daughter board communication error - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS RSX > ECU Tuning RSX
Notices
Reply
Thread Tools
Old 01-22-2008, 11:07 AM   #1
06rsxts
Senior Member
06rsxts's Avatar
06rsxts is an unknown quantity on c-rsx
I have a check engine light on my 06 type s so i checked it with kpro and two things come up. The first does NOT have a code...all it says is daughter board communication error (battery voltage low when cranking) and the second does have a code... (90-2) P1457 - EVAP control system leakage (canister system).
Im guessing the second code is from not haveing a catalytic converter even though I do have the defouler. I get this check engine light every now and then so I didnt think it was a big deal but recently when i would accelerate under WOT in 1st and 2nd gear vtec would actually cut out at like 5-6k rpm and come back in at like 7k rpm til redline. Third gear seams fine but I just dont understand why first and second gear are acting up on me...I appreciate any help
06rsxts is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-22-2008, 11:13 AM   #2
krystar
Master Member
krystar's Avatar
krystar is an unknown quantity on c-rsx
that second code isn't catalytic related. did u overfill yer gas tank? gas cap open?
1st code is low battery voltage or a bad board connection or a bad cable or something.
Originally Posted by DJCarbine
I have a 6 sheets of paper in front of me, all of them my fuel maps. I'm noting where to add and take away fuel.
This is the most work I've done at work EVER
krystar is offline   Reply With Quote
Old 01-22-2008, 11:24 AM   #3
06rsxts
Senior Member
06rsxts's Avatar
hmm maybe i possibly overfilled the tank...
any ideas as to why vtec doesn't engage properly?
Old 01-22-2008, 11:31 AM   #4
06rsxts
Senior Member
06rsxts's Avatar
here are 3 datalogs i did before...1st and 2nd gear in one...vtec disengages at around 4k rpm...the other 2 runs are third gear pulls...i think everything is ok in the third gear pulls tho
Old 01-22-2008, 11:40 AM   #5
krystar
Master Member
krystar's Avatar
check yer solenoid? oil level?
Old 01-22-2008, 12:55 PM   #6
rensoyka
Breast inspector by appt.
rensoyka's Avatar
rensoyka is an unknown quantity on c-rsx
the first code is for low voltage when you try and start the car. either your battery needs charging or needs to be replaced or you need to check the engine and ECU grounds.
the second code happens automatically with '05-'06 models because we use an '02-'04 ECU. the ECU is looking for an evap device that isn't present on our cars so it throws P1457. disable OBDII on K-pro or it will keep coming back, although it doesn't affect performance.
'06 black type-s.
rensoyka is offline   Reply With Quote
Old 01-22-2008, 01:59 PM   #7
06rsxts
Senior Member
06rsxts's Avatar
hmm i thought i had it disable to begin with...i have to check...thanks!
Old 01-22-2008, 02:08 PM   #8
Danrsxtypes
Back to stock :(
Danrsxtypes is an unknown quantity on c-rsx
Hey Rensoyka, do I still have to disable OBDII even tho I have hf cat?
Parts FS support my addiction
http://forums.clubrsx.com/showthread.php?t=854458
05 JGM SOLD!!
08 OBP sti hatch more junk in the trunk
01 OBP RS 2.5 SOLD!!
07 Impreza Wagon family hauler project
Danrsxtypes is offline   Reply With Quote
Old 01-22-2008, 02:37 PM   #9
rensoyka
rensoyka's Avatar
The hi-flow cat should keep P0420 from coming up, which is the CEL for no cat, but you can still disable it with the K-pro parameters as well. If you don't want the P1457 CEL to come on, you need to disable it, otherwise you will be fine by just clearing it whenever it comes up. Disabling OBDII with the misc parameters makes 4 codes not appear at all: secondary O2, ECU baro sensor, ELD and evap sensor. None of these affect performance as far I know, and you can clear them at any time if you don't disable them.
'06 black type-s.
Old 01-22-2008, 02:54 PM   #10
Danrsxtypes
Back to stock :(
The code has not showed up yet, so i guess I'll leave enable.
05 JGM SOLD!!
Old 01-22-2008, 06:57 PM   #11
Axix23
Axix23's Avatar
Axix23 is an unknown quantity on c-rsx
When your cel comes on, does your immboli light keeps flashing too?? Does it still let you crank the car up???
FORSALE: FS: ONE MINT 17x8" Gunmetal SSR Type-C-RS wheel, Black T1 Racing turbo blanket, NEW Tial 44m WG Spring(2.9psi), NEW Tial 50mm BOV 11 psi spring, NEW o2 extension, OEM RSX-S injectors with clips, pair of Digital h1 3k Hid bulbs, and NEW Gatorback 4070775 belt, PM me for prices....
Axix23 is offline   Reply With Quote
Old 02-01-2008, 08:42 PM   #12
mo1113
03
mo1113 is an unknown quantity on c-rsx
im having the same problem with the daught communication code when the light is on the car wont rev pass 4k when i erase the code everythings fine again, but the code returns after a couple days. looking for some help as well
mo1113 is offline   Reply With Quote
Old 02-02-2008, 08:10 AM   #13
rensoyka
rensoyka's Avatar
read the first line of post #6.
'06 black type-s.
Old 08-27-2009, 04:20 PM   #14
ddoouugg
Senior Member
ddoouugg is an unknown quantity on c-rsx
I have the exact same 2 codes coming up in my 03 base rsx. I have kpro and prb mani and prb tb though. I should have the evap system correct? ANd the daughter board communication error? I don't see what that oculd be from. My battery is very new and I have not experienced any problems with grounding before. What do you think?
I like cheese!
ddoouugg is offline   Reply With Quote
Old 08-27-2009, 04:32 PM   #15
krystar
Master Member
krystar's Avatar
did you relocate the engine harness ground to the cylinder head?
Old 08-27-2009, 04:44 PM   #16
ddoouugg
Senior Member
yes i did. It has been that way for a while and ther were no problems before now. Is that the problem?
I like cheese!
Old 08-27-2009, 04:50 PM   #17
krystar
Master Member
krystar's Avatar
wouldn't hurt to clean that ground and reconnect it...but if not that...then something else is going on. even though it's a new battery, have you checked your battery voltage w/o the engine running?
Old 08-27-2009, 05:03 PM   #18
ddoouugg
Senior Member
My battery reads about 12.4 volts. I will clean the ground another time when the engine isn't so hot. I reset the ecu and I will see if the codes come back. I'm gonna drive it now.
I like cheese!
Old 08-28-2009, 01:24 AM   #19
craze89
ummmm VTEC!
craze89's Avatar
craze89 is an unknown quantity on c-rsx
im having this same problem as well and it is very frustrating. im stuck in limp mode until i clear it with my laptop. so i need to bring my laptop wherever i go when i drive my car. i sanded all the grounds so they are practically clean grounds and i also sanded where the grounds touch the metal on where they bolt on to.
i also have a fairly new battery and got it charged at autozone.
i dont think i have a failing alternator because when i checked my voltage on the batter with the multimeter it was always averaged to be the same throughout a series of readings.
unfortunately i forgot the readings when i did them ( yah i know i should have written them down..)
don't know what it could be either. but if you find the problem TS please let me know because it is very frustrating. ive been having the problem for about 5 months.
i even did the "big three" cable mod to change the stock grounds to bigger gauged ones and added the same size gauged wire from the chassis to the long alternator bolt.
i also moved the engine harness ground from the intake manifold to the valve cover bolt that hondata recommended.
i hope im not thread jacking TS but i beleive our problems are similar anyways
2003 Acura Rsx Type - S
craze89 is offline   Reply With Quote
Old 08-28-2009, 08:36 PM   #20
craze89
ummmm VTEC!
craze89's Avatar
figure anything out yet TS?
Old 08-29-2009, 01:00 AM   #21
ddoouugg
Senior Member
the ts hasn't posted here since 2008. If you're talking to me, I reset the ecu and cleaned my connection. The cel hasn't turned back on yet. knock on wood. I still don't understand the evap system code.
I like cheese!
Old 08-29-2009, 03:08 PM   #22
craze89
ummmm VTEC!
craze89's Avatar
lol I guess I'm talking to u now haha. I didn't look at the dates of the posts.
what did you do to clean them? just sand the metal?
I've reset the ecu (unplug battery for quite some time) and cleared security through kpro as well.
I don't know what else to do though
Old 08-29-2009, 04:26 PM   #23
rensoyka
rensoyka's Avatar
http://www.hondata.com/forum/viewtopic.php?t=4877
'06 black type-s.
Old 08-29-2009, 08:49 PM   #24
ddoouugg
Senior Member
I just got the code for the evap canister again. Could this be from an installation fault while installing my prb manifold and tb? Is it just for emissions so it's safe to drive? sorry if its the wrong thread
I like cheese!
Old 08-29-2009, 08:53 PM   #25
ddoouugg
Senior Member
I just opened my gas cap and a lot of pressure was released from inside the tank. Does this mean there actually is a problem with my evap canister?
I like cheese!
Reply
Bookmarks
board , communication , daughter , error
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
