#1 |
Still tuning....
My K24/K20 Boosted Build-up...w/pics.
As some of you know, my #1 cylinder rod decided to put a two holes in the side of my OEM block last week
. So I decided to do a little write-up of what I'm doing to get my car going again.After doing some research I found that going with a k24/k20 frank would be what I needed. A reliable way to get ~375-400whp on my daily driver, with some more torque to get around with. I went with a K24A1 motor...as in the entire motor that I got from a slavage yard. I paid $700 and drove home with it the same day. Just to make thing eaiser, when I say k20 I mean as in K20A2 (RSX-S parts), and k24 is in reference to K24A1 parts (2002 Honda CR-V). I dont know what the hell the k24a2, k24a3, or k24a4 parts will do with a k20 head. If you have any questions/comments...let me know and I'll try to help Heres what I found once I dropped the motor...
2002 Type-S Some Boosted Big Block Honda Shit
![]() PM FOR QUOTES AND PRICING For Sale: K20Z1 Shortblock with all new rod & main bearings...0 miles on rebuild Custom Intercooler Pipes, Custom Battery Relocation Trays, Custom 3" Revhard Downpipes. All Full SS/AL & TIG Welded Last edited by kracker; 02-11-2007 at 12:29 PM. |
#2 |
713
wow that snapped in half!
st00pified and Kpro'd RSX Base Auto w/ IPT Race Trans 260+whp/235+wtq 2010 BMW 335d w/ Sport Package
#3 |
Still tuning....
Before I pulled the motor out of my car I disassembled the k24 down to the longblock assembly. I took everything off...head, oil pan, oil pump, timing chain, guides, etc. The only thing on the stand was a block, crank, and 4 pistons & rods.
Then I pulled the motor out the car and put it on the stand. Then I tore that all the way down to the block as well. I was going to use everything possible off the k20 onto the k24.
#4 |
Still tuning....
There is a lot of talk about which oil pan and oil pump and baffle to use. I put my k20 oil pump onto the k24 block, and used a k20 oil baffle. The k24 is a big (counterweighted) oil pump, and I liked the idea of using the k20 instead. It bolted straight up with no modifications at all! The same is true for the baffle.
Make sure you use the k20 oil pump chain and tensioners. But use the k24 crank "sprocket" (timing and oil chain gear). It is marked just like the k20 is so you'll have no problems there.
#5 |
Bar'd TWICE
ohhh, nice!
06 CBR600RR 09 Toyota Pruis Full Loaded(Navi and leather) rolling @48.6mpg 01 EM2 - Built K24--PICS OF THE k24 EM2 NA tune 9:1...240.7 hp and 190.9 tq Stuff for Sale |
#6 |
Still tuning....
Now its time to put the head on and set up the timing.
I went with ARP studs, because I feel a lot safer running those on a boosted engine. Use a CR-V headgasket. You will have to use the k24 timing chain, guides, and I used the tensioner (could probley use either one). It is just like setting time in a k20 motor. Line up the sprocket to TDC, colored link on the sprocket (makes it eaiser/safer to make sure its in time), get the cams in position and set as needed.
#7 | |
Member
For safety/reliability I would use a new oil pump |
#8 |
Still tuning....
Now comes time to put the stuff onto the block.
You can use either crank pulley...I went with the k20 b/c its a little smaller and will give a slight "under-drive" to all the other belts driven accessories. The k24 pulley is larger than the k20. If you dont want to have the oil cooler hooked up you will save some time and $$. In order to run it you would have to take the block to a machine shop and have a part of it milled flat and drilled out. If you do want to run it, no big deal...but I dont think its worth it. If you decide not to use it (what I did) then its not that bad at all. You WILL have to run the k24 water pump. The k20 has an outlet for the oil cooler that I didn't feel safe to attempt to plug in any way. Simply remove the thermostat housing, alternator, and belt tensioner from the k20. Then remove the same from the k24. Use the k24 water pump block to go to the side of the motor. Then bolt up the alternator, tensioner, and thermostat housing. You could use the k24, but I felt safer using the k20 parts.
![]() PM FOR QUOTES AND PRICING For Sale: K20Z1 Shortblock with all new rod & main bearings...0 miles on rebuild Custom Intercooler Pipes, Custom Battery Relocation Trays, Custom 3" Revhard Downpipes. All Full SS/AL & TIG Welded Last edited by kracker; 02-11-2007 at 12:28 PM. |
#9 |
Still tuning....
Yes, I completely disassembled it and inspected it. Took it to a parts wash and thoroughly cleaned it and made 1000% sure there was nothing inside. I spent about 3 hours on that alone. There was no damage to the gear or gear housing inside the pump.
![]() PM FOR QUOTES AND PRICING For Sale: K20Z1 Shortblock with all new rod & main bearings...0 miles on rebuild Custom Intercooler Pipes, Custom Battery Relocation Trays, Custom 3" Revhard Downpipes. All Full SS/AL & TIG Welded |
#10 |
Still tuning....
You will also have to use the k24 side motor mount...the k20 will not work. Mine didnt come with the top part of it, so I robbed it off the k20. The bottom it the part that has to mate up to the cover/motor.
I also used the k20 oil pan. You will need the bolts from that also, the k24 bolts are too short. This back pic is it nearly assembled. I need to put the plug in above the oil filter and run my braided line off the oil pressure sensor hole on the back.
#11 |
Still tuning....
The only other thing is that you'll need to get some spacers. I made mine 19.7mm and it worked perfectly...a stack of washers will also work. Because the block is ~20mm taller, the intake manifold brackets will not reach without a spacer of some kind.
Here is a pic of the 3" downpipe that will be going to the straight 3" exhaust
#13 |
Still tuning....
After all that was said and done, I dropped the motor into the car and put the tranny on. Thats where it sits now, till I have some time to work on it.
I figure I have ~25-30 hours total in it, and ~$750...not too bad. BTW, you'll have to use the k24 dip stick...k20 is too short. I'll put up my driving impressions once I get it on the road.
#14 |
10.801@137.72
nice progress. I cant believe the freaking rod broke in half like that. Why didnt you decide to upgrade internals on the k24?
#15 | ||
Still tuning....
Explain?? Quote:
#16 |
RIP 2/4/2009
That orfice is for oiling the counter shafts on the K24 oil pump, failure to remove will result in low oil pressure when used with a K20 oil pump. It has to be removed and plugged (and use loctite!!), be careful, it's soft brass and strips out very easy!!.
Sorry to be the bearer of bad news, but I warned you in your other thread:
The liver is evil, it must be punished
#18 |
713
shouldnt be too hard to plug that orfice with motor in the car. just remove pan.
dude, u work fast. i gota give that to ya btw, i dont even have a brace/bracket supporting the PRB IM cuz i'm a base. the head will hold it up just fine if u decide to go without spacers.
#19 | |
Still tuning....
thanks
#21 | |
New Member
Out of interest what would be the best way of plugging it up securely? |
#22 |
Senior Member
#23 |
713
^with loctite.
#24 |
RIP 2/4/2009
No need to drop the girdle, just the pan and tray.
#25 |
Senior Member
nice work man
http://img.photobucket.com/albums/v397/yakec23/PIC6.jpg |
| Bookmarks |
| Tags |
| boosted, buildupw or pics, k24 or k20 |
| Thread Tools | |
