DIY Custom Fiberglass Enclosure - Club RSX Message Board
Notices
Reply
Thread Tools
Old 01-12-2007, 08:31 PM   #1
El_PiBe
Projectors....Mmmmmm
El_PiBe's Avatar
El_PiBe is an unknown quantity on c-rsx
A couple of people wanted me to make a write-up on how to make a Fiberglass Enclosure. Here you go…
Materials:
1 Gallon Fiberglass Resin W/ Hardener [Found This At Autozone, $33]
Bondo Filler [Autozone $14]
Sand Paper [Ace Hardware $3]
Dremel [Walmart $29]
Dremel Cutting Blades [Walmart $3.50]
Dremel Sanding Bit [Comes With Dremel Pack]
100 Plastic Cups [Dollar Store]
100 Latex Gloves [Dollar Store]
3M Glue [Walmart $8]
2 Yards Of Carpet [$4 Audio Store]
1 Yard Of Fleece [Walmart $3]
1 Ring For Your Subwoofer [Audio Store $10] Or you can make your own by buying a sheet at Home Depot for 5 bucks.
1 Flush Ring For Sub [Not sure price, probably the same as a reg. ring]
4 Yards Fiberglass Mat $16[Best to use the 2oz thick Mat] Real cheap at this websiteFiberglass Mat Link
20, 1" Painting Brushes [Walmart $10]
Aluminum Foil [Walmart $2]
2 Rolls Of Masking Tape [Walmart 1.50 ea]
Plastic Bags [Steal some from work, jk Walmart $3]
Glue Gun [Walmart $5]
Glue Sticks [Walmart $1]
Now that you have all your materials, we can begin our project.
First start off by masking the side you want to Fiberglass. I chose the left side. Here's what it looks like after it’s masked.
I have a trunk tray so it is a bit more work. My sub’s specs call for a 1.24 cub. ft. enclosure.
So I have to extend the masking over the trunk tray.
After you mask with tape, do the same with Aluminum Foil.
2005Infiniti G35 Coupe 6MT
2006 Projectors// 13% Tint// Pioneer AVIC D3//HKS Hi Power Exhaust //Nismo Shift Knob
El_PiBe is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-12-2007, 08:32 PM   #2
El_PiBe
El_PiBe's Avatar
Foiling continued...
After you’ve put the Aluminum Foil on, prep the rear by placing plastic around it. You don’t want to get any Resin on your car!!! Place plastic on the inside too.
You are ready to apply your first coat of Resin now that you have the plastic on the outside and the inside. It was my first time using Fiberglass Resin. Here’s how I measured my amounts of Resin and Hardener. The Resin is a thick liquid and it has a real strong odor. Please wear a mask while using this. And also have the latex gloves on while working with Resin. The Hardener is a water like liquid. It’s not thick. Here’s how I measured the amounts.
1. In a 16 oz plastic disposable cup I filled the cup halfway with Resin.
2. I poked a hole in the hardener tube and placed 15 drops in the cup filled with Resin.
3. Quickly mix it together with a plastic knife before the hardener starts to harden.
4. After you’ve mixed it together, you are ready to apply it to the Fiberglass Mat.
The way you apply the Resin to the Mat is with dabbing the brush at the Mat. Don’t brush it because the Mat will start to break apart. 4-5 half cups of Resin should be enough for 1 coat depending on how big you decide to make your enclosure. Mine took about 5-6 half cups. Cut the Mat in squares or
6X6 or however small you want. For large areas that don't have corners or edges you can cut the Mat bigger to kill that area off quicker.
Just hold the Mat against the Aluminum Foil and start applying the Resin. Be sure you don’t start to get bubbles. You’ll get the hang of it after the 1st or 2nd coat. BE PATIENT and do a good job or else it’ll come out bad. The 1st coat took like 5 hours to dry for me. The 2nd was less than that.
Here’s the 1st Fiberglass coat:
If you noticed that the Resin was getting hard quick while applying it to the Mat, then use less drops of Hardener. The more Hardener you use the quicker it will harden...so make sure you use just the right amount
Old 01-12-2007, 08:32 PM   #3
El_PiBe
El_PiBe's Avatar
Here’s the 2nd coat: Notice how it looks darker.
After you’ve applied 2 coats and it’s got some strength, you can take the mold out of the car.
Here's the bottom of the box and where the trunk tray runs through:
I know I skipped a few coats when I had first done this project but here’s coat 5:
Old 01-12-2007, 08:33 PM   #4
El_PiBe
El_PiBe's Avatar
Here is the 7th Fiberglass coat: This can be your last coat or you can keep going as thick as you want. I chose this to be my last cause it was the thickness I wanted.
After you have applied your last coat of Resin/Mat, it is time to cut your Mold. I used a Dremel with some cutting wheels. After rounding the Mold you can take off the excess Aluminum Foil still attached to it.
Old 01-12-2007, 08:34 PM   #5
El_PiBe
El_PiBe's Avatar
Here's how it looks with the tray in place. And some shots of how it looks inside. The reason I have duct tape is because it's applying pressure to the bottom rods and the top rods so the glue can dry tight on there.
If you're going to flush your sub then place a ring ontop of another ring. This is what it looks like.
06CTtypeS I borrowed your picture
Once you have your ring made for your sub you can position it with the dowel rods. I got these rods from some small flags I found at the Dollar store. I just took the flag off and used the rods/sticks whatever you want to call it. Using your glue gun, place a lot of glue to make the rods hold in place.
After you’ve positioned your ring, you can now place the Fleece on. Pull it tight and glue it to the back or sides of the mold.
Old 01-12-2007, 08:34 PM   #6
El_PiBe
El_PiBe's Avatar
After you have put the Fleece on, it’s time to add some Resin to make the Fleece stiff and strong. Mix the Resin and Hardener together again like before and just dab or brush it on the Fleece. The Fleece is going to absorb a lot of Resin. What you want to do is make sure you soak the entire Fleece with Resin. That means you have to apply it to the inside of the Fleece too. Yes, I know it’s going to be a PITA but you want it to come out very strong before you start applying Mat to the Fleece.
APPLY ONLY RESIN TO THE FLEECE. No Mat needed. You want to soak the Fleece as much as possible.
First coat of Resin on Fleece:
2nd coat of Resin on Fleece:
After you’ve soaked the Fleece real well with Resin you can start adding Mat to the outside of the Fleece. After every coat to the outside, place a coat or Mat and Resin to the inside part of the ring inside the enclosure for sturdiness. I noticed on mine that the inside part of ring was kind of loose so I had to add Mat to make it strong and keep it from caving in. Also, brush some resin on the inside edges of the enclosure too.
Here’s the 1st coat:
Old 01-12-2007, 08:35 PM   #7
El_PiBe
El_PiBe's Avatar
I put 7 coats of Mat on the Fleece too. Here’s the 7th coat. I know I skipped coats 2-6 but you know what to do. Same steps like you did to the mold. Just take your time and dab at the Mat instead of brushing.
After you have applied your last coat you can sand it down and test for fitment.
Old 01-12-2007, 08:35 PM   #8
El_PiBe
El_PiBe's Avatar
I cut a hole in the back of the enclosure for the connectors:
I sanded it down a bit around the ring area.
Once you have applied all the coats to the Fleece, you can start adding the Bondo Filler to the outside. This adds more strength and makes it easy to sand down for smoothness.
Bondo is real cool to work with. Just read the directions and apply to the enclosure.
Old 01-12-2007, 08:36 PM   #9
El_PiBe
El_PiBe's Avatar
After the Bondo hardens, sand it down to make it smooth. Then dust it off and start to carpet it. I got this carpet at Walmart but I really don’t like it. I went to the Audio shop a couple of days after I finished my box and got some speaker box carpet. It’s a bit more thinner than the one I have on now. Use the 3M glue and spray it on the enclosure and place the carpet on.
That’s it. You’re done.
Old 01-12-2007, 08:43 PM   #10
Darth Do'Urden
Master Member
Darth Do'Urden's Avatar
Darth Do'Urden is an unknown quantity on c-rsx
Awesome write-up!
Shoulda used leather/vinyl to cover the enclosure. That would look sweet if it matched the seating.
Fantastic job!!
"Truth does not depend on what you or I believe."
2008 Alabaster Silver Accord EX-L V-6 Coupe w/Navi 6-Speed
Darth Do'Urden is offline   Reply With Quote
Old 01-12-2007, 08:56 PM   #11
cammyman1
referred to Subaru
cammyman1's Avatar
cammyman1 is on a distinguished road cammyman1 is on a distinguished road cammyman1 is on a distinguished road
very nice i have one too but its like 10x smaller which sucks cause it really limits my sub size.
cammyman1 is offline   Reply With Quote
Old 01-12-2007, 09:53 PM   #12
m1ndless
m1ndless has been a little shit in the past
Freaking Awesome. I have a quick question, after you stretch the fleece, you said do two coats of resin to soak it, that means no mat, just the resin w/hardner right? Then after those two coats then use the mat or just on the inside or what?
And I think the question everyone is thinking..how does it sound? Does it hold up when you have it up? Any ratteling?
m1ndless is offline   Reply With Quote
Old 01-13-2007, 01:20 AM   #13
Sushkin
Selling Penguins Since 82
Sushkin is an unknown quantity on c-rsx
wow that is a lot of airspace in that thing. Looks good though...
2004 E.Blue Srt-4 *SOLD*
2002 RSX Type S
Sushkin is offline   Reply With Quote
Old 01-13-2007, 02:12 AM   #14
MKpoto
Formerly Trvotypes
MKpoto's Avatar
MKpoto is on a distinguished road
nice i love working with fiberglass.. minus the smell of resin lol
Top Down Crew#2
FUTURE: E92 M3/335I/135I SO BUY MY CAR!
Current: FOR SALE!! 05 NFR Honda S2000
Past:03 Acura Rsx Type S Turbo 300whp 210tq on 7.5 Greddy- SOLD
MKpoto is offline   Reply With Quote
Old 01-13-2007, 11:57 AM   #15
El_PiBe
El_PiBe's Avatar
I will edit it right now. I meant apply the resin to the fleece only, no mat yet. After the two resin coats then you apply mat. I applied the Mat to the outside of the fleece.
Old 01-13-2007, 11:59 AM   #16
smoresrock
yut ughhh!!!
smoresrock's Avatar
smoresrock is on a distinguished road
PRETTY DAMN CLEAN JOB.
fight my brute!
out with the old, in with the new.
smoresrock is offline   Reply With Quote
Old 01-13-2007, 12:54 PM   #17
El_PiBe
El_PiBe's Avatar
I appreciate all the good feedback. If anyone is planning on making one and has any questions just PM me
Old 01-13-2007, 03:10 PM   #18
zephyr
Member
zephyr's Avatar
zephyr is an unknown quantity on c-rsx
be sure to wear your respirator kids
zephyr is offline   Reply With Quote
Old 01-13-2007, 05:59 PM   #19
Spy
Member
Spy's Avatar
Spy is an unknown quantity on c-rsx
great write up,...but why did you use body filler if you ended up carpeting it?
Spy is offline   Reply With Quote
Old 01-13-2007, 07:10 PM   #20
El_PiBe
El_PiBe's Avatar
^^ To make everything smooth. I had small bumps and dents. I wanted the carpet to lay perfect.
Old 01-13-2007, 07:29 PM   #21
9 Meter Peter
I like turtles
9 Meter Peter's Avatar
9 Meter Peter has a clean start 9 Meter Peter has a clean start 9 Meter Peter has a clean start 9 Meter Peter has a clean start 9 Meter Peter has a clean start
+rep
9 Meter Peter is offline   Reply With Quote
Old 01-13-2007, 07:43 PM   #22
RSX4U2NV
...gOt boOst
RSX4U2NV's Avatar
RSX4U2NV is an unknown quantity on c-rsx
Great job!
~F/S* DC5R INSERTS~
~My Feed Backs~
~More Pic of my car~
[Greddy Turbo]FMIC HKS BOV[JDM]valve cover[JDM]spark plug cover[JDM]steering wheel[JDM]pedals[JDM]console w/ebrake[JDM]floor mats[JDM]carpet[JDM]shift knob [JDM]headlight w/12000K[MUGEN]front&rear struct brace[MUGEN]reservoir covers[HENSHIN]full BC2 body kit[SEIBON]CF fenders[LEXUS]rx330 white crystal pearl paint[SEIBON]evoII carbon fiber hood[VIS]carbon fiber trunk[JDM]side markers[][J8pro] 19's[Takata]harness
RSX4U2NV is offline   Reply With Quote
Old 01-13-2007, 07:44 PM   #23
rtjones
What the Fawkes?
rtjones's Avatar
rtjones is an unknown quantity on c-rsx
nice DIY, I'm going to do this myself soon enough.
2003 SSM RSX-S
INJEN CAI, JDM Shift Knob, Gunmetal Stockers, ITR Valve Cover,
Black Outs, Redouts, Calipers, Exedy clutch and Fidanza flywheel.
Sidemarkers!
rtjones is offline   Reply With Quote
Old 01-13-2007, 08:45 PM   #24
whoflung-poo
crackle
whoflung-poo's Avatar
whoflung-poo is an unknown quantity on c-rsx
This is so cool! I might just have to try it and I couldn't care less about having a system in the car. But I would be proud of it if it came out as good as yours.
+rep
04 type S DSM mods: /17" Einke 5+/ Nitto NeoGen ZR/ Mugen SS/ SPC camber kit/ Injen CAI/ Kpro/ESMM/OBXRH/PowerGetter
Garage: Hondata IMG
whoflung-poo is offline   Reply With Quote
Old 01-13-2007, 09:02 PM   #25
El_PiBe
El_PiBe's Avatar
*Edited* some more. I added a picture of how the flush ring is added to the bottom ring.
Reply
Bookmarks
custom , diy , enclosure , fiberglass
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2012, Club RSX, Inc. All rights reserved worldwide.
