Trunk won't lock, please help - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Problems & Solutions RSX
Notices
Reply
Thread Tools
Old 07-19-2007, 03:00 PM   #1
TVolpe03
Senior Member
TVolpe03 is an unknown quantity on c-rsx
I was getting out of my car the other day and grabbed the key pad and pressed the big button twice. well, it wouldn't beep so i knew something wasn't locked. i checked the driver and passenger doors and they were both locked. then i tried to open the trunk and it opened right up. why won't the trunk lock? i'm wondering if i am just overlooking the obvious!
TVolpe03 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-19-2007, 03:20 PM   #2
Xqzrt
Master Member
Xqzrt's Avatar
Xqzrt is an unknown quantity on c-rsx
actuator gone bad?
'04 DSM Base
Xqzrt is offline   Reply With Quote
Old 07-19-2007, 03:32 PM   #3
yrap
CheapCaribbean
yrap's Avatar
yrap is an unknown quantity on c-rsx
Originally Posted by Xqzrt View Post
actuator gone bad?
that or faulty wiring mabey something became disconnected.
all so make sure theres nothing stuck in the latch
-Joe
PhotoTrail...UpDate 8/20/07
CarDomain Yuengling Crew#1 ; Aquarium Crew/SW crew ; WAWA Crew #6 ; TopDownCrew
SJ OG CREW FOR LIFE
yrap is offline   Reply With Quote
Old 07-19-2007, 03:55 PM   #4
VTEC_Inside
Mmm, 3rd lobe...
VTEC_Inside's Avatar
VTEC_Inside is an unknown quantity on c-rsx
Never looked at it myself but there is supposed to be a pop off panel on the inside to access the hatch lock for situations like these.
Honda, The Heartbeat of Japan...
2006 Acura CSX Touring 160hp 141lb/ft
2004 Acura RSX Type S 6spd 200hp 142lb/ft
1989 Honda Accord Coupe LX 5spd 2bbl 98hp 109lb/ft
Slushies are something to drink, not drive...
Nikon Crew Member #23 | Gripped D700/D200, 2.8 from 17-200
VTEC_Inside is offline   Reply With Quote
Old 07-19-2007, 04:05 PM   #5
yrap
CheapCaribbean
yrap's Avatar
yeah its dead center on the inside of it. but the whole panel comes off real easy any way
-Joe
SJ OG CREW FOR LIFE
Old 07-25-2007, 08:54 AM   #6
TVolpe03
Senior Member
well i looked at the actual latch part in the trunk and i found the switch that is supposed to move back and forth when i hit the button and it isnt. also if i move the switch manually then shut the truck the trunk wont unlock because the switch isnt moving. do you think that is an easy fix or should i take it to the dealership? thanks for the help!
Old 07-26-2007, 12:48 AM   #7
HondaSpeed05
Master Member
HondaSpeed05's Avatar
HondaSpeed05 is a glorious c-rsx member HondaSpeed05 is a glorious c-rsx member HondaSpeed05 is a glorious c-rsx member HondaSpeed05 is a glorious c-rsx member HondaSpeed05 is a glorious c-rsx member HondaSpeed05 is a glorious c-rsx member HondaSpeed05 is a glorious c-rsx member HondaSpeed05 is a glorious c-rsx member HondaSpeed05 is a glorious c-rsx member HondaSpeed05 is a glorious c-rsx member HondaSpeed05 is a glorious c-rsx member HondaSpeed05 is a glorious c-rsx member HondaSpeed05 is a glorious c-rsx member HondaSpeed05 is a glorious c-rsx member HondaSpeed05 is a glorious c-rsx member HondaSpeed05 is a glorious c-rsx member
you have some bad luck with your car arent ya?
HondaSpeed05 is offline   Reply With Quote
Old 07-26-2007, 03:31 PM   #8
TVolpe03
Senior Member
omg yeah did you see my damn burning oil thread i started. this damn car is just going down the drain. i think its a lemon!
Old 07-27-2007, 09:35 PM   #9
DC5Tyler02
got stolen
DC5Tyler02's Avatar
DC5Tyler02 is an unknown quantity on c-rsx
i have the same problem. . .
i flip the white switch and it will lock but not unlock. . . or if its unlocked my car alarm will not engage.
i just keep my hatch switch over and try like hell to never use it
acura looked at me like i was crazy when i tried explaining this to them.
glad im not the only one.
I(use to)VTEC
DC5Tyler02 is offline   Reply With Quote
Old 08-01-2007, 01:57 PM   #10
TVolpe03
Senior Member
do you ever have a problem opening the trunk? sometimes mine wont even open bc the switch wont work
Old 08-01-2007, 02:22 PM   #11
Leonard1818
Master Member
Leonard1818's Avatar
Leonard1818 is an unknown quantity on c-rsx
looks like you'll have to find another place to keep your extra quart of oil!
lol sorry, I couldnt resist.
Leonard1818 is offline   Reply With Quote
Old 08-01-2007, 04:41 PM   #12
bmw15
Senior Member
bmw15 is an unknown quantity on c-rsx
Probably your actuator.... my drivers actuator went out last month.... that was fun to replace....
2002 EBP Acura RSX SS
Build#: 28,032
120,000 miles
*Spoon Sports Upper Front Strut Bar *OEM Foglights *Neuspeed Front sway bar bushings *AEM SRI *Neuspeed X-Brace * Neuspeed Rear Anti-sway bar
bmw15 is offline   Reply With Quote
Old 08-02-2007, 08:38 AM   #13
TVolpe03
Senior Member
hahahahaha that is funny. the funny thing is i was at the gym the other day and put my gym bag in the trunk because it decided to work. well, when i arrived at the gym and had to get the bag out the trunk wouldn't open lol
Old 08-02-2007, 08:38 AM   #14
TVolpe03
Senior Member
yeah someone actually told me it could be that. how much did it cost to fix?
Old 08-02-2007, 09:15 AM   #15
Xqzrt
Master Member
Xqzrt's Avatar
umm just for parts? i think about 50. check AcuraOEMParts.com and search actuator. or search on this forum. i posted the part numbers like 20 times by now...
'04 DSM Base
Old 08-02-2007, 11:44 AM   #16
TVolpe03
Senior Member
okay thank you
Old 08-02-2007, 05:35 PM   #17
bmw15
Senior Member
yeah the part was fairly cheap.... i want to say somewhere between 40-50$ for my driver's door actuator.... the hard part was getting the door apart and lock assembly out of the door... I'm sure the hatch is easier.... at least one would hope.
Build#: 28,032
120,000 miles
Old 08-21-2011, 01:04 PM   #18
MasonGL
New Member
MasonGL is a jewel in the rough of c-rsx MasonGL is a jewel in the rough of c-rsx MasonGL is a jewel in the rough of c-rsx MasonGL is a jewel in the rough of c-rsx MasonGL is a jewel in the rough of c-rsx MasonGL is a jewel in the rough of c-rsx MasonGL is a jewel in the rough of c-rsx MasonGL is a jewel in the rough of c-rsx
Im new and have a 2002 rsx, Im having the same problem with the actuator..
MasonGL is offline   Reply With Quote
Old 08-21-2011, 01:09 PM   #19
mschaidle
Sith Lord
mschaidle's Avatar
mschaidle is an unknown quantity on c-rsx
replace the accuator. it's not that hard to do.. just pull off the pannel and put a new one in.
I had to do it about a month ago.
Originally Posted by LOW TRQ View Post
For gods sake put some real wheels and tires on your car. This "Hella Flush" shit is hella gay. This is one of those dark times in the import world and you need to let it die.
Originally Posted by ritchie View Post
I like to think of CRSX as the front lines of the war against rice.
mschaidle is offline   Reply With Quote
Old 08-21-2011, 05:34 PM   #20
MasonGL
New Member
Yep, already took out the accuator, right now im just using the manual lock, Can somebody post a link of the exact thing I need, ive been looking for accuators but dont know for sure if it is what i need
Thanks in advance
Old 08-21-2011, 05:47 PM   #21
808ster
Gangsta Plumber
808ster's Avatar
808ster is an unknown quantity on c-rsx
Heres the part # 74896-S6M-A01
I never read the Qu'ran or Islamic scriptures
Only psalms I read was on the arms of my niggas
808ster is offline   Reply With Quote
Old 08-21-2011, 07:33 PM   #22
atrain01
Member
atrain01's Avatar
atrain01 is a jewel in the rough of c-rsx atrain01 is a jewel in the rough of c-rsx atrain01 is a jewel in the rough of c-rsx atrain01 is a jewel in the rough of c-rsx atrain01 is a jewel in the rough of c-rsx atrain01 is a jewel in the rough of c-rsx atrain01 is a jewel in the rough of c-rsx atrain01 is a jewel in the rough of c-rsx
Actuator
atrain01 is offline   Reply With Quote
Old 08-21-2011, 09:40 PM   #23
itskien
Doesn't Give A F*ck
itskien's Avatar
itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with
x2
Empty Tank Crew #1
Twitter: KiensAJauk
Instagram / Snapchat: ItsKien
Originally Posted by AzianK View Post
kien you fat fuck, no set of wings can lift your cinna bun ass up to heaven anyway.
itskien is offline   Reply With Quote
Old 08-22-2011, 07:27 AM   #24
atrain01
Member
atrain01's Avatar
When I got rear ended and the assy broke I just bolted my hatch shut.
Problem solved
Old 08-23-2011, 07:30 AM   #25
Lil_wildindian
Member
Lil_wildindian is a jewel in the rough of c-rsx Lil_wildindian is a jewel in the rough of c-rsx Lil_wildindian is a jewel in the rough of c-rsx Lil_wildindian is a jewel in the rough of c-rsx Lil_wildindian is a jewel in the rough of c-rsx Lil_wildindian is a jewel in the rough of c-rsx Lil_wildindian is a jewel in the rough of c-rsx Lil_wildindian is a jewel in the rough of c-rsx
why would you bolt it shut lol, i have the same problem but i just unlock it by crawling in the back and flipping the lock
Lil_wildindian is offline   Reply With Quote
Reply
Bookmarks
lock , trunk
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
