Serpentine Belt Change - Club RSX Message Board
Notices
Reply
Thread Tools
Old 12-15-2007, 10:18 AM   #1
Slow-02-RSX-S
Member
Slow-02-RSX-S's Avatar
Slow-02-RSX-S is an unknown quantity on c-rsx
Exclamation Serpentine Belt Change
any one know or have DIY serpentine belt change ? Never change it ever since i have the car, car has 110k miles on it, Now I started to hear speaky noise from it, I don't know if it from the serpentine belt it self or the Pulley because it getting old and rusty, looking for instruction on how to change the belt myself and fix the squeaky noise ! help Please !
2002 RSX-S
Injen short ram intake
Ingall Engine Damper
Mugen Replica Strut Bar
Jackson Racing Race Header
Greddy SP2 Catback Exhaust
Tanabe Sustec Pro S-OC type II coilver
yet with all the mod, it still Slowwwww !
http://www.pix2show.info/turtle.jpg
Future Mod:
Hondata Kpro
Jackson Racing SC
Slow-02-RSX-S is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-20-2007, 09:16 PM   #2
Steveodc5
VW's are a pain
Steveodc5's Avatar
Steveodc5 is an unknown quantity on c-rsx
here's the routing:
You've got to get a wrench on the tensioner pulley and turn it clockwise (toward the front of the car) to relieve tension on the belt so you can remove it (re-install it).
Good luck
'02 SSM S = SOLD
Snowboard Crew #5
Steveodc5 is offline   Reply With Quote
Old 12-20-2007, 09:34 PM   #3
soberstan
Good times.
soberstan is an unknown quantity on c-rsx
to be safe...have a buddy help you while you take the belt off...the tensioner is pretty heavy to pull on...u might need a breaker bar...unless your mad deez...
...(if it ends up being REALLY REALLY stubborn...take the pass. headlight off and ull have more space)
Broke Status.
soberstan is offline   Reply With Quote
Old 12-22-2007, 12:35 PM   #4
himrin1216
In the works... ^.^; ;
himrin1216's Avatar
himrin1216 is on a distinguished road himrin1216 is on a distinguished road
mines starting to squeak to i might have to try this
________
Marijuana bubbler
himrin1216 is offline   Reply With Quote
Old 01-28-2008, 05:36 PM   #5
swiftonesdc5
Senior Member
swiftonesdc5's Avatar
swiftonesdc5 is an unknown quantity on c-rsx
Do you need to absolutly use that special 14mm tool or could you use a regular breaker bar with a 14 on the end?? And from what I understand all you need to do is pull down on the tensioner pull out the old belt and slip in the new one?? I'm gonna be changing mine this weekend, mines making mad squeels and I'm smelling something like burnt rubber coming from that area, could that be the belt needing to be changed?? How often do you need to change the belt?? I'm at 70k...
swiftonesdc5 is offline   Reply With Quote
Old 01-28-2008, 05:55 PM   #6
RoachsRSX-S
Let the wind carry u home
RoachsRSX-S's Avatar
RoachsRSX-S is an unknown quantity on c-rsx
There is def not enough room in that area to get a breaker bar and socket on there. The job is simple with the serp. belt tool and crows foot, or you could use long 14mm open ended wrench .. but, I would recommend renting the serp. belt tool from autozone.
x Salty Grave x on XBL
00 NFR Honda S2000 former
03 ABP RSX Type-S former
RoachsRSX-S is offline   Reply With Quote
Old 01-31-2008, 11:01 PM   #7
jonathanmil26
Senior Member
jonathanmil26's Avatar
jonathanmil26 has been a little shit in the past
which one is the tensioner?
jonathanmil26 is offline   Reply With Quote
Old 02-01-2008, 12:17 AM   #8
Steveodc5
VW's are a pain
Steveodc5's Avatar
You can use work with two wrenches put together (open end on closed end) to add length and leverage to the concoction lol
O-------< O--------< Like so, insert one side of the open end into the closed end.. get it?
The top left arrow is pointing to the tensioner pulley
'02 SSM S = SOLD
Snowboard Crew #5
Old 02-01-2008, 12:32 AM   #9
jonathanmil26
Senior Member
when ur done taking off the belt how you put the new one?
Old 02-01-2008, 12:41 AM   #10
gamer123
dealer star
gamer123 has been a little shit in the past
Just had a mechanic replaced it few days ago, hope it'll last awhile.
gamer123 is offline   Reply With Quote
Old 02-01-2008, 10:52 AM   #11
Glimpse
Don't TILT
Glimpse's Avatar
Glimpse is an unknown quantity on c-rsx
Werd. I always just used an open-ended wrench but it pops off easily and you can hurt yourself if you aren't careful. Just get the tool it's fairly cheap.
2003 NBP A-Spec Type S
Injen: CAI Hayame: Exhaust Toda: Race Header, Valve Springs, Headgasket, N2 Cams, Front Swaybar Skunk2: SS Valves, Ti Retainers Energy Suspension: MM Bushings Hondata: IMG, K-Pro Unorthodox Racing: Ultra SS Pulleys JDM: ITR IM, ITR FD CRSX: Shift Bushings Exedy: Organic Clutch, Flywheel Quaife: LSD StopTech: BBK PowerSlot: Rear Rotors Techna Fit: SS Lines AXXIS: Metal Master Pads Motul: RBF 600 Xenon Depot: 5000k HID Spoon: Drain Bolts Grillcraft: Lower Grill
I love Pink Rsx
Glimpse is offline   Reply With Quote
Old 02-01-2008, 02:28 PM   #12
bwsteg
Master Member
bwsteg's Avatar
bwsteg is on a distinguished road
I just changed my recently. Took me 4 min exactly...
2002 Acura RSX Type-S K24a2 JRSC - SOLD 5/21/2011
BMW E92 335i 6MT - PURCHASED 6/8/2011 - SOLD
OEM Mtech Front and Rear | m3 Side Skirts | M-Sport Shift Knob | Continental DWS | BMS DCI | BMW Performance Exhaust | ER CP/Tial BOV | Zeckhausen Racing Modified CDV
bwsteg is offline   Reply With Quote
Old 02-01-2008, 02:52 PM   #13
Skottyyy
Senior Member
Skottyyy's Avatar
Skottyyy is an unknown quantity on c-rsx
wow this is perfect timing for it im doing it at my tech school for class assignment even tho i only have 41k on it. thanks for the diagram
Skottyyy is offline   Reply With Quote
Old 02-01-2008, 04:27 PM   #14
swiftonesdc5
Senior Member
Interesting, did you do all the work from the engine bay or did you have gain access through the side of the wheel well. I'm changing my belt after I get off work. Does the good year gatorback belt work very well??
Old 02-01-2008, 05:20 PM   #15
JaCkaL829
Car Care Extraordinaire
JaCkaL829's Avatar
JaCkaL829 is an unknown quantity on c-rsx
It looks like there is 0 room to do anything. I really need to change my belt since it's been squeaking like a mofo everytime it rains. I bought the replacement belt but it's been sitting in my garage since I'm very unsure of the procedure and have no time.
John
2002 NBP RSX 5 spd
http://www.flickr.com/photos/jackal829/
JaCkaL829 is offline   Reply With Quote
Old 02-01-2008, 06:56 PM   #16
RoachsRSX-S
I usually pull back the fenderwell liner so I can easily put the belt on the right grooves of the crank pulley. I believe that to be your best course of action.
Old 02-01-2008, 08:07 PM   #17
swiftonesdc5
Senior Member
This sux, I went to go pick up a belt from kragen and they don't have it in stock, nor does any autoparts store around my area have it in stock, I have to order it tonight... Guess I'll deal with the crickets for awhile till I get it.
Old 02-01-2008, 08:26 PM   #18
bwsteg
Master Member
bwsteg's Avatar
I installed the goodyear gatorback and no need to gain access through the wheel well. All you need is a long breaker bar... Make sure to move the p/s pump to the side...
Old 02-05-2008, 10:45 PM   #19
swiftonesdc5
Senior Member
Serpentine belt installed
So I got my belt in today, and I just installed it awhile ago. It was a fairly moderate job, not hard at all actually. It was easy getting the belt off, the only hard part was getting it on and around the pulleys. I didn't have to take off the fender wheel liner, all the work was done from the engine bay. It would help if you have great patience since the area is really small to work around. I manage though and it took me about 30-40 min all together since I had to move the belt around alot to get it around the pulleys. I highly recommend the serpentine belt tool, since it gives you great leverage to pull on the tensioner. So all in all, the job was really easy the more I look at it, the only hard part is putting in the new belt. Hope this will help some folks that need to replace their belt. If you guys have any questions feel free to pm me.
Old 06-05-2008, 03:58 AM   #20
FutureITR
Bye bye BOOST, i-Vtec now
FutureITR's Avatar
FutureITR might be well recognized one day on c-rsx FutureITR might be well recognized one day on c-rsx FutureITR might be well recognized one day on c-rsx FutureITR might be well recognized one day on c-rsx FutureITR might be well recognized one day on c-rsx FutureITR might be well recognized one day on c-rsx FutureITR might be well recognized one day on c-rsx FutureITR might be well recognized one day on c-rsx
How much do you tighten it?
Man, at least this is easier than the old B and D series motors.
No TDC thing to do or anything? And you meant you have to move the PS steering resovoir right?
The last form of my 2003 SSM Type S
Suspension: Ohlins DFV
Made 235hp/173trq Z1 cams + Bolt Ons.
FutureITR is offline   Reply With Quote
Old 06-05-2008, 07:07 AM   #21
RoachsRSX-S
The tensioner is auto-tensioning. There is no tightening it.
TDC would be if you changed the timing chain. We're talking about the serpentine drive belt.
Old 06-05-2008, 07:13 AM   #22
VTEC_Inside
Mmm, 3rd lobe...
VTEC_Inside's Avatar
VTEC_Inside is an unknown quantity on c-rsx
The K series has a spring loaded auto tensioner, no tightening required.
I'm a bit torn on which is easier though, this spring loaded tensioner, or f'ing with the adjusters on the old ones.
This is the accessory belt, not timing belt. K series has a chain.
Honda, The Heartbeat of Japan...
2006 Acura CSX Touring 160hp 141lb/ft
2004 Acura RSX Type S 6spd 200hp 142lb/ft
1989 Honda Accord Coupe LX 5spd 2bbl 98hp 109lb/ft
Slushies are something to drink, not drive...
Nikon Crew Member #23 | Gripped D700/D200, 2.8 from 17-200
VTEC_Inside is offline   Reply With Quote
Old 06-26-2008, 08:24 AM   #23
quevaj
Master Member
quevaj's Avatar
quevaj is on a distinguished road quevaj is on a distinguished road
is there a sound this thing makes when you know its wearing out? i have a whining, rotating sound but i dont have a clue what it is...
flickr
quevaj is offline   Reply With Quote
Old 06-26-2008, 10:26 AM   #24
PiMPtWiSt
Master Member
PiMPtWiSt's Avatar
PiMPtWiSt is an unknown quantity on c-rsx
when I turn my engine off I hear a squeeking noise. sounds like a gerbil wheel and I know its not my A/C(just had it replaced for the 4th time)
Originally Posted by TypeS Jay
Now if your hung like a Pringels can, then yeah it might cause some problems to her ass, lol.
100K club - member since Dec 08'
PiMPtWiSt is offline   Reply With Quote
Old 06-26-2008, 10:27 AM   #25
RSX FSU
RSX FSU is a glorious c-rsx member RSX FSU is a glorious c-rsx member RSX FSU is a glorious c-rsx member RSX FSU is a glorious c-rsx member RSX FSU is a glorious c-rsx member RSX FSU is a glorious c-rsx member RSX FSU is a glorious c-rsx member RSX FSU is a glorious c-rsx member RSX FSU is a glorious c-rsx member RSX FSU is a glorious c-rsx member RSX FSU is a glorious c-rsx member RSX FSU is a glorious c-rsx member RSX FSU is a glorious c-rsx member RSX FSU is a glorious c-rsx member RSX FSU is a glorious c-rsx member RSX FSU is a glorious c-rsx member
http://www.amazon.com/WILMAR-W84010-...4494037&sr=8-1
RSX FSU is offline   Reply With Quote
Reply
Bookmarks
belt , change , serpentine
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
