Old 02-11-2008, 01:23 PM   #1
jonnybfast
Member
jonnybfast's Avatar
1st time wax!
I am believe it or not gonna wax my car for the first time, I usally pay to get it done, but i rather do it my self since i love my car and cant let anyone touch the 06 pwp paint other than myself. I am a noob I know but what is the best way to wax so i dont fuck it up. I hand wash it once a week and the paint looks perfect its just not slick to touch!
any feedback is appreciated!
jonnybfast is offline   Reply With Quote
Old 02-11-2008, 01:34 PM   #2
Costco
1. Use good quality microfiber towels/applicators (the ones with silk lining are nice)
2. Apply just enough pressure but dont press to hard, rub in back and forth motion vs. a circular motion.
Costco is offline   Reply With Quote
Old 02-11-2008, 01:38 PM   #3
jonnybfast
Member
jonnybfast's Avatar
should i follow the lines of the car and how long should the strides be?
Thanks for the quick response too!
Old 02-11-2008, 02:15 PM   #4
Type-Jeff
<RSX3
Type-Jeff's Avatar
following the lines of the car and the length of the strides don't matter when waxing a car. the most important rule is to make the the wax goes on thin and also, depending on the wax, make it sure it dries to a haze before removing. don't apply wax with a dirty pad, if it falls on the ground while waxing, get a new one. when removing, ALWAYS use a clean microfiber towel or else you cause unnecessary swirls while removing the wax. since i'm assuming you have never bought a wax before, i suggest for OTC and buying meguiars NXT paste or liquid wax from any auto store because that wax is great from OTC. make sure you wax your car every 2-3 months to keep your car looking clean and fressssssssh.
hope i helped.
Motorcycle Crew #650
2006 Ninja 650r
Type-Jeff is offline   Reply With Quote
Old 02-11-2008, 02:35 PM   #5
jonnybfast
Member
jonnybfast's Avatar
hope i helped.
definitly helps!! thanks
How many microfiber towels will i go through when i wax my car? one per each side(front, back, driver, passenger)
Old 02-11-2008, 03:29 PM   #6
MD02RSX-S
ADVAN'S FTMFW!!!
MD02RSX-S's Avatar
depending on the size of your MF towl you can fold it over so that you can turn the towel over and use the other side for the next section. Once you are all done go over it all again with a separate MF towel. Good luck.
WA TODA CREW MEMBER #3
06' CBR600RR Motorcycle Crew Member #200600
02' RSX-S
MD02RSX-S is offline   Reply With Quote
Old 02-11-2008, 03:58 PM   #7
DC5Berry
Communication Breakdown!
DC5Berry's Avatar
Here you go buddy, page 40 - 45ish
http://home.comcast.net/~michael.coh..._Hand_Book.pdf
Always check the stickies b/c more than likely, it has been covered in great "detail", no pun intended
'04NBP
DIY JDM style headlights, 06 Type-S rims, Fujita SRI, Red-Outs
I detail...on the side.
M.D.(Memphis.Detailer.) Crew Member #1
MEMPHIS TIGERS!
DC5Berry is offline   Reply With Quote
Old 02-11-2008, 06:35 PM   #8
jonnybfast
Member
jonnybfast's Avatar
Thanks , you are so correct!
Old 02-11-2008, 11:25 PM   #9
jesselyons2002
Need Help ?
hope i helped.
I would follow the line. Cause you can get unwanted wax in the crevice.
jesselyons2002 is offline   Reply With Quote
Old 02-12-2008, 10:28 AM   #10
dazzerjp
Senior Member
Also, dont push too hard on the applicator, but do work the wax in until it breaks down. it takes a while with some waxes, but the wax should go clearer.
this helps when wiping offthe residue wax.
dazzerjp is offline   Reply With Quote
Old 02-12-2008, 12:21 PM   #11
DC5Berry
DC5Berry's Avatar
IME, I've never had to "break down" a wax. I've had to break down polishes. Wax is simply applied and removed according to the directions on the product label.
'04NBP
MEMPHIS TIGERS!
Old 02-12-2008, 01:06 PM   #12
yeah
Senior Member
exactly. all you do is apply and wipe off excess
yeah is offline   Reply With Quote
Old 02-12-2008, 04:49 PM   #13
Frosty
Administrator
Frosty's Avatar
Frosty is a jewel in the rough of c-rsxFrosty is a jewel in the rough of c-rsxFrosty is a jewel in the rough of c-rsxFrosty is a jewel in the rough of c-rsxFrosty is a jewel in the rough of c-rsxFrosty is a jewel in the rough of c-rsxFrosty is a jewel in the rough of c-rsxFrosty is a jewel in the rough of c-rsxFrosty is a jewel in the rough of c-rsxFrosty is a jewel in the rough of c-rsx
1 - Read the newbie thread.
Frosty is offline   Reply With Quote
Old 02-13-2008, 05:06 AM   #14
dazzerjp
Senior Member
i just knew somebody would say that...
with a lot of waxes, when u are applying the wax you need to very gently rub the wax until it @breaks down@ and the finish is matted but consistnet.
the application process is somewhat dependent on the wax, but as an average piece of begineer advice, i would reiterate that the person waxing think in terms of breaking down/in the wax.
the is oppossed to the oft seen; rub in a bit of wax, wait for it to dry and then wipe off. u need togently work in the wax - unless its some cheapy polymer wax witha glue base in which case the opposite is true.
@Use a small amount of wax at a time, and rub it in well. If you use too much wax, you're wasting the product and your time.@
http://autopia.org/forum/guide-detai...-your-car.html
note the rub it in well. not just apply and wipe off.
Old 02-13-2008, 06:54 AM   #15
jonnybfast
Member
jonnybfast's Avatar
thanx guys for all the feed back... it really is helping me better understand how to wax so that my car comes out the best that it can!
Reply
Bookmarks
1st, time, wax
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
