Go Back   Club RSX Message Board > GENERAL > The DIY Garage
Reply
Thread Tools
Old 06-03-2006, 01:09 AM   #1
KSMatic
Sidemarker Mechanic
KSMatic's Avatar
KSMatic might be well recognized one day on c-rsxKSMatic might be well recognized one day on c-rsxKSMatic might be well recognized one day on c-rsxKSMatic might be well recognized one day on c-rsxKSMatic might be well recognized one day on c-rsxKSMatic might be well recognized one day on c-rsxKSMatic might be well recognized one day on c-rsx
DIY Guide: How to Install S2000 Push Start Button. (Visual Guide)
Please do not PM me about you having problems doing this and that, i am not a live tech support. I do however have two sets for sale and the panel is also for sale as well.
So after selling 3 units and having one returned due to lack of knowledge of how to install the whole thing and with all the damn threads out there about S2000 Push Start, i guess i have to narrow it down and make this thread for the person and for everyone to see.
DIY S2000 Push Start Button, Installation Steps Only.
Time:
- 20 to 40 minutes
Tools and material needed:
- S2000 Push Start Button with plug or soldered wires on to the 3 pin.
(Green for Output, Red for Power and Black for Ground, 5 pin, 1-green 2-red 3-green 4-5-useless)
- 12Volt 30A Relay
- Wire Cutter
- 4 feet 16-18 guage stranded wire
- Wire Crimper
- female adaptors plugs
- Voltage Tester if needed.
- Electrical Tape
Difficulty:
Medium
Step 1:
Make sure you have your tool box handy, along with all the nice little adaptors you may need. I should clean my shit up
Step 2:
Remove the Steering Column, you need to remove this to gain access to the ignition wires located underneath the key hole.
Step 3:
Now that its removed, locate the brown 8 pin plug, (displayed in the pic with the blue tape)
Step 4:
You need to run about two 20" wires, 16-18 guage wires from ignition to where ever you are going to locate your S2000 push start button.
Connect one wire to WHITE and another to BLACK/WHITE.
Step 5:
LOCATION: Some people perfer to locate the S2000 by the Cigarette lighter area.
[IMG]www.socaldc5.com/S2000/DSC08708.JPG[/IMG]
Step 5-A
Remove the panel
[IMG]www.socaldc5.com/S2000/DSC08709.JPG[/IMG]
Step 5-B
Remove plug from cigarette plug and locate the wires, you will need to tap positive and ground from here. YELLOW/GREEN = Positive BLACK = GROUND
NOW, run the wire to where you are going to locate the S2000 push start button.
One thing with that, your passenger can be messing with the button and will cause some damage to your starter if not used properly.
I have locate mines by the Driver side control panel so i will continue from there.
ClubRSX Super Moderator: Southern California Regional Forum
Need Installation? So Cal Installer here to service the RSX/Import Community
05 Acura RSX Type S
2008 BMW M3 6 Speed Convertible Alpine White
KSMatic is offline   Reply With Quote
Old 06-03-2006, 01:10 AM   #2
KSMatic
Sidemarker Mechanic
KSMatic's Avatar
Step 6
Get the two wires coming from the ignition and tap them in to the relay. Connection point can be either: 87 and 30. Can be reversed.
Step 7:
Time to connect the S2000 Push Start Button, connect the green wire from the S2000 to relay point 85.
Step 8:
Connect the Power and Ground to the S2000 push start button and slice the ground wire and connect to the relay point 86.
Step 9:
Finish Product.
VIDEO:
Video 1 - Shows how i try to start the car first without holding down the clutch and after i do. (Type S) Yes, i see my car knocking
Troubleshoot:
if there is no power, please check all your fuses and see if everything is still up and running. Also, make sure you tape up everything or else it might cause a short.
05 Acura RSX Type S
Old 06-03-2006, 01:28 AM   #3
IVtecDaily
Member
Also dont forget to turn on your cruise control since you're gettin rid of the button...dont know if it stays on when you restart your car tho...
2002 DSM RSX Type S
Installed Mods: Comptech 22mm Rear Sway w/ energy poly bushings :: Eibach Pro Kit
IVtecDaily is offline   Reply With Quote
Old 06-03-2006, 01:58 AM   #4
MKpoto
Formerly Trvotypes
MKpoto's Avatar
thanks ksmatic..
but this was exactly how my friend did it
Top Down Crew#2
FUTURE: E92 M3/335I/135I SO BUY MY CAR!
Current: FOR SALE!! 05 NFR Honda S2000
Past:03 Acura Rsx Type S Turbo 300whp 210tq on 7.5 Greddy- SOLD
MKpoto is offline   Reply With Quote
Old 06-03-2006, 02:02 AM   #5
KSMatic
Sidemarker Mechanic
KSMatic's Avatar
Originally Posted by trvotypes
thanks ksmatic..
i wasnt talking about you. it was another guy who returned it
05 Acura RSX Type S
Old 06-03-2006, 02:23 AM   #6
MKpoto
Formerly Trvotypes
MKpoto's Avatar
hahah okay
Top Down Crew#2
Old 06-03-2006, 02:25 AM   #7
KSMatic
Sidemarker Mechanic
KSMatic's Avatar
hahah okay
i'll check it out and see..
did you check your fuse though? I will check the light bulb when it gets back to me lol
05 Acura RSX Type S
Old 06-03-2006, 03:05 AM   #8
dorkzracing
SiK DC5
dorkzracing's Avatar
nice DIY are you selling the other engine starter sets? if so, how much? i'm interested... Thankz
iT's Not a gAmE... It'S a LifE StyLe
Professionally tuned by Mike @ Elite Tuning
2003 RSX Type S : Picture Trail
1990 CRX Si : The latest project - Sold
1993 Civic Hatchback Si - Sold
1988 CRX Si - Sold
dorkzracing is offline   Reply With Quote
Old 06-03-2006, 11:20 AM   #9
KSMatic
Sidemarker Mechanic
KSMatic's Avatar
05 Acura RSX Type S
Old 06-04-2006, 05:36 PM   #10
flyguy7150
Master Member
flyguy7150's Avatar
Where can you get the relay from locally?? Radio shack?? also if i get this one http://cgi.ebay.com/ebaymotors/JDM-0...spagenameZWDVW can i just solder the wires to the back of the button or will i need the harness?
2004 NBP Acura RSX
>>>| WHP - 191.24 | TQ - 171.31 |<<<
| Dynotune Nitrous | Injen CAI | ESMM | Megan Racing Header | Megan Racing Test Pipe | Megan Racing M-N1 Custom Catback | Ground Wires | Tein S-Techs | BFGoodrich g-Force Sport | 5% and 15% Tint | Type-R Spoiler | Redouts | Blacked Out Headlights | PureVision HID's 8000k | Kenwood KDC-X590 | Elemental Design 13Kv.2 | Elemental Designs Nine.2 | Custom Hatch |
flyguy7150 is offline   Reply With Quote
Old 06-05-2006, 01:42 AM   #11
dorkzracing
SiK DC5
Yup RadioShack has them... i work there
1988 CRX Si - Sold
Old 06-05-2006, 03:39 PM   #12
stardotstar
Senior Member
stardotstar's Avatar
Awesome guide, btw how do you tell your car is knocking?
stardotstar is offline   Reply With Quote
Old 06-05-2006, 03:48 PM   #13
KSMatic
Sidemarker Mechanic
KSMatic's Avatar
i have my knock senor enabled and my check engine light was blinking.
05 Acura RSX Type S
Old 06-05-2006, 04:32 PM   #14
Truvietz916
Cult Ambassador
Truvietz916's Avatar
lol this is such a easy install... dunno why ur buyer backed out
Toda Package
Pictures!
www.norcaldc5.com
Truvietz916 is offline   Reply With Quote
Old 06-05-2006, 05:24 PM   #15
KSMatic
Sidemarker Mechanic
KSMatic's Avatar
cause they are probably color blind.
you still want my s2000?
you will get the one thats in the picture
05 Acura RSX Type S
Old 06-07-2006, 09:56 PM   #16
maranello
New Member
how much for the template? and how much for button + template?
email me at albin614@yahoo.com
seriously considering it.
100% COMPLETE 05 STOCK BABY! and whats more is... ITS AUTO!!! o yeah... you laugh at me now... ill laugh at you when you are stuck in traffic!
maranello is offline   Reply With Quote
Old 06-14-2006, 04:09 AM   #17
White.Type.S
JDM the new Rice
White.Type.S's Avatar
how did you put the s2000 start by ur mirror moving thing on the left side?
2006 Premium White Pearl RSX-S
WTB
+ 17" Rays engineering G games Gold w/ Polished lip
+ Koni Yellow's
+ Tein SS-P Spring's/Eibach pro kit
White.Type.S is offline   Reply With Quote
Old 06-16-2006, 12:02 AM   #18
igorski_89
respect my autoritay
igorski_89's Avatar
Originally Posted by KSMatic
Step 6
http://host210.ipowerweb.com/~lenawi...0/DSC08712.JPG
http://host210.ipowerweb.com/~lenawi...0/DSC08713.JPG
Step 7:
http://host210.ipowerweb.com/~lenawi...0/DSC08714.JPG
http://host210.ipowerweb.com/~lenawi...0/DSC08721.JPG
Step 8:
Step 9:
Finish Product.
http://host210.ipowerweb.com/~lenawi...0/DSC08728.JPG
VIDEO:
Troubleshoot:
i was wondering...did you order a special bracket or somtin to install he push start button.....cuz there is supposed to be 2 little rectangles for the roof an cruise control???
igorski_89 is offline   Reply With Quote
Old 06-16-2006, 12:09 AM   #19
KSMatic
Sidemarker Mechanic
KSMatic's Avatar
120 shipped + paypal 3.5%
for my s2000, relay and panel.
05 Acura RSX Type S
Old 06-16-2006, 12:14 AM   #20
maranello
New Member
you know you can buy the genuine s2000 button plus the relay for 65... so... how bout 85 shipped with the panel?
Old 06-16-2006, 12:15 AM   #21
KSMatic
Sidemarker Mechanic
KSMatic's Avatar
then go buy it.
05 Acura RSX Type S
Old 06-18-2006, 01:44 PM   #22
maranello
New Member
i want the panel
Old 06-18-2006, 01:57 PM   #23
Krisen Type-S
SEND EMAIL, NO PM!
Krisen Type-S's Avatar
i want the panel
its a pretty easy DIY, just takes patience
http://forums.clubrsx.com/showthread...ighlight=s2000
SEND EMAIL, NO PM!
03' RSX Type-S
GO LEAFS GO
Leafs > dog shit > Sens
Krisen Type-S is offline   Reply With Quote
Old 06-18-2006, 02:25 PM   #24
ITLNstallion818
New Member
this is so cool! nice write up!
ITLNstallion818 is offline   Reply With Quote
Old 06-20-2006, 08:44 PM   #25
maranello
New Member
thanks krisen
Reply
Bookmarks
button, diy, guide, install, push, s2000, start, visual
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
