#101 | |
0 to 1320...
so using a -6 bulkhead would require the least amount of modification to the top part of the pump assembly? Then using a -8 to -6 reducer, run a -8 feed to an inline filter then rail.
WWW.TEAMXXXRACING.COM
race team | online parts store '02 RSX-S Turbo :: 11.466 @ 122.91 AIM - teamXXXracing |
#102 | |
Demonic
I hacked out the top regulator/venturi, this opened up a lot of space. Drilled and tap the -8 AN bulkhead on the center of the cap, make sure you have an O-ring to make sure the pressure will not leak out of the tank. Once the bulkhead is on there, use the -8 AN hose end and connect to it, make sure it is tighten down fully or the fitting will not hold the up to the bulkhead and you will end up popping off the fitting...no more fuel LOL. It is tricky so that is why a lot of ppl just tap to the side of the regulator so that you can fit a open end wrench in there to tighten it up. I used a crow foot to get mine on. |
#104 | |
0 to 1320...
#106 |
0 to 1320...
drop the tank... no, but loosen the bolts on the drv side that hold the tank up and use a pry bar to push the tank away so you can snake the fuel lines in between.
#107 |
k20 valve cover FS!!!!!!!
I can vouch that if you don't make that cut to let the walboro fit in, your car will not crank up and if it does, it will barely come on.. .. It happened to me today... LOL This guy at a shop didn't mod anything and just dropped the walboro in and the o-ring was leaking fuel like crazy, took 5 times to crank the car up and then he test drove it and it hit lean cut everytime he tried to floor it.. Thank god for Hondata or my motor would be toast now... BTW, the mechanic thought my jrsc was a turbo.. GOD, i should of tried to do the install myself...
FORSALE: FS: k20 valve cover, k20 sparkplug cover, k20 intake manifold cover NEW Tial 44mm wg springs(2.9/4.1psi), NEW o2 extension, 06 oem RSX Type S injectors with clips, and NEW Gatorback 4070775 belt.. My forsale thread http://forums.clubrsx.com/showthread...3#post23954863RSX Type-Srt-4 Member # 1 Boost Slut Krew Member # 5 Last edited by Axix23; 04-18-2008 at 06:41 PM. |
#109 |
actually, i went to a local performance shop that just happened to use some kid to install my fuel pump.. Finally some experience asian mechanic fixed it in like 10 min. and it started up and drove like a charm... thank god, it only costed me like $65
FORSALE: FS: k20 valve cover, k20 sparkplug cover, k20 intake manifold cover NEW Tial 44mm wg springs(2.9/4.1psi), NEW o2 extension, 06 oem RSX Type S injectors with clips, and NEW Gatorback 4070775 belt.. My forsale thread http://forums.clubrsx.com/showthread...3#post23954863RSX Type-Srt-4 Member # 1 Boost Slut Krew Member # 5 |
#110 |
is it true when u run your fuel tank very low often, that it will burn out your fuel pump? I hear soo many diff. stories about this myth...
#111 |
Senior Member
I've heard people say that running the fuel low will allow the pump to overheat and burn it up. But consider there is 255 lph moving 'through' the pump (where the electric motor actually is), plus - the Acura pump sets in that plastic 'bathtub' that is always full of fuel - you should have plenty of cooling right up until you run out of gas.
One thing to consider is that when the fuel gets low, that last gallon or so is making quite a few trips through the pump (and up to the engine and back if you have a return line) so it's getting the fuel pretty hot. It may not be the best for performance, but as far as keeping the fuel pump cool, it should be fine.
Corey 02 NBP Type S • E85 Fueled • CN Turbo • Kpro • RC 750's • CC Stage 4 • OBX LSD • TSX 6th gear set • 3” Custom SS Exhaust Fight for your driving rights - www.motorists.com - Member #222205
#112 |
how many lph is the factory rsx fuel pump?
#113 |
BSK#17 Whale Penis Power!
this guide worked amazing, thanks palmerblock, this took me 45 minutes and I've never done anything with a fuel pump before.
#114 |
Fully Boosted
any DIY on removing the backseat and getting the fuel pump out because the other links dont work anymore
ABP Crew Member #30 BOOSTED! 346Whp, 285Trq Boost Slut Krew Member #7 ![]() My 04 Turbocharged ABP RSX-S DIY: Full Race Greddy upgrade install DIY: Low/High Boost switch |
#115 |
I <3 Bewst
It's really easy there are hinges on the seat that you would have to undo from the seat if you want the backs to be removed (makes it easier). Then the bottom of the seat sort of is locked in place. If you pull up hard enough the bottom will sort of unbuckle itself. Next your gonna have to remove the fuel pump cover. There are 4 bolts. After that all you need to do is unscrew the black ring that seals/holds the fuel pump assembly in the tank. It's easy as pie.
Full Race Stage 3 Gt35R kit Pump: 426 whp @ 1 bar / Race: 522.7 whp @ 1.3 bar And of course [MASE'D] ABP CREW #27 ![]() Full-Race Twinscroll S366 Build (2010) - 700+whp or bust ![]() ![]() |
#116 |
The Architect™
Jeff, sounds like you need to get a copy of the helms manual. The rear seat is really easy to pull off.
St00pid Tuned 06' RSX Type-S, Peakboost Turbo Kit
w/ GT3076 Turbo 400whp & 280ft/lbs on pump partially tuned ![]() PeakBoost krewmember #1 Boost Slut Krew Member #4 Buy my turbo RSXhttp://forums.clubrsx.com/showthread.php?t=694002 |
#117 |
Boosted Goose
this thread was def helpful during the installation, but my case around the fuel pump didnt close ALL the way but 3 of the 4 clips are close is that going to hurt it or mess it up? and also I didn't need any special zip ties right?
#118 |
Southern Discomfort
Just did mine today. my case didnt close very well and i was a little forceful getting 3 of the clips to snap but it works great.
Thanks for the pictures, they def helped me!
Domestic fan boi WAT? Miranda Kerr Run Crew member Type-S Fuel Injectors for sale. |
#119 |
Alky fed rat.
Just to clarify, The bulkhead fitting is -6an and adapted to a -8an feed line? Does that contradict the use of a -8an line?
#121 | |
0 to 1320...
Not necessarily cause the outlet on the Walbro is basically a -6 size or a little smaller... so running that to a -6 bulkhead and then a -8 line works fine. Thats how i've run mine with no problems.
#122 | |
Alky fed rat.
Thanks. Regarding the submersible line frome gates, I see that there are 2 lines at the pump, 1 for the return and 1 for the pump to bulkhead feed, both are required or is 1 a factory piece that I will reuse? 20.00 for a 1ft piece is crazy! |
#123 | |
0 to 1320...
#124 | |
New Member
What can I use to plug the unused end???? |
| Bookmarks |
| Tags |
| 255lp, fpr, installstock, walbro |
| Thread Tools | |
