Go Back   Club RSX Message Board > GENERAL > The DIY Garage
Reply
Thread Tools
Old 10-09-2007, 11:28 AM   #1
flacopower
I hate VVT4ME
flacopower's Avatar
DIY: Oil Catch Can
Took this from the cb7 forums. this post is from cokinut and i am not taking credit, simply reposting..
Originally Posted by cokinut
I’m not responsible for any damages to you or your car.
Pictures are used for a guide only.
EDITED Extra notes: (09.17.04)
Use a 3/8" fuel / fuel injection hose from your local auto store. you will only need the 2 ft. one, but it will cost around $4 for 2ft. I changed hoses so many times because:
1. i've heard the vinyl braiding hose will warp due to the high engine temps.
2. the silicone, when it heats up, gets soft and collapses.
3. air hose i.d. 300 psi.
Disregard the pictures of the vinyl braiding tubing and silicone hose. imagine that it is fuel hose.
Purpose: (thanks to turbopanda from Honda tech)
In an engine, there are two areas of air pockets in which the air is not directly related to combustion. Within these two areas, oil and air are separated from the combustion chambers and coolant jackets for the purpose of lubrication of the engine. The upper air and oil pocket is constrained by the valve cover at the top, and the valve seals at the lower end. The bottom air and oil pocket is constrained by the piston rings at the top and the oil pan in the bottom.
In a perfect world, these two lubrication areas would not pressurize. However, in real life compression leaks by valve seals and piston rings in what is called blow-by. Blow by introduces pressure into the two pockets of air and oil (the head and the crankcase). In addition, heat caused as a byproduct of combustion causes air molecules to expand which also causes the pressure to increase in these lubrication areas. If no ventilation system was employed to release this pressure, it would find the point of least resistance to escape, which could be oil seals...or worse.
To relieve this pressure, a system called Positive Crankcase Ventilation (PCV for short) is used. It is a closed system that takes the pressurized air and oil vapor from these two lubrication areas and introduces it back into the combustion chamber, by way of vacuum caused by the intake charge.
http://img.photobucket.com/albums/v1...CH%20CAN/1.jpg
Parts / Price List:
You can get most, if not all, of these products are your local hardware store. If not, then good luck finding some
http://img.photobucket.com/albums/v1...CH%20CAN/2.jpg
- air / water separator tank for air compressors = $15
http://img.photobucket.com/albums/v1...CH%20CAN/4.jpg
- (2) ¼” male barbs - $1.50/each
http://img.photobucket.com/albums/v1...CH%20CAN/5.jpg
- (optional) (2) ¼” elbow fittings = $2.20/each
http://img.photobucket.com/albums/v1...CH%20CAN/3.jpg
- Teflon tape = $$0.75
- (4) 5/8”-1/4” clamps = $.79/each
http://img.photobucket.com/albums/v1...CH%20CAN/6.jpg
- 2 ft 3/8" fuel / fuel injection hose = $4.00 at an auto store
http://www.pelicanparts.com/catalog/...l_inj_hose.JPG
- steel wool = $1.50
http://img.photobucket.com/albums/v1...H%20CAN/20.jpg
- total cost of project: $33 or $28 minus the ¼” elbows
Originally Posted by VVT4ME
you should be fired from inteligence. you possess none.
flacopower is offline   Reply With Quote
Old 10-09-2007, 11:29 AM   #2
flacopower
I hate VVT4ME
flacopower's Avatar
[quote=cokinut]Instructions:
1. take out the filter from the air/water separator tank. You don’t need this since the steel wool will act as a baffle for the oil.
2. Stuff enough steel wool in the container to fill it up comfortably. What this does is keep the oil at the bottom of the tank and prevent the vacuum pressure from sucking up the oil from the bottom of the tank.
3. get the 2 (optional) ¼” elbow fittings and put teflon tape on the threads
This step is optional because depending on location, you may not need the elbows. They just provide a better fit for the hose in the engine bay.
4. Screw them onto either end of the air/water separator tank.
5. get your 2 ¼” male barbs and telfon tape the threads on those.
6. place the one male barb on each of the elbow fittings.
7. Make sure everything is tight.
8. Find a spot to mount your new oil catch can (air/water separator)
9. Notice on top of the air/water separator, there is an arrow indicating the air flow – remember that when attaching the hoses.
10. remove the old hose attaching the pcv valve to the intake manifold.
11. Get your 5/8” vinyl braided hose, cut one piece to go from your pcv valve to the inlet of the air/water separator.
12. remember to clamp down the ends.
13. cut another piece of hose to from the outlet of the air/water tank to the intake manifold nipple where the pcv hose thing used to attach to.
Old 10-09-2007, 11:50 AM   #3
Danrsxtypes
novice
i know this has been done before, but i give you credit for good DIY writeup
Danrsxtypes is offline   Reply With Quote
Old 10-09-2007, 12:02 PM   #4
infraredrsx
Zero Tolerance 4 Retards
infraredrsx's Avatar
infraredrsx is on a distinguished road
You should use the filter/baffle assembly that came with the separator. It is designed to filter oil and water from the inlet air. The plastic parts that hold the filter in place act as a baffle to create a sump that causes the water/oil to drip to the bottom of the container. The steel wool is not actually acting as a baffle, it is just catching some of the oil as the inlet air comes in contact with it. The baffle/filter that comes with the separator actually forces the oil/water out of the inlet air.
There are 2 types of people behind the wheel, drivers and operators.
Operators are interested in geting from point A to point B.
Drivers are interested in what's between.
infraredrsx is offline   Reply With Quote
Old 10-09-2007, 12:20 PM   #5
erik loza
On the long road...
erik loza's Avatar
erik loza Golden Rep Whoreerik loza Golden Rep Whore
erik loza Golden Rep Whoreerik loza Golden Rep Whoreerik loza Golden Rep Whoreerik loza Golden Rep Whoreerik loza Golden Rep Whoreerik loza Golden Rep Whoreerik loza Golden Rep Whoreerik loza Golden Rep Whoreerik loza Golden Rep Whoreerik loza Golden Rep Whore
Good job and thanks for sharing. "Husky" catch-can FTW. I mounted mine to the FSTB with aluminum brackets for the sport fishing industry.
erik loza is offline   Reply With Quote
Old 10-09-2007, 12:25 PM   #6
*El Ocho Uno*
Angry Old Man
*El Ocho Uno*'s Avatar
^^^ Always liked yours
386 rwhp / 395 lb/ft
http://forums.clubrsx.com/showthread.php?t=684348
Originally Posted by Doug Wilson
She needs some Cockamole on her Faceadilla!
*El Ocho Uno* is offline   Reply With Quote
Old 10-09-2007, 12:25 PM   #7
RSX Factor
this is my inner child
RSX Factor's Avatar
Holy shit, that mounting bracket is awesome. Wish I had that when I was trying to mount my GReddy catch can.
CRSX Louisiana...blocking traffic and getting dirty looks since 12/19 /04
RSX Factor is offline   Reply With Quote
Old 10-09-2007, 12:27 PM   #8
infraredrsx
I agree. Those brackets are pretty.
Old 10-09-2007, 12:28 PM   #9
*El Ocho Uno*
Angry Old Man
I actually need a bracket like that to better mount my oil pressure sender.
Where'd you get those, Erik ?
Old 10-09-2007, 12:35 PM   #10
erik loza
On the long road...
erik loza's Avatar
I don't think they sell over the net, but I bought them at my local Sportsman's Warehouse. They are a bracket for clamping fishing rod cups to the aluminum railing on boats. About $15 apiece, IIRC...
http://www.sportsmanswarehouse.com/fishing.cfm
Old 10-09-2007, 01:47 PM   #11
El_PiBe
Projectors....Mmmmmm
El_PiBe's Avatar
What are those catch cans for?
Nevermind...reading > me
2005Infiniti G35 Coupe 6MT
2006 Projectors// 13% Tint// Pioneer AVIC D3//HKS Hi Power Exhaust //Nismo Shift Knob
El_PiBe is offline   Reply With Quote
Old 10-09-2007, 02:04 PM   #12
SammySamSam
turbo=neverending debt
SammySamSam's Avatar
thank you very much for this post! I really appreciate it. Couple of questions tho. That seperator tank looks kinda small compared to the catch cans that are being sold. Will that seperator be big enough to hold all the blow by? also, can you show me any pics of where the hoses attach on the intake manifold?
03 NightHawk Black Pearl Type S,Greddy Turbo,FMIC,K-pro,
unforgettable Test pipe, Natedog 3" DP,2.5" DC Dual Cannister Exhaust,
Wings West Evo style CF hood, 18" buddy club sf
new project:t3/to4e garrett/borg warner hybrid
SammySamSam is offline   Reply With Quote
Old 10-09-2007, 02:21 PM   #13
flacopower
I hate VVT4ME
flacopower's Avatar
yeah.. just empty it out everytime you change your oil... if you have enough blow by to fill one of those big catch cans you got some problems
Old 10-09-2007, 02:23 PM   #14
*El Ocho Uno*
Angry Old Man
Ahhh OK, I'll check out some of my local boating places see if I find something similar
I'll hit you with some +rep again as soon as I can
Old 10-09-2007, 02:30 PM   #15
JayDM-'06
<3 Megan Fox
JayDM-'06's Avatar
Awesome put-together! Its gonna help me do it cuz ive been looking for a clear demonstration! +rep!
JayDM-'06 is offline   Reply With Quote
Old 10-09-2007, 02:34 PM   #16
erik loza
On the long road...
erik loza's Avatar
I need to drain mine at least once per month and the effluent seems to mostly fuel, with some oil in it. It smells strongly of gasoline. The infeed line is from the PCV outlet and the return line goes back to your manifold.
Old 10-09-2007, 02:41 PM   #17
*El Ocho Uno*
Angry Old Man
ever check to see how flamable that mixture actually is
Old 10-09-2007, 02:49 PM   #18
erik loza
On the long road...
erik loza's Avatar
Hahahhaaa... I actually need to drain it this week and am out of lighter fluid for the grill. Solve two problems at once.
Old 10-09-2007, 03:06 PM   #19
KazeSpec
KneeDragger in Training
KazeSpec's Avatar
NA motors wouldn't really need this would they? lol i'm looking for a cheap mod to do
Special Projects Motorsports, Pro-Car Innovations, Innovative Mounts, Amsoil, Blueprint Racing, AIT Racing, BuddyClub, LF.com
click: INfamoUS, All Motor Crew#14, Motorcycle Crew #37
need Spy sunglasses? PM me. Hardrace/PCI bushings PM me
KazeSpec is online now   Reply With Quote
Old 10-09-2007, 03:19 PM   #20
SammySamSam
i cant find my helms manual. any visuals?
Old 10-09-2007, 03:32 PM   #21
erik loza
On the long road...
erik loza's Avatar
PCV outlet is by the water pump, under the PS pump. Intake barb is right next to it on the manifold. It is clearly visible. You are simply splicing the catch can into the loop.
Old 10-09-2007, 03:33 PM   #22
KazeSpec
KazeSpec's Avatar
damn i was too slow lol. you should see it. as said it is right under the PS pump, it has a tube that connects to the IM. so can i get confirmation on above question?
Old 10-09-2007, 03:51 PM   #23
RSX Factor
RSX Factor's Avatar
Stole these pics from soccerman002's thread...
Basically pull this small hose out and replace with your hoses to the catch can.
Old 10-09-2007, 04:13 PM   #24
SammySamSam
thanks for all the responses. A special thanks to rsx factor for the pics!
as for N/A cars doing this, a buddy of mine had it done to his N/A car and he would get some oil in the catch can.
Old 10-09-2007, 04:14 PM   #25
Islanti
asdf
Islanti's Avatar
Good work. Here is another I would like to point out: DIY: Oil Catch Can For Under $20 (taken from k20a.org)
Supercharged Crew Member #12
2002 Acura RSX Type-S
307 horsepower / 231 torque (DynoJet) @ 7psi
Islanti is offline   Reply With Quote
Reply
Bookmarks
catch, diy, oil
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
