Old 03-23-2009, 10:35 PM   #1526
hummerbum16
Master Member
hummerbum16's Avatar
Hey woot, I'm looking into getting that seibon mg style hood that u have. Would I need hood pins if I installed the PWJDM hood dampers?
06 Type-S (ASM)| BC Pro Spec 65mm| Injen CAI
My New Pro Spec Vid
hummerbum16 is offline
Old 03-23-2009, 10:38 PM   #1527
WooTIHaveATypeS
Boost Slut Krew Member #1
WooTIHaveATypeS's Avatar
WooTIHaveATypeS is a rep WHORE
WooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHORE
I dont use hood pins on mine. I dremeled the slot where the hood latch sits.. I dremeled that oval out farther down so the hood latch would hold it down tighter. I drove it like that for over a year and a half. At like 75mph you could see the hood shake around some but I took it well over 100mph many times and it's still on so... lol. Now with the hood dampers on there, it doesn't vibrate around at all on the highway at higher speeds so all is good.
11.79 @ 120MPH - Bandimere Speedway, CO
SuperFlow Dyno Tuned - 91 - 440whp 330wtq @ 18lbs - Thanks Brian!
DynaPack Dyno Tuned - 91 - 525whp 340wtq
My In-Depth Build Threads:http://forums.clubrsx.com/showthread.php?t=674689
WooTIHaveATypeS is offline
Old 03-23-2009, 10:39 PM   #1528
iBoost
Nut Up or Shut Up
iBoost's Avatar
iBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii Fit
iBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii Fit
Originally Posted by Fade2Black View Post
dont really know if it makes a difference but i've always installed those with the big part of the shock towards the bottom
i installed it how PWJDM told me to install it with the thicker part up top... still dont know if it makes a difference. mine have worked flawlessly for a few years now.
Boost Slut Krew Member #16
Custom Slowmotion Motorsports GT35R Setup
458whp / 325 wtq @ 12psi - Pump Gas
iBoost is online now
Old 03-23-2009, 10:49 PM   #1529
hummerbum16
Master Member
Good deal. Could I get away with just the dampers?
My New Pro Spec Vid
Old 03-24-2009, 09:22 PM   #1530
Lower Elite
CLUBRSX Supporter
Lower Elite's Avatar
What's going to hold the hood down....
2006 ASM RSX Type S
q/___\p
/Oo.\\_. A ._//.oO\
\_o__|R S X|__o_/
Lower Elite is offline
Old 03-25-2009, 06:29 PM   #1531
Carboncrsxtony11
Member
Carboncrsxtony11's Avatar
mmmm I smell something good whats cookin mom, some headers you fuk.
Carboncrsxtony11 is offline
Old 03-25-2009, 06:54 PM   #1532
hummerbum16
Master Member
Does it not come with a hood latch?
My New Pro Spec Vid
Old 03-25-2009, 06:57 PM   #1533
iBoost
Nut Up or Shut Up
iBoost's Avatar
Old 03-25-2009, 07:03 PM   #1534
hummerbum16
Master Member
Originally Posted by iBoost View Post
My New Pro Spec Vid
Old 03-28-2009, 09:32 PM   #1535
edward77
Senior Member
woot can you make some more videos of you doing highway pulls?? Cause you make some sick vids
edward77 is offline
Old 03-28-2009, 10:31 PM   #1536
06k20dc5
My lIl BoXeR
06k20dc5's Avatar
lol
06k20dc5 is offline
Old 03-28-2009, 10:49 PM   #1537
Nino
11.88 @ 120 mph
Nino's Avatar
Nino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their own
Nino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their ownNino must be an admin because here is no way they could have reached this amount on their own
headers huh
Boost Slut Krew Member #6
My Build Show-Off DIY Carputer Fuel Return Setup
Nino is offline
Old 04-11-2009, 01:50 AM   #1538
Nokama
Senior Member
If you're coming down from denver then tomorrow is your chance right?
That stretch right before you hit Monument is pretty straight and flat. Do et
04 Base RSX, beater status paint job
08 WRX Spark Silver Metallic
Nokama is offline
Old 04-11-2009, 01:52 AM   #1539
WooTIHaveATypeS
Brian is gonna work on my tune tomorrow once I get to the Springs. We are dynoing on may 2nd and then I'll be fully ready to make some sick vids.
Old 04-11-2009, 01:56 AM   #1540
Nokama
Senior Member
Bbq
So I'll try to stop by at 12:30 tomorrow. Woot says you guys are BBQ'ing. I can def bring something. What do we need still, beer? Let me know.
Nokama is offline
Old 04-11-2009, 02:03 AM   #1541
WooTIHaveATypeS
Wrong thread foo!
Old 04-11-2009, 02:08 AM   #1542
Nokama
Senior Member
Wrong thread foo!
Shit....
Nokama is offline
Old 04-14-2009, 11:21 PM   #1543
pr2rm128
Member
pr2rm128's Avatar
having a pretty similar build to yours i wanted to reach out to you about a recent problem i ran in to. finally after more than a year i got my car on the dyno for the tune. happy to say i got 450whp at 15psi. the problem i ran into was that i started getting boost creep around 7800. i believe the solution is to upgrade my wastegate to a 60mm. is this a reasonable fix to the problem? any suggestions?
for now i will be driving it at those numbers cutting rpms at 7700 until i have some more time to get this straightened out. im pretty stoked at the outcome and feel that with the right tune without boost creep i could run near 500whp as a dd.
Any help would be greatly appreciated
pr2rm128 is offline
Old 04-15-2009, 12:35 AM   #1544
WooTIHaveATypeS
Who tuned your car? What psi is it creeping to? Did you make those numbers with the creep or without it? Your tuner should be able to control creep if they are using the boost control through kpro.
Old 04-15-2009, 09:48 AM   #1545
pr2rm128
Member
pr2rm128's Avatar
a local tuner that i had build the car. from what i was told it creeps to 17psi around 7900rpms. the numbers were made without the creep but quite certain it will make a lot more when i get this problem resolved and can set my redline at 9200. i'll have to check on the boost control. i read this exact problem in another thread but can't seem to find it since there are so many peak boost builds on here
pr2rm128 is offline
Old 04-15-2009, 10:37 AM   #1546
WooTIHaveATypeS
So if he made 450whp on a 15psi tune that ran to redline without creeping then why not use that tune? What changed? Im confused lol. But yeah you should be able to control the creep through the duty cycle tuning and boost tables in kpro. What spring do you have in the wastegate?
Old 04-15-2009, 11:24 AM   #1547
Jrsx
Boost > Vacuum
Jrsx's Avatar
Good job on the 2nd gear woot!
I did the exact same thing on the track with slicks running 305WHP supercharged.
I'm coming over to the dark side very soon!!
My PB GT3582R kit will be here by May21st!
HPC coated with a anodized black intercooler
02 RSX Type-S PeakBoost GT3582R
Jrsx is offline
Old 04-15-2009, 11:39 AM   #1548
Jrsx
Boost > Vacuum
Jrsx's Avatar
Heres the video of when my 2nd went.
you can hear the car just bounce of the rev limiter
http://www.youtube.com/watch?v=-l-AB...eature=channel
Jrsx is offline
Old 04-15-2009, 11:40 AM   #1549
EastCoastDC5
Member
WOW, great build.
EastCoastDC5 is offline
Old 04-15-2009, 12:01 PM   #1550
WooTIHaveATypeS
Funny, I got my 2nd gear blowing up on vid too.
It was already crippled and finally broke here: http://videos.streetfire.net/video/B...2nd_639631.htm
Closed Thread
Bookmarks
build, gt3582r, peakboost, thread or guide, wootihaveatypes
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
