Go Back   Club RSX Message Board > GENERAL > The DIY Garage
Reply
Thread Tools
Old 08-22-2006, 10:38 AM   #1
Heronbone
Official Janitor of ONE!
Heronbone's Avatar
Adjusting headlight height
I need some help on how to adjust the height of my headlights. Ever since I lowered my car I cant see shit unless I have my high beams on. I know that I have to have them shining on a wall to see how high they actually are, I just need to know which screws and such to turn and adjust. Can anyone help me out?
Heronbone is offline   Reply With Quote
Old 08-22-2006, 10:40 AM   #2
abowersrsx
Canon Crew
abowersrsx's Avatar
there are phillips headed screws on the backside of the headlight..stick a screwdriver in there and you can adjust your headlights up and down.
2003 SSM Type-S
Canon EOS Digital Rebel XTi
Canon 70-200mm f/4 L :: Canon 50mm f/1.8 II :: Canon 18-55mm f/3.5-5.6 :: Opteka Battery grip
abowersrsx is offline   Reply With Quote
Old 08-22-2006, 10:41 AM   #3
Heronbone
Heronbone's Avatar
thanks, I'll try tonight.
Old 08-22-2006, 10:46 AM   #4
abowersrsx
Canon Crew
abowersrsx's Avatar
not a problem. Just get out on an empty road, make sure you have a flashlight to see in the engine bay, and take a smaller screwdriver and it slides into the back part of the housing...you turn it and it will raise the level of the light pattern
2003 SSM Type-S
Old 08-22-2006, 01:19 PM   #5
n7plus1
Four Rings
n7plus1's Avatar
ah...this reminds me that i have to get this done tonight too.
2003 A4 1.8TQM
TRUTH IN ENGINEERING
[08:24] n7plus1: man, i think i may need some tighter pants for tonight
[08:24] smcdowell1977: HAHA
n7plus1 is offline   Reply With Quote
Old 08-25-2006, 06:10 AM   #6
jsantos
yoshi!!
jsantos's Avatar
sounds good...i was about to put up a thread about this also
:no signature acquired:
jsantos is offline   Reply With Quote
Old 08-28-2006, 12:37 AM   #7
magikal_one
Senior Member
magikal_one's Avatar
can someone post up a pic..? sorry noob questin.
magikal_one is offline   Reply With Quote
Old 08-28-2006, 02:26 PM   #8
Ar-Es-Ex
Master Member
Ar-Es-Ex's Avatar
i forget which way to rotate it to lower it, but you just stick a screwdriver in there and spin it to rotate the teeth of that thing. you'll be able to tell if its aiming higher or lower in a couple turns.
Click image for larger version
Ar-Es-Ex is offline   Reply With Quote
Reply
Bookmarks
adjusting, headlight, height
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
