Go Back   Club RSX Message Board > PERFORMANCE BASICS > All Motor
Reply
Thread Tools
Old 04-10-2006, 05:48 PM   #1
chunky
frank and beans!
chunky's Avatar
For anyone that's killed their stock motor mounts
I recently had an issue with my motor mounts that caused some serious problems for me. Previously I had the ES MM inserts. Well, they eventually wore out and my stock front motor mount was torn. This allowed a lot of extra play which led to vibration that knocked my front motor mount bolt loose. So then one fine day after a hard 2-3 shift, the engine rocks back so hard that it pulls off the lower radiator hose! As you might imagine, it wasn't a pleasant feeling to hear a THUNK as the valve cover hit the underside of my seibon hood, and then, seeing a cloud of white vapor ensuring a safe getaway from any potential pursuers.
Anyhow, I hate paying excess prices for things I can do myself so I started looking into polyurethane mixes with which I could "rebuild" my stock motor mounts. Because hey, the brackets were just fine, AND they're cast aluminum so they're strong and light.
Lo and behold, I came across some polyurethane products that looked like they'd work. So yesterday I rebuilt my stock mounts to what is essentially race mount hardness using the stock mounts. I doubt most people would want their mounts as firm as I have, but there are softer polyurethane products that will work and have more give.
I thought about using the tried and true "window weld" fix, but the cure time on it was kind of ridiculous. I settled on some 3m 2 part poly urethane mixes. It's part of their "Scotch-weld" lineup of products. These products certainly weren't cheap (they required the purchase of a rather expensive applicator gun AND you have to use a new disposable nozzle for each bottle of stuff you use), but they had really short cure times AND were much firmer than window weld. For reference, window weld has a hardness of 55A and the products I used had a hardness of 70D and 85A respectively.
The front mount I wanted to be basically solid with very little give at all. I used the 3M DP601-NS product. This stuff is HARD. It's a polyurethane, so it won't crack, and it has an adhesive strength of 2000+psi. Anyhow, the NS means "no sag" which means that it comes out thick and won't run. They also sell a self leveling version of the product which comes out looking a little nicer, but it's harder to work with. Anyhow, here's how the front mount looked after I was done.
I just filled the holes in the stock rubber mount (as well as putting some inbetween the two parts that tore). This mount cured fully in about an hour. You have to be very careful when putting the mount back on the car b/c the mount is solid, everything has to line up really well b/c you can't flex the mount into place like with the stock stuff.
For the rear mount, I did something a little unique. I wanted the mount to be as firm as possible, but I also wanted some give so that the idle was reasonable. The solution was to use the ultra-firm stuff on the top, and the softer stuff on the bottom. The softer mix is the DP604-NS. This stuff is rated to 900psi and cures in 6 hours. The great thing about these mixes is that they don't require heat or application in thin layers to cure all the way. It's a 2 part chemical reaction that occurs so you fill the whole mount in a single step.
I coated the whole outside with the black stuff just so it looked a little better. In the future I'll be able to make these a LOT prettier. I was pressed for time so I didn't get to make it look pretty by leveling with a spatula or something.
So the final result - these mounts are FIRM. There is still some give b/c the stock rubber is still inside. As a result, Idle didn't change much from when I had just the ES MM inserts. There is more vibration at low rpm between 2000-2500rpm. Highway cruising is about the same as before.
When I step on the gas with these mounts, there is zero hesitation. The car just gets up and GOES. The power goes into turning the wheels, not into compressing the mounts.
Oh, here's what my ES MM insert looked like after about 90k miles
It was destroyed. For anyone that drives agressively, this is definitely the low cost alternative for buying full new mounts. I wouldn't really reccomend that anyone use the gray stuff unless they're hardcore like me, but the black stuff is a good product and it will turn your mounts into the equivalent of a solid polyurethane mount.
The most expensive part of this was buying the mixer gun. How could something so tiny cost so much.
Here's the used containers. If it wasn't for that gun and the rush shipping I paid, I could have easily done both mounts for under $70. Not bad considering how much new polyurethane mounts go for. My front is actually stiffer than just about anything that is commercially availible.
On the bright side, if I ever have to do it again, I can do it for cheap. Oh, and there is no wheel hop. whatsoever. at all. :mgrin:
2002 ep3 - you may call her estella, current: IPS K2 Mark III coming soon, Click to see full mod list
All Motor crew: lucky #7
You can take me out of the race, but you can't take the race out of me.
chunky is offline   Reply With Quote
Old 04-10-2006, 07:20 PM   #2
9bells
fabricator supremo
9bells's Avatar
Nice job and write up. Thanks for sharing, it will be in my future..
13.5@101.5 @3500ft
higherarcing.com
9bells is offline   Reply With Quote
Old 04-10-2006, 07:27 PM   #3
chunky
frank and beans!
chunky's Avatar
Hopefully you will make yours look prettier than mine. I didn't have much time to complete the job so I blazed through it.
Are you gonna go for the gray stuff or just do the black stuff all around?
Also, I forgot to mention, this stuff is rated from -65deg to 250deg, so it's good for use in the engine bay unlike some of the other stuff people use on similar projects..
Old 04-10-2006, 07:30 PM   #4
mdoyle
Senior Member
mdoyle's Avatar
Hhhm... I might do this with my front mount.. already have a free Hasport rear in
mdoyle is offline   Reply With Quote
Old 04-10-2006, 08:58 PM   #5
9bells
fabricator supremo
9bells's Avatar
Not sure, maybe grey stuff all around!!!
I don't really care about looks though.
I will likely just slop it in good, and trim excess with blade.
13.5@101.5 @3500ft
higherarcing.com
Old 04-10-2006, 09:22 PM   #6
Drewk20z1
Drewls6/K24A8
Drewk20z1's Avatar
yeah we use those huns some at work and they cost to damn much
crews are gay
Drewk20z1 is offline   Reply With Quote
Old 04-10-2006, 10:13 PM   #7
05_DC5
Senior Member
nice work
06 with stuff to come
05_DC5 is offline   Reply With Quote
Old 04-10-2006, 10:27 PM   #8
boix
BOIX bitch! eff yo couch
boix's Avatar
oh man that is slick. very good application.
back to stock
oh injen CAI thats about it
boix is offline   Reply With Quote
Old 04-11-2006, 12:34 AM   #9
Sikboy
New Member
I have heard people using "sikaflex" to fill in the mounts. Its stuff that body kit installers use to glue lip kits on. Its probably not as stiff and hard though.
"If you don't stick it, you can't claim it"
Sikboy is offline   Reply With Quote
Old 04-11-2006, 01:57 AM   #10
park83rsx
Master Member
park83rsx's Avatar
park83rsx is an unknown quantity on c-rsx
Nice. I'll have to remember that in the future. We used something else on a friend's car and had to do it layer by layer, so it would cure.
park83rsx is offline   Reply With Quote
Old 04-11-2006, 08:45 AM   #11
chunky
frank and beans!
chunky's Avatar
do ittt!!!!
I can't even begin to explain how much better the car feels initially when applying throttle.
If you're local, to ATL or baltimore, you can borrow my applicator gun.
Old 04-11-2006, 08:47 AM   #12
chunky
frank and beans!
chunky's Avatar
Yah, the gray stuff is easy to trim with a blad b/c of its firmness. Gray stuff all around would be pretty nuts. I like mine the way it is. Vibration is not bad at all at idle. just when you're getting moving at low rpm. other than that, I hardly notice a difference from the MM inserts.
Old 04-11-2006, 08:48 AM   #13
chunky
frank and beans!
chunky's Avatar
Yeah. That would have been bad for me. I had to do two mounts in a day. And it HAD to be done since I was driving from ATL to baltimore the next day.
Old 04-11-2006, 10:55 AM   #14
BlackNite
SS Specialist to the 6th
Nice. I might do that to my front and then get hasport rear mount
BlackNite is offline   Reply With Quote
Old 04-11-2006, 11:28 AM   #15
sifrx
Master Member
sifrx's Avatar
so Im guessing you really beat the shit out of your car lol
Blog = 1337 and bored
sifrx is offline   Reply With Quote
Old 04-11-2006, 11:38 AM   #16
chunky
frank and beans!
chunky's Avatar
why wouldn't you just do both? It's not like the hasport would offer any real advantages over something like from a function standpoint. It's a lot prettier though.
Old 04-11-2006, 11:39 AM   #17
chunky
frank and beans!
chunky's Avatar
it's a 2002, with 132k miles. as I like to put it, the upper regions of the tach are well loved.
Old 04-11-2006, 11:43 AM   #18
Stitch
Mazda Speed Crew Bitch
i think thats an udnerstatement for tearing a mount to shit with esmm on it
fuck you
Stitch is offline   Reply With Quote
Old 04-11-2006, 11:55 AM   #19
park83rsx
Master Member
park83rsx's Avatar
It was pretty funny when we messed up by not applying it in layers. Even after letting them set for quite a while, we took it for a drive and the filler just shot out.
Old 04-11-2006, 01:00 PM   #20
sifrx
Master Member
sifrx's Avatar
damn you really must love driving. I wish i had that much time to put that much on mine lol.
Old 04-15-2006, 02:26 PM   #21
chunky
frank and beans!
chunky's Avatar
Well, I finally got around to taking a look at my passenger side mount.
Did you guys know that it's liquid filled? the top of mine had sheared completely off (pics coming later on) exposing the insides of the mount fully (and spraying a bunch of dark shock fluid all over). Anyhow, it is now a solid polyurethane mount.
I'm going to let it cure fully before putting it on the car. I'll give you guys my impressions at about 8-10pm tonight. Hopefully this will fix the random knocks that i've been getting while going over big bumps on the road etc.
Old 04-17-2006, 05:01 PM   #22
BarracksSi
Master Member
BarracksSi's Avatar
Cool -- consider me subscribed.
ITR, FG2, Quaife, etc. LSD? I want one....
Titanic must lose. Go see The Dark Knight again and again.
BarracksSi is offline   Reply With Quote
Old 07-10-2006, 09:37 PM   #23
cwesttypes
Senior Member
cwesttypes's Avatar
So hows the car with all the 3m urethane mounts? Does it vibrate real bad? Did you use the grey or black urethane for the passanger mount? I just used three tubes of the grey 3m urethane to do the front and rear. I'm debating on doing the sides in grey. I didn't use a gun to apply it. I just took a bolt and pushed the epoxy out and mixed it then appy it with a stick.
cwesttypes is offline   Reply With Quote
Old 07-14-2006, 12:55 AM   #24
cwesttypes
Senior Member
cwesttypes's Avatar
I just got finished testing my diy grey front and rear mounts. All I can say is, I wish I would have done it sooner. The car at idle feels like esmm slight less vibs. More vibrations at 1k to 3k rpm. The car feels more stable and handles better. No wheel hop. The car seems faster. When vtec kicks in it pulls like crazy with 12psi. I'm very happy with this mod. Wonder how the sides filled with this stuff would feel like? Have you done this yet Chunky?
Old 10-30-2006, 11:00 AM   #25
chunky
frank and beans!
chunky's Avatar
Originally Posted by black dc5 View Post
Just bumping this thread (even if it's old ) to see if anyone else has done this. I have stock mounts laying around and I'm tempted...but I'd want something less aggressive, yet that would limit engine movement enough to support the use of race header--think using the black stuff will suffice?
well, the black stuff is still pretty firm. I used it for my rear and passenger side mount. The stuff is holding up great, launches are still smooth. if I had an LSD and 225's on the car, I could get off the line really hard and not worry about the drivetrain.
Reply
Bookmarks
killed, motor, mounts, stock
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
