How To Aim Projector Headlights - Club RSX Message Board
Go Back   Club RSX Message Board > STYLE > Lighting
Reply
Thread Tools
Old 03-11-2007, 09:42 PM   #1
DHack
No More Broken OEM Fogs
DHack's Avatar
There may be a thread on this already but I figured I would make a thread that was easy to find if you did a search. Please feel free to contribute if you think I may have left anything out....or if you would do something differently.
TO AIM PROJECTOR HEADLIGHTS:
1. Align your car dead center in your driveway....the front and back of your car need to be perfectly aligned in the center..
2. Pull your car up to the garage door...as close as you can get w/o hitting the door..dead center in the middle of the garage door / driveway.
3. Put a piece of tape where the headlight beams hit the garage door. This should only be smal dot of light...
4. Pull you car back 25'. Your Projector lens should be 25' away from the garage door...not your tires or your bumper...your headlights. DEAD CENTER IN THE DRIVEWAY
5. With tape Place a VERTICAL line that intersects each piece of tape that you put on the garage where your headlight beams hit. Use a yardstick or a straight edge t make it perpendicular to the driveway. This is important for aiming your lights right to left....this is just as important as up and down because if your lights are aimed to far left you will still be shining omcoming traffic in the eyes and if they are aimed too far right your not getting the most out of your light.
6. With tape place a horizontal line along the garage that intersects each piece of tape that you put on the garage where your headlight beams hit. They should oth be the same height off the driveway.
7. With tape place a horizontal line along the garage that is 2.1" lower than the tape you placed on the garage in instruction #6. This line should be parallel with the line in #6...just 2.1" lower.
8. Cover up the passenger side headlight with a thick towel.
9. Turn on your lights
10. Drivers Side UP/Down: Bring the lower step of the cutoff to or below the tape line that is 2.1" lower than your headlights...Dot Spec is 2.1" to 2.5" drop over 25'
11. Drivers Side Right / Left: The Vertical line on the drivers side of the garage should intersect the middle of the slant on the cutoff. Move the beam pattern until this is the case.
Moving the projectors from right to left may effect the height of the beam pattern. If this is the case..just go back and fine tune.
12. Cover the Drivers side headlight with a thick towel.
13. Repeat the UP/Down Left/Right procedure that you did on the drivers side with the passenger side. The vertical line on the passenger side of the garage is to be used for instersecting the slant in the cutoff on the passenger side headlight beam.
Compulsive HID Retrofreak - I can't Stop
DHack is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-11-2007, 09:57 PM   #2
DHack
DHack's Avatar
Old 03-11-2007, 10:17 PM   #3
F123456
Master Member
awesome guide. adjusting projectors is always a pain, but i'm glad to have a formal guide now.
F123456 is offline   Reply With Quote
Old 04-13-2007, 08:17 PM   #4
04Integra S
Senior Member
04Integra S's Avatar
good guide man, thanks for the help
04Integra S is offline   Reply With Quote
Old 04-13-2007, 08:52 PM   #5
Iluvferrari
fudge em
Iluvferrari's Avatar
what if you have a two door garage and cannot have the car parked in the center of the driveway. Is it ok to be parked in the center of the door?
This is my signature
Iluvferrari is offline   Reply With Quote
Old 04-13-2007, 09:37 PM   #6
DHack
DHack's Avatar
It will be more difficult for sure. The changes in depth (door / wall) will make it look like the cutoffs are crooked. Its enough to drive you crazy.
Check out this shot and you'll see what I mean:
Maybe its not so bad. You might have a hard time with the area between the headlights though..either way...it can be done and good luck to you.
Old 04-13-2007, 09:40 PM   #7
DHack
DHack's Avatar
Cool guys!!! I'm glad this is some help.
Old 07-18-2007, 08:10 PM   #8
edhgreatone
Senior Member
edhgreatone's Avatar
great guide i did every step but when i'm using the screwing driver to aim the headlights up/down there not moving at all also left/right i see the wheel thing turning but no adjusting the headlights any ideas?
edhgreatone is offline   Reply With Quote
Old 07-18-2007, 10:16 PM   #9
DHack
DHack's Avatar
It is possible that you (or someone else) adjusted the projectors out so far that it popped the mounting point of the projector out of the socket. A good indication of this (besides trouble aiming) is when the projectors flop around when you hit bumps.
In the ebay headlights (02-04 non eyebrow) there are three mounting points on the projectors:
1. up/down adjuster screw
2. Left/Right adjuster screw
3. Anchor point or pivot ball. It sits on the bottom an acts as an anchoring point so that the projectors are not floating around on just two adjuster screws.
Check out this picture with captions;
Old 07-18-2007, 10:21 PM   #10
DHack
DHack's Avatar
It is possible to fix them w/o tearing them apart but its a little tricky. You'll have to take them off the car and try to force that ball into the socket by guesswork since you won't be able to see it. You should have a real good idea how to maneuver the projectors so the pop back in though. Remember: If you popped them out of the sockets it is because they were adjusted way too far out (down and/or out). In order to get them in a position to pop back into the socket you will have to turn the adjuster screws clockwise to brink the projectors closer to the back of the housing and the socket.
D
Old 07-18-2007, 10:42 PM   #11
rly44
06 NBP Type-S
rly44's Avatar
Very good starting point but this method only works if your driveway is level from the door to wherever you position the car 25' away. I also aimed my lights a bit lower than DOT since I thought I was aimed too high and blinding people at the correct height. I may be at about 3" with TSX projectors. cops over in my area are looking for a reason to pull people over so I have my wife's civic with E55 projectors aimed even lower due to the higher step.
Just another RSX in Iowa..
rly44 is offline   Reply With Quote
Old 07-18-2007, 11:06 PM   #12
DHack
DHack's Avatar
You should only aim your headlights on a level surface
Old 07-19-2007, 06:58 PM   #13
edhgreatone
Senior Member
oh wow... so you have to pull out the hole cover of the headlight? with the whole oven trick thing and then put it back together in order to aim the headlights?
Old 07-19-2007, 07:49 PM   #14
DHack
DHack's Avatar
No...that is what I am saying....you may be able to do it w/o doing that.....I just had mine out to put better projectors in.
Go back and read my post and you'll see.
Old 07-20-2007, 10:23 PM   #15
godraj
vtec my ANTI-DRUG
godraj's Avatar
worked out well for me with this method.
godraj is offline   Reply With Quote
Old 07-20-2007, 11:26 PM   #16
DHack
DHack's Avatar
can't wait to see your hybrid headlights on your ride godraj.......
Old 07-28-2007, 12:00 PM   #17
ixihazardixi
The S
ixihazardixi's Avatar
I haven't tried it, but i will try it tonight and see if it works.
DC5 N-Sport Full Cat, AEM V2 Shortram,polished 4-1 header, EiBach sportline springs, 18 BBS RK, A-Spec Kit, Black Housing Halo Projectors
ixihazardixi is offline   Reply With Quote
Old 08-02-2007, 09:43 PM   #18
ixihazardixi
The S
okay, i forgot to tell you, i have the projectors with the eyebrow.. how can i get those bcuz the bolts/screws are different and i'm also trying to get them to beam out further bcuz it only beams out about 15' in front of me..
Old 08-02-2007, 09:50 PM   #19
DHack
DHack's Avatar
I've never done those lights but it should be pretty much the same. There should be two adjusters per projector. One for up/down and one for left/right. Can you confirm that there are two adjuster screws per projector?
Old 08-13-2007, 04:55 PM   #20
turbomzi
F1 Racer
turbomzi's Avatar
I have the eyebrow headlights too. It only lights 15' or maybe less in front of me. On some roads, it's impossible to see anything... My questions is, I see two silver screws on the back of the light, but one of them is very difficult to get to and I think that one is the Up/Down screw. Do I have to take it off or is it possible without taking the lights off? maybe a special kind of tool?
turbomzi is offline   Reply With Quote
Old 08-13-2007, 04:56 PM   #21
DHack
DHack's Avatar
you should be able to reach them and turn them with a long screwdriver
Old 08-13-2007, 05:01 PM   #22
DHack
DHack's Avatar
don't try to use the (flathead) screwdriver like you would a normal screwdriver.....just use it to turn the screw by pushing down on either side of the head...that is why the adjuster screws are flared like that.
Old 08-13-2007, 05:14 PM   #23
turbomzi
F1 Racer
turbomzi's Avatar
k, I will try that. Thanks a lot.
Old 08-13-2007, 07:57 PM   #24
Big Cam
Retired
Big Cam's Avatar
Big Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their own
Big Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their ownBig Cam must be an admin because here is no way they could have reached this amount on their own
I am going to add this to the stickie on the top of the page.
Guilty of being white since 1982and how
XBL GT=Xerocam *Motorcycle Crew # 97,5875,856,236*
Originally Posted by dale dribble View Post
Cam outta nowhere!
Originally Posted by erik loza View Post
LOL: Being a Mod is like getting a license to whore.
Originally Posted by simpuhl View Post
You sound like an awesome friend.
Big Cam is offline   Reply With Quote
Old 09-30-2007, 10:32 AM   #25
RSXspeed6
New Member
Hey guys, i just bought JDM blacked out halo projectors. I got all wires hooked up, except two red wires hanging off. And the halo projectors are not turning on. So my question is, where do i hook these two red wires??? thanks
RSXspeed6 is offline   Reply With Quote
Reply
Bookmarks
aim, headlights, projector
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2001-2012, Club RSX, Inc. All rights reserved worldwide.
