Door Removal + Door Actuator Replacement. . . - Club RSX Message Board
Notices
Reply
Thread Tools
Old 03-22-2008, 12:21 PM   #1
RedRiderRSX-S
Senior Member
RedRiderRSX-S's Avatar
RedRiderRSX-S is an unknown quantity on c-rsx
THIS IS MORE FOR THOSE FIRST TIMERS MESSING WITH THE RSX DOORS. . .
You would think is self explanatory, but i did not know what was involved with the door removal and replacing of the door actuator. . . I would say the removal of the door panel is about a 1 out of 10, the door actuator is a 5.
Driver Door Actuator part #72155-S5P-A11 $ it ranges from $25 to 64, depending on dealership. (Passenger Door Actuator is #72115-S6A-J01)
First off. . The large arrows shows the sequence i went in. . The circles are the screws that needed to be removed.
Above: Remove panel behind the handle. Use a small screw driver to unclip it. Lift on the little tab and it should pop right out.
Above: Unclip the power to the door locks
Below: Be careful with these plastic clips (purple clip) to remove the rods
Below: Unplug the power windows clip.
DOOR PANEL SHOULD BE FREE!
For the Actuator. . .Continue. .
Above: Pop off the gasket holding the plastic in place
Below: Again, be careful with the removal of the plastic clips when removing the two rods, a gold one and a smaller silver one.
Below: Unscrew the three screws at the side of the door.
Remove black plug to release the shroud around the door lock.
Boom. . there is the actuator.
Remove one black screw from the metal plate. Replace actuator. .
Repeat procedure backwards. .
Good Luck!
RedRiderRSX-S is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-22-2008, 12:52 PM   #2
IMC
That Dead Pedal Guy
IMC's Avatar
IMC is an unknown quantity on c-rsx
Nice man.. I've been putting off giving Acura the $100 CDN for the stupid door actuator for like 6 months now lol...
Thanks for the DIY, it'll be very helpful
IMC is offline   Reply With Quote
Old 03-22-2008, 01:22 PM   #3
RedRiderRSX-S
Senior Member
No prob. . i just did it this morning. .
it is not that bad. . Those plastic clips were the biggest pain. . i want to say it took about an hour and 1/2 to do. . . and that was cause i started to put it all together. .and forgot about the little black screw for the actuator. . i had to take it all apart again. . If you are experienced with taking things apart. .this should be a breeze. .
Old 03-22-2008, 06:32 PM   #4
spd579
Master Member
spd579's Avatar
spd579 has been a little shit in the past
I cant figure out how to get the door panel free from where it connects to the handle.....I see that you unscrewed 3 screws from behind the handle but how do you get to them? thanks
05 RSX-S DD
89 Miata--400 hp go-cart
03 350Z Track--In between ride
spd579 is offline   Reply With Quote
Old 03-22-2008, 07:54 PM   #5
RedRiderRSX-S
Senior Member
Behind the handle, there is a little clip. Lift the little clip up and the panel slides out. Use a sharp object, i used a small screw driver, and popped it out. . behind that panel are the 3 screws.
Old 03-23-2008, 12:47 AM   #6
spd579
Master Member
spd579's Avatar
yep I got it, does anyone know if they make lexan or FAL side windows for the RSX?
05 RSX-S DD
Old 03-23-2008, 08:08 AM   #7
RedRiderRSX-S
Senior Member
I'm sure someone out there can make them. . but i would not know the first thing about going about it. Sorry. . .
Old 03-23-2008, 10:40 PM   #8
Nguyen
RSX-less
Nguyen's Avatar
Nguyen is an unknown quantity on c-rsx
Good write up.
Nguyen is offline   Reply With Quote
Old 03-24-2008, 01:01 AM   #9
VIP
F*CK YOU
VIP's Avatar
VIP is cool, not as cool as some though VIP is cool, not as cool as some though VIP is cool, not as cool as some though VIP is cool, not as cool as some though VIP is cool, not as cool as some though VIP is cool, not as cool as some though VIP is cool, not as cool as some though VIP is cool, not as cool as some though VIP is cool, not as cool as some though VIP is cool, not as cool as some though VIP is cool, not as cool as some though
i just replaced mine recently and removing that rod was a bitch.
i recommend some pliers to pull the gold rod out.
VIP is offline   Reply With Quote
Old 03-24-2008, 07:22 AM   #10
RedRiderRSX-S
Senior Member
I found that a small screw driver worked great for those little clips . . . that and my fingers. .
Old 04-01-2008, 03:25 PM   #11
quevaj
Master Member
quevaj's Avatar
quevaj is on a distinguished road quevaj is on a distinguished road
where have you guys been ordering your parts?
quevaj is offline   Reply With Quote
Old 04-01-2008, 03:48 PM   #12
RedRiderRSX-S
Senior Member
I would recommend the dealership. .
I see that they range in price from dealership to dealership. . Where i am , it was $54.00.
I got it off of someone here for $32.00 shipped. .
Ask around. .
Old 04-01-2008, 03:54 PM   #13
quevaj
Master Member
quevaj's Avatar
thanks man. +rep for you!
Old 04-02-2008, 09:13 AM   #14
RSSEXtype-sizzle
BeKWeeZee
RSSEXtype-sizzle is an unknown quantity on c-rsx
good writeup, thanks man
[SIGPIC][/SIGPIC]
RSSEXtype-sizzle is offline   Reply With Quote
Old 04-02-2008, 06:31 PM   #15
LABELKiLLz
Everyday im shufflin'
LABELKiLLz's Avatar
LABELKiLLz is an unknown quantity on c-rsx
nice... now i just need a passanger side door actuator! ;]
LABELKiLLz is offline   Reply With Quote
Old 04-02-2008, 07:32 PM   #16
Frunkis
Casual Scum
Frunkis's Avatar
Frunkis is an unknown quantity on c-rsx
I just had my first experience removing my doors and it was actually kinda frustrating. I just started transferring my audio equipment into the RSX. (I just bought it yesterday.)
After tugging and wrestling with it for oh, an hour and a half or so (I wish I had seen this guide EARLIER! ) I got it hanging by one harness only to realize that I'd have to drill my own holes to fit in my Infiniti 6.25's... I don't have a power drill here at the house so needless to say I was pissed off.
I am without front speakers at the moment until I can secure a drill. At least I got my knees muddy and taught myself something tonight.
Anyways... nice writeup!
Frunkis is offline   Reply With Quote
Old 04-02-2008, 08:47 PM   #17
RedRiderRSX-S
Senior Member
thanks man. . before i do something to the RSX. . i try to look on here first to see if there is anything i should look for or be aware of. . I hope it helped!. . maybe a little. . .
GL on the drill!
Old 04-02-2008, 08:47 PM   #18
RedRiderRSX-S
Senior Member
That's the expensive one from what i have heard! GL!
Old 04-06-2008, 05:48 PM   #19
Iluvferrari
fudge em
Iluvferrari's Avatar
Iluvferrari has been a little shit in the past
Thanks for the write up I just did this yesterday and it helped a lot. One thing to add though is you have to remove one bolt that holds the window frame thingy. I couldn't get the acuator out unless I removed that bolt so I could move the frame out of the way.
This is my signature
Iluvferrari is offline   Reply With Quote
Old 04-18-2008, 11:54 AM   #20
kavmon3
Member
kavmon3 is an unknown quantity on c-rsx
Thanks for the write up.
Does anyone have any suggestions on how to remove the 3 screws on the side of the door? I tried wd-40, but still no luck.
kavmon3 is offline   Reply With Quote
Old 04-18-2008, 12:28 PM   #21
RedRiderRSX-S
Senior Member
I used my Dewalt drill. They came right out. . .
Old 04-25-2008, 09:23 AM   #22
kavmon3
Member
I tried using a drill and it looked like it was stripping the screws.
Old 04-26-2008, 10:33 PM   #23
monkay
oh hai
monkay's Avatar
monkay is an unknown quantity on c-rsx
somebody wanna do this shits for me?
Originally Posted by devrules81 View Post
i just farted
i think more then just air came out
heading to the shower
flickr
monkay is offline   Reply With Quote
Old 04-26-2008, 10:50 PM   #24
JM RSX
Hung
JM RSX's Avatar
JM RSX is an unknown quantity on c-rsx
gj on write-up, my friend needs to do this pretty bad he control locks his car, then manually locks his driver door for like a month now. lmfao.
JM RSX is offline   Reply With Quote
Old 04-28-2008, 07:28 AM   #25
RedRiderRSX-S
Senior Member
I did it for about two or so before i just got tired of doing it. .
It really is not that bad of a job. . just be patient. . don't break the plastic tabs and lose any screws.
Reply
Bookmarks
actuator , door , removal , replacement
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
