#1 |
Master Mechanic/Tuner
Buddy Club N+ Racing Dampner Install Thread...56k will die
lets make it simple and sweet...this thread is primarily to give you guys a visual aid on these particular coilovers and the install itself
if you need more technical info, fell free to ask me or wait for another members detailed write up on the intall....again this is more of a visual thread...USE YOUR EYE BALLS ALSO SPECIAL THANKS TO ANDREW sikdalla i bought the coilovers from him, AND ALBERT BuddyClub-CL9 for helping me with the pre setup info PRE-SETUP INFO Rear disassemble the entire shock boddy down to this set the height accordingly....view the picture...i set mine to 1.7in drop which was 11.3cm for me ![]() lock it...the 11.3 cm measurement i got didnt include the locking perch...it was after the perch...DO NOT MIX THIS UP reassemble accordingly...follow the pics
2069cc_9.5:1_Project X 661hp, 398tq @9600rpm Dynojet Bonneville 200 Mph Club Life Member D-Mac Enterprises (INSTALLS) Church Automotive Testing F.S. K20Z3 Long Block $1600 http://forums.clubrsx.com/showthread.php?t=682372 Last edited by palmerblock; 02-21-2006 at 02:54 PM. |
#2 |
b4 this step tighten the 14mm bolt on the top of the shock body all the way tight so you wont get inaccurate readings on the next steps
were still assembling at this point, but now its time for the spring preload...THERE ISNT NONE...set to 15cm which equals 150mm.... for reference mine is set at 15cm on both shock bodies ![]() lock it and double check measurement....AFTER THIS STEP, LOOSEN THE 14MM BOLT ON TOP OF THE SHOCK BODY (do not remove the bolt, just have it barely hand tight) TO ALLOW THE SHOCK BODY TO MOVE WHILE INSTALLING IT ON THE CAR...ONCE SHOCK BODY ITS BOLTED TO THE LOWER CONTROL ARM...view the instuctions below (POST #5) on how to approach the next step once the rear shocks are on the car FRONT make sure the rubber on the front struts is like this so you wont get inaccurate readings between the two...take off the top bearing to view this...which is under the mount that connects to the car----> on the top of the shock body tighten down the 19mm bolt on the top all the way tight, then set spring preload...THERE ISNT ANY....set to 20cm which equals 200mm for reference i set mine to 20cm +/-0.4 between the two due to spring length measure accordindly...once spring preload is set lock the first perch with the second one Next, set the shock height or the drop you want 1cm = 3in drop, 2cm = 2in drop, 3cm = 1in drop for reference i set mine at 1.7 in drop which equaled 2.3cm you set the height by measuring between perch 2 and 3...once height desired is met, lock it by rotating the black part of the strut until it meets the bottom perch...tighten down and make sure bottom perch doesnt move so your measurement wont go off
2069cc_9.5:1_Project X 661hp, 398tq @9600rpm Dynojet Bonneville 200 Mph Club Life Member D-Mac Enterprises (INSTALLS) Church Automotive Testing F.S. K20Z3 Long Block $1600 http://forums.clubrsx.com/showthread.php?t=682372 Last edited by palmerblock; 02-26-2006 at 03:44 AM. |
#3 |
my car on eiback sportlines and stock shocks...i hate how the rear was lower than the front
now start disconnecting the suspension...i started with the front
2069cc_9.5:1_Project X 661hp, 398tq @9600rpm Dynojet Bonneville 200 Mph Club Life Member D-Mac Enterprises (INSTALLS) Church Automotive Testing F.S. K20Z3 Long Block $1600 http://forums.clubrsx.com/showthread.php?t=682372 |
#4 |
now the buddy clubs go in....go ahead and unlock the toe bolts as your toe will be WAY OFF...dont adjust it until you car is finshed and on the ground
this is how i delt with the break line and abs b.s. now for the rear...you may need a jack to help you realign things once the new shocks are in unless your a muscle head and can lift against the bushings...you also may need a jack to relieve the stress on the camber kit (whether stock or aftermarket) when your removing them and reinstalling them
2069cc_9.5:1_Project X 661hp, 398tq @9600rpm Dynojet Bonneville 200 Mph Club Life Member D-Mac Enterprises (INSTALLS) Church Automotive Testing F.S. K20Z3 Long Block $1600 http://forums.clubrsx.com/showthread.php?t=682372 Last edited by palmerblock; 02-21-2006 at 02:44 PM. |
#5 |
now the buddy clubs go in...ONCE YOU GET THEM IN, USE A HAMMER AND FLAT HEAD SCREW DRIVER AND TAP THE HEIGHT ADJUSTMENT LOCKING PERCH TO INSURE THAT IT IS INDEED TIGHT...ALSO DONT FORGET TO MAKE SURE THE 14MM BOLT IS TIGHTEN DOWN AFTER THE SHOCKS HAVE BEEN INSTALLED ON THE CAR....WHEN TIGHTENING THE 14MM BOLT ON THE TOP, PRELOAD THE ENTIRE SHOCK WITH A JACK TO MAKE SURE THE EVERYTHING IS SEATED PROPERLY SINCE THE CONTROL ARM WILL WANT TO PULL DOWN ON THE SHOCK BODIES SINCE IT PUTS THE INITIAL HEIGHT HIGHER UP IN THE WHEEL WELL VERSUS STOCK STRUTS
right after i lowered the car..toe is way off....then i reset it and off to the alignment machine i go since i have a lifetime alignement, why not use it..i can go whenever i want and change settings to whatever i want after alginment camber front -0.9 - camber rear -1.0 - toe and caster are in spec post notes i have my drop set the way i do on purpose since i drag primarily...im not into the slammed look/tucked look/whatever... i just wanted to replace my shitty suspension setup i had...and the car handles great now any questions?... any answers?...
2069cc_9.5:1_Project X 661hp, 398tq @9600rpm Dynojet Bonneville 200 Mph Club Life Member D-Mac Enterprises (INSTALLS) Church Automotive Testing F.S. K20Z3 Long Block $1600 http://forums.clubrsx.com/showthread.php?t=682372 Last edited by palmerblock; 02-22-2006 at 04:14 PM. |
#8 |
Master Member
nice drop can go a lil lower tho..
even tho you set front and rear both to 1.7.. the rear is gonna have a smaller wheel well gap.. cuz of the way our fenders are designed.. the back is a smaller cut out..
'06 Lex IS250 Black on Black on Black Tint
#9 | |
#12 |
Name's Vic
haha yea u mean my detailed write up? this is very nice i might not have to show people how to put em together and adjust em since this is already well done it answers all my questions without having them in front of me.
I will have a detailed install and detailed review, my new alignment machine should be shortly to so i can make al lthe necessary adjustments. Palmer what did u mean by loosening the toe bolts? im gonna take the tie rod out of the strut and put it back in the buddy club
Canon Crew Member #3.MC crew #Slevin. Nutella Crew Member #1 (founder).Armenian crsx crew member #6 02 RSX-S 160k mi, 14.5 @97. 02 F4i 20k mi, stoopid fast. |
#13 |
I love my rally car
wow good writeup
Vid of me at streets of willow http://youtube.com/watch?v=rWNnDO7EHMw My picture trail Join the anti-drag racing crew
20MPG Crew ![]() |
#14 |
Buddy Club
Thanks Daniel
#15 |
i keep it clean
nice write-up daniel...the explanation with those pics makes it easier to understand how to make adjustments...seems like a great coilover
05 SSM Type-S....SOLD!! Buddy Club - DC Sports - eD - Fujitsubo - HOP - Ingalls - Injen - JL Audio - Kenwood - Mugen 05 Subaru Impreza WRX Sti
#17 |
ooohgen whore
awesome write up! next time could u start working on it a little earlier so by the time you still finish you can take some daylight pics?!
#18 |
i will take some more pics tomorrow guys...been sleepy all day, lol
#21 |
i will answer all other questions in a couple of hours...but just a quick update....
i changed the directions a lil to avoid problems with these coilovers.....the changes i made are in color red and are bold....follow them directly and you wont have a problem for those wondering why i added those directions...in breif...my rear driver side shock body height locking perch came loose and i was hearing clunking noises all over the place when i hit any type of inperfection in the road...they are fixed now and i have adjusted the instructions on this thread accordindly
2069cc_9.5:1_Project X 661hp, 398tq @9600rpm Dynojet Bonneville 200 Mph Club Life Member D-Mac Enterprises (INSTALLS) Church Automotive Testing F.S. K20Z3 Long Block $1600 http://forums.clubrsx.com/showthread.php?t=682372 Last edited by palmerblock; 02-22-2006 at 04:25 PM. |
#23 | ||||
thanks for all the comments guys...just tryin to make the install easier for the rest of you
but yes they are smaller in diameter but are wider to improve traction, which i what i need with my setup ![]() Quote:
you can throw it on the rack anytime you want...ie. if you take off your subframe and want to check the alignment afterwards, or change suspension, or even get new tires....
2069cc_9.5:1_Project X 661hp, 398tq @9600rpm Dynojet Bonneville 200 Mph Club Life Member D-Mac Enterprises (INSTALLS) Church Automotive Testing F.S. K20Z3 Long Block $1600 http://forums.clubrsx.com/showthread.php?t=682372 Last edited by palmerblock; 02-22-2006 at 06:45 PM. |
#25 |
Name's Vic
i still dont get the loosening to toe nut, doesnt sound to good to me toe will be fucked up anyways if i see its off ill try to adjust it by eye but dosnt matter to me im getting an alignment machine soon at my shop. So lifetime alignments and its free plus i get to fuck up my car not someone else lol
| Bookmarks |
| Tags |
| buddy, club, dampner, die, install, racing, thread56k |
| Thread Tools | |
