CEL - PO141 02 Sensor Heater Circuit Malfunction (bank 1 sensor 2) HELP! - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL > Problems & Solutions
Reply
Thread Tools
Old 12-27-2007, 03:10 PM   #1
chris_2002rsx-s
Senior Member
chris_2002rsx-s's Avatar
Yesterday car wouldn't start, oil was very low and car hasn't been maintained. 83000 miles so I changed the spark plugs and did an oil change.
Car starts and idles at 500-650 rpm, doesnt even go high to warm up, struggles to stay on.
I have type r hondata flash, r cams & manifold, aem cai, jrrh w/ obd1 carsound cat, and 5zigen exhaust.
so i get the reader from autozone and it tells me.
PO301 - cylinder 1 misfire
Caused Freeze Frame
I am trying to resolve this, will buying a new cat and secondary 02 sensor alleviate the problem, or is there more to this.
I was also thinking maybe something could be leaking air in the engine.
I don't know I am confused, LONG TIME board member, brother has the car need to fix it for him.
THANKS>
RSX-S Black
*cai/jrhdr/5zigen Exhaust
*R cams/manifold/flash
*Exedy Organic/Act Prolite
*azenis/x-brace/mugen replicas
*r rear sway/revo ss
chris_2002rsx-s is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-27-2007, 03:11 PM   #2
drumnatural
I can drive up your rsx
drumnatural's Avatar
You don't need to replace your cat. But u need to replace your secondary 02 sensor.
You treat your car like your girlfriend...Tender loving care along with giving her some WOT
[SIGPIC][/SIGPIC]
drumnatural is offline   Reply With Quote
Old 12-27-2007, 03:19 PM   #3
JPSlick
Master Member
JPSlick's Avatar
Search
NEw secondary o2 sensor. AS far as the misfire
C6 Z06 & GSXR 750
09 BMW 335i- Gone
02 RSX Type S- Supercharged w/ Nitrous - SOLD
My Youtube Video Channel
JPSlick is offline   Reply With Quote
Old 12-27-2007, 03:31 PM   #4
chris_2002rsx-s
Senior Member
Thats whats worrying me, BUT WHY would the car misfire or stall and run low rpm at idle from just a bad 2nd O2 sensor
Ive been running with a bad O2 sensor for a long time.
RSX-S Black
Old 12-28-2007, 12:11 PM   #5
AleRSX03
What??
AleRSX03's Avatar
bad o2 sensor, wont cuase low idle, ive run without one for awhile and the idle was fine, have ever cleaned ur iacv???
As for misfire code, not sure....try another spark plugs!!! Coil goin bad maybe???
Im just point u in some direction on things that i would check, i hope this help u
AleRSX03 is offline   Reply With Quote
Old 12-28-2007, 12:32 PM   #6
smokingtoysupra
04 Type-S
smokingtoysupra's Avatar
Spark plugs is your misfire problem. There is nothing wrong with your cat just buy an O2 sensor. You can actually run cars perfect without an O2 sensor, but it will sound like you have a huge exhaust leak.
smokingtoysupra is offline   Reply With Quote
Old 12-28-2007, 03:21 PM   #7
rensoyka
Breast inspector by appt.
rensoyka's Avatar
secondary O2 will throw a CEL unless you have K-pro, but won't affect anything else. if plugs are good, you have a bad coil pack or a sticking injector.
'06 black type-s.
rensoyka is offline   Reply With Quote
Old 01-02-2008, 05:03 PM   #8
chris_2002rsx-s
Senior Member
Little Update,
went to the muffler shop, the wires going into the secondary 02 sensor where unplugged, now I need to know how to put those 4 wires into the right location.
All of a sudden after stalling and having to drive the car with revs high,
it started idling normal.
Confusion, confusion.
RSX-S Black
Old 01-02-2008, 05:05 PM   #9
chris_2002rsx-s
Senior Member
I haven't touched the iacv> explain?
As for the Coil goin bad, how would I check that?
Im an goin to change to the new ob2 carsound highflow, because currently running the obd1 carsound cat.
RSX-S Black
Old 01-02-2008, 05:31 PM   #10
rensoyka
rensoyka's Avatar
It's likely that the undone wires from the secondary sensor were shorting out, causing your codes and problems.
'06 black type-s.
Old 04-24-2011, 05:25 PM   #11
02type_S
New Member
i have a similar problem.. i have a 02 RSX type S and my secondary o2 sensor got ripped from the plastic molex plug the other day when i hit something in the road. now i have 4 wires hanging that were completely pulled from the molex sliver pins and all. anyone know the placement of the wires? i cant find it anywhere.. please help!
2002 Acura RSX Type S
"...a work in progress"
02type_S is offline   Reply With Quote
Reply
Bookmarks
bank, cel, circuit, heater, malfunction, po141, sensor
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2001-2012, Club RSX, Inc. All rights reserved worldwide.
