on a distinguished road
3" is difficult. michael tried it but wasnt successful. he had to replace it with 2.5".
aluminum piping is best. lightweight, doesnt rust, and dissipates heat better.
steel needs to be powdercoated or it will have a chance of rusting, also is heavy as hell.
it takes a special type of welder to weld aluminum i believe. but just call the shop and make sure they can do it.
st00pified and Kpro'd RSX Base Auto w/ IPT Race Trans 260+whp/235+wtq
2010 BMW 335d w/ Sport Package
03DSM-RSX is offline   Reply With Quote
Old 01-31-2006, 05:26 PM   #3
Fade2Black
OoooOOoo a red ball
Fade2Black's Avatar
Fade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their own
Fade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their own
stainless is heaver and possibly more expensive... just do aluminum
Fade2Black is online now   Reply With Quote
Old 01-31-2006, 09:10 PM   #4
Djstorm100
Boostifed
Djstorm100's Avatar
You need a tig to well alu. and ss hard as hell to weld them with a mig
Old 01-31-2006, 09:20 PM   #5
Fade2Black
OoooOOoo a red ball
Fade2Black's Avatar
Originally Posted by Djstorm100
need a tig for either alu. and ss
huh? yes the best way is too TIG is your asking...
Old 01-31-2006, 09:22 PM   #6
Ripping VTEC
Senior Member
use aluminum. wouldnt it be harder to run the piping like greddy, there is barely any room to start with. you would prob want to route it the same as the CN kit.
Ripping VTEC is offline   Reply With Quote
Old 01-31-2006, 09:24 PM   #7
Fade2Black
OoooOOoo a red ball
Fade2Black's Avatar
i could defintely fit 3 inch piping if i had a side/side intercooler and a new IM
Old 01-31-2006, 09:31 PM   #8
Keith DC5
3.8 N/A > 2.4 F/I
Keith DC5's Avatar
Keith DC5 is on a distinguished roadKeith DC5 is on a distinguished road
Yes stainless steel is heavier, but isn't aluminum more expensive? That's not an easy material to produce.
As far as sizing vs power goes, it's pretty much air volume versus velocity. Smaller piping has a faster air flow (increase torque) while larger ones just have more airflow (increase horsepower). I'm not 100% sure on that however...
8600 RPMs and 4 PSI
Volumetric efficiency without the understeer
Keith DC5 is offline   Reply With Quote
Old 01-31-2006, 10:17 PM   #9
Fade2Black
OoooOOoo a red ball
Fade2Black's Avatar
pretty sure about your statement....unless your runnin a bad ass setup there is no need for 3 inch piping... regardless 3 inch SS and aluminum are both pretty expensive in regards to the size of the piping alone...
Old 01-31-2006, 10:26 PM   #10
Djstorm100
Boostifed
Djstorm100's Avatar
yea this i've been aware of but wasnt/didnt kow if it was 100% true
i'm going ot make a torque monster... 10mm piping LMAO
Old 01-31-2006, 10:57 PM   #11
flex1181
Pump Gas Bandit
are you running a CN kit...?
flex1181 is offline   Reply With Quote
Old 01-31-2006, 11:22 PM   #12
Djstorm100
Boostifed
Djstorm100's Avatar
yupp about to be redone
Old 03-01-2006, 08:40 AM   #13
vuaccordla
Member
vuaccordla's Avatar
Bringing this thread back to life. Can anyone confirm Keith DC5 about the piping size?
I will be using a rev hard FMIC that has 2.25 in and 2.25 out. Would I be better off running 2.25 piping or 2.5 piping? Setup will most likely be in a EK k20a2, with gt35r. Daily driven with room to grow in the future.
vuaccordla is offline   Reply With Quote
Old 03-01-2006, 11:13 AM   #14
Djstorm100
Boostifed
Djstorm100's Avatar
2.25
Old 03-02-2006, 12:25 AM   #15
rsxnky02
Member # 1 Forcefed Tuner
rsxnky02's Avatar
stainless is a biotch to weld. a lot heavier, prolly more expensive. as far as the aluminum goes, if you can't find some1 2 weld it, prep it 4 welding and ill weld it up 4 u. how thick is it? im certified alum. mig and alum. tig.
Forcefed Tuning
Member # 1
2002 SSM acura rsx type-s
ESMM - DCRH - AEM V2 - Tsudo Fireball - CC Stage 4 - Quaiffe - Redline - FT customs
rsxnky02 is offline   Reply With Quote
Old 03-02-2006, 10:28 AM   #16
Djstorm100
Boostifed
Djstorm100's Avatar
its all in how you prep to weld it, i know how to weld ss, or atleast i got a master welder up the road from me, that i'm good friends with
Old 03-02-2006, 07:01 PM   #17
RSX4U2NV
...gOt boOst
RSX4U2NV's Avatar
I have a custom 3in SS(kteller) exhaust for my car w/out any problems. And SS won't rust,it will last a life time. Aluminum will rust over time.
~F/S* DC5R INSERTS~
~My Feed Backs~
~More Pic of my car~
[Greddy Turbo]FMIC HKS BOV[JDM]valve cover[JDM]spark plug cover[JDM]steering wheel[JDM]pedals[JDM]console w/ebrake[JDM]floor mats[JDM]carpet[JDM]shift knob [JDM]headlight w/12000K[MUGEN]front&rear struct brace[MUGEN]reservoir covers[HENSHIN]full BC2 body kit[SEIBON]CF fenders[LEXUS]rx330 white crystal pearl paint[SEIBON]evoII carbon fiber hood[VIS]carbon fiber trunk[JDM]side markers[][J8pro] 19's[Takata]harness
RSX4U2NV is offline   Reply With Quote
Old 03-02-2006, 09:05 PM   #18
Djstorm100
Boostifed
Djstorm100's Avatar
theres a different between alumized and aluminum
Old 03-02-2006, 09:21 PM   #19
RSX4U2NV
...gOt boOst
RSX4U2NV's Avatar
Aluminized will still get rusted down the line.
~F/S* DC5R INSERTS~
~My Feed Backs~
Old 03-03-2006, 12:19 AM   #20
rsxnky02
rsxnky02's Avatar
your correct. but i think its a little different than rust, its more or green shit, starts to look galvanized, good lord dont put galvanized on it. that crap is dangerous. sucks to weld 2. try drinking cold milk on a hot summer day. it sucks. but thats what the test called 4.
Forcefed Tuning
Member # 1
Old 03-03-2006, 10:32 AM   #21
RSX4U2NV
...gOt boOst
RSX4U2NV's Avatar
Here's a few pics of my 3in SS set up w/HKS Ti muffler
~F/S* DC5R INSERTS~
~My Feed Backs~
Old 03-03-2006, 10:34 AM   #22
RSX4U2NV
...gOt boOst
RSX4U2NV's Avatar
~F/S* DC5R INSERTS~
~My Feed Backs~
Old 03-09-2006, 04:46 PM   #23
SammySamSam
turbo=neverending debt
SammySamSam's Avatar
I also want to redo my piping, but i dont kno which size to get. I am using the greddy turbo kit on my car with the greddy fmic. What size piping does greddy use on the fmic? is it 2.25 or 2.5? Also, will my hks ssqv BOV be able to fit on both 2.25. or 2.5 piping with the same flange(the universal one i got from hks) that i have?
03 NightHawk Black Pearl Type S,Greddy Turbo,FMIC,K-pro,
unforgettable Test pipe, Natedog 3" DP,2.5" DC Dual Cannister Exhaust,
Wings West Evo style CF hood, 18" buddy club sf
new project:t3/to4e garrett/borg warner hybrid
SammySamSam is offline   Reply With Quote
Reply
Bookmarks
alum, pipinghmm, stainless
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
