Go Back   Club RSX Message Board > GENERAL > General RSX Discussion
Reply
Thread Tools
Old 05-02-2007, 07:28 PM   #1
zeppdogg
NIBIRU PLANET X
zeppdogg's Avatar
fujita cai installed sunday ( labor and performance outcome) outcome wit vid
yup i installed it sunday evening, started at 6pm and ended at 9:40pm lol theres some tricks ive learned in the process or solutions i would like to share with ya'll maybe this will help future fujita cai installers. 1st the fujita washer bottle pump holes are to small for the pumps to fit in nicely not even the rubber seals can get in nicely. my solution was to take a drill and a small drill bit not too small and drill around the holes a couple of laps. this was did holding the bottle in the air holes facing down so the shreads would fall out the bottle instead in, also i had the drill going in reverse like you loosening so the drill bit would help pull the shreads away from the inside. i did the smae thing with the washer bottle neck opening because that too wasnt fitting properly. 2nd the battery tray bolts. you dont have to unscrew them all the way out lol just loosen them enough and slide the tray straight up also if you need help trying to locate the bolts just slide you fingures down the two ramps and that will take you to the 2 bolts (btw the rubber vibrant mount takes the place of the bolt thats closes to the tranny. the tray bolt that is) with the tray out theres nice space to work. 3rd the fender well. trimed it just enough so the intake can squeez threw you dont have to cut a big ass hole for it to work. the best tool i found easy to use for cutting was a old steak knife 1st i tried a sawzall i wasnt getting no where fast plus it died the fender well killed the sawzall, then i tried a electric chainsaw it was to violent the fender and shit was just vibrating at 15k rpms then i tried a old steak knife it cut thru like a hot knife threw butter. it just carved away like turkey meat. ( btw it was pretty easy running the intake thru the top you push it in the fender opening you just cut as far as you can go then go to the fender and pull it threw then go back to the top and pull the radiator hose up and push the pipe down to the coupler that should be on the throttle body) 4th i notice alot of ppl were having issues with the gearing or shift linkage i dunno how but heres some advise on that too. look under the hood and have somebody shift 1st thru 5th and you will see the shift thingy rock back and forth lol this will give you an idea of what kinda space you have between the pipe and the thingy that rocks back and fourth. my pipe was far enough from the get go. 5th OMG OMG the mount on the intake is a mile away from the rubber vibrant mount
my soulution was to bend that bitch towards the rubber mount while pulling the intake a liittle at this part its good idea to leave the braket slighty loose , thats for the intake not the bracket for throttle body. that pretty much somes up the hard labor parts everything else is pretty much common sense.
peformance
what we all been dying for after a hard days of work. the intake like everybody else says it whistles i dunno about it sounding like a BOV but it whistles. its nothing really special because i had a filter that whistled the same way before the difference was that it actually drew air from the front middle of the filter unlike the fujita filter its like a closed up velocity stack. but anyway its loud esp when vtec hits i never knew a CAI can be lounder than a SRI. vtecing threw tunnels or side streets with lots of parked cars with all your windows wide open is like have dolby digital surround sound of the intake screaming. vtec is most def loud and it pulls nicely when kicking in.
vid/sound clip
heres just a b.s vid from my cam phone its low quality but it works (vtec is not as loud like on my phone nor in person cuz after sound is duplicated so many times it becomes muffled) so bear with it Click here to see Video
zeppdogg is offline   Reply With Quote
Old 05-02-2007, 07:29 PM   #2
05Aucrarsx
RIP
u really didnt need to write that much
i think we all know what an intake is or how it perform
05Aucrarsx is offline   Reply With Quote
Old 05-02-2007, 07:31 PM   #3
zeppdogg
NIBIRU PLANET X
zeppdogg's Avatar
lololololol well i kept seeing struggles
Old 05-02-2007, 11:31 PM   #4
So Fly
Powered by Comptech
So Fly's Avatar
Nice write up, I recently installed my F5 also and I had the same issues too!
Supercharged 2003 NBP Acura RSX Type-S
05/06 Conversion + Recaro + Volks + CTSC @ 8.9psi = 296whp & 204wtq
Mods and Pics:
http://forums.clubrsx.com/showthread.php?t=636299
http://www.arizonarsx.com/forums/vbp...p?do=view&g=81
So Fly is offline   Reply With Quote
Old 05-02-2007, 11:32 PM   #5
SoloTeg
countdown to cone season
SoloTeg's Avatar
SoloTeg has disabled reputation
I'm going to read this later. Seems like a good write up from me scrolling through it.
SoloTeg is offline   Reply With Quote
Old 05-03-2007, 07:18 AM   #6
zeppdogg
NIBIRU PLANET X
zeppdogg's Avatar
thank you thank you
Old 05-03-2007, 09:18 AM   #7
HondaTom
Drunkard Member
HondaTom's Avatar
HondaTom is offline   Reply With Quote
Old 05-03-2007, 09:42 AM   #8
KazeSpec
KneeDragger in Training
KazeSpec's Avatar
wow from 6 to 9:40? jeez what were you doing the whole time?
Special Projects Motorsports, Pro-Car Innovations, Innovative Mounts, Amsoil, Blueprint Racing, AIT Racing, BuddyClub, LF.com
click: INfamoUS, All Motor Crew#14, Motorcycle Crew #37
need Spy sunglasses? PM me. Hardrace/PCI bushings PM me
KazeSpec is offline   Reply With Quote
Old 05-03-2007, 10:04 AM   #9
Drahk
Mr. Type-S
probably and :giggitygiggity: inbetween breaks?????? if so.... in for pics......
Drahk is offline   Reply With Quote
Old 05-03-2007, 06:28 PM   #10
zeppdogg
NIBIRU PLANET X
zeppdogg's Avatar
man was installing and looking around for short cuts it didnt look like any short cuts were possible while trying to stay neat and clean i'll take some pics of the job soon
Old 05-03-2007, 11:09 PM   #11
juicyjoint316
Master Member
juicyjoint316's Avatar
u act like u can install cai in 10mins...doing a cai on a k series the 1st time is a bitch. cut him some slack, took me and my friend 5hrs due to the fact we thought it was the rsx-s system instead of the base b.c. of fitment issues.
03 nbp rsx 5spd base cai/rh/e *SOLD*
Now: 07 galaxy grey civic si sedan AEM cai/DCRH/35% tint fronts, 20%tint rears, window visors
Awaiting install: Exedy Stage1 clutch, Exedy lightweight Flywheel.
juicyjoint316 is offline   Reply With Quote
Old 05-03-2007, 11:12 PM   #12
juicyjoint316
Master Member
god damn zepplin ur car has over 100k miles on it...time to get a real mod f/i. buy my type-s dcrh i want the bcrh!
Old 05-04-2007, 12:38 AM   #13
Sweetnessinfall
she loves it
Sweetnessinfall's Avatar
qft
[SIGPIC][/SIGPIC]
HotAvy&SigKrew Member #5 BOXXY[ruu#1
Sweetnessinfall is offline   Reply With Quote
Old 05-04-2007, 12:42 AM   #14
SoloTeg
SoloTeg's Avatar
Ok so I read it. There's a million threads like this, but good writeup nonetheless. Probably should go in the DIY forum
Old 05-04-2007, 12:52 AM   #15
ghb2513
Social Distortion fan....
ghb2513's Avatar
Nice write up
ghb2513 is offline   Reply With Quote
Old 05-04-2007, 01:03 AM   #16
KazeSpec
KazeSpec's Avatar
i said it jokingly, i wasn't trying to make fun of him. maybe some people are just better installers than others, only took me 20 min my first time, including stock airbox removal
Old 05-04-2007, 05:32 PM   #17
juicyjoint316
Master Member
i find that hard to believe 20mins but back when aem/injen 1st came out there was no hints or clues to how to install the systems. must me nice to do it that fast with a lil crsx help... i kid, i kid
Old 05-05-2007, 01:18 AM   #18
KazeSpec
KazeSpec's Avatar
haha well thats why we have DIY's dont we?
Old 05-05-2007, 03:02 AM   #19
zeppdogg
NIBIRU PLANET X
zeppdogg's Avatar
Originally Posted by ghb2513 View Post
Nice write up
thank you thank you
20 mins taking the whole thing apart is like 20 mins cutting the fender nicely bout another 20 mins. didnt want to shave to much
Old 05-05-2007, 03:05 AM   #20
KazeSpec
KazeSpec's Avatar
i cut enough to clear the entire piping, a nice rectangle.
Old 05-05-2007, 05:26 AM   #21
Game
Game's Avatar
@ 5 hours and not knowing what the car is...
And CAI's are done in 20 mins all the time.
MIDWEST CREW
LAKERS!!
Game is offline   Reply With Quote
Old 05-05-2007, 06:38 AM   #22
Game
Game's Avatar
Originally Posted by Austinite View Post
The guy that takes him 10-20 min to install a CAI must drive around without a bumper or fender liners, was previously running with just a tube and a port for IAT, and have the battery zip tied to the fender on the outside.
That's the only way I can see a 10-20 min job.
I've heard of beat up old abused '02 models, but wow that's insane for that kind of setup.
lol...bumper can take 2 minutes.
Trust me CAIs can take no time at all if you go in there knowing what your doing.
MIDWEST CREW
LAKERS!!
Old 05-05-2007, 06:53 AM   #23
Game
Game's Avatar
What if your car is slammed and you can't get to the 4 screws or 6 clips underneath, then what? What if you have 245R18s in front?
For a stock car maybe, but then all the screws and clips are nice and tight. You still have to take the side screws off and if you have the full top part of the bumper that adds some clips.
I've installed 5-10 CAI's so far, not to mention uninstalled/reinstalled for IMGs and for RBCs, and I sometimes help the family at their Acura/Honda Body Shop. So I think I have the hang of it. I can take an oem bumper off and put it back on in 45 minutes without scratching anything, with all the screws/buttons, and aligned perfect. I can also swap an exhaust in 25 minutes, and rotate tires with just the supplied oem jack in 20 minutes.
So, no, I personally can't see it taking 10-20 minutes. Not without doing damage, or starting with a mangled vehicle, that is.
Didn't really want to get this deep into it.
Ok well my car was already lifted and the fender liner was moved aside because the suspension was being worked on. The SRI was removed and the CAI was put in a total of about 20 minutes.
MIDWEST CREW
LAKERS!!
Old 05-05-2007, 12:33 PM   #24
KazeSpec
KazeSpec's Avatar
the only thing that helped with my 20 min CAI install was that i didnt have the 4 push tab screws on the bottom. everything else is still there. also a sharp sharp knife or scissor
Old 05-05-2007, 07:13 PM   #25
zeppdogg
NIBIRU PLANET X
zeppdogg's Avatar
i mean i guess it wouldnt take long after doing it it for a few times like right now since i know everything if i was to do it again it should only take an hr and prob a few minutes for finishing up. but this is prob what a 10-20 min job look like
Reply
Bookmarks
cai, fujita, installed, labor, outcome, performance, sunday, vid, wit
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
