#51 |
wtfhax0r
ah, i'm just getting into the turbo scene right now and i can't stress how much this has helped me. awesome write up man thanks
TooZooted#1 HotAvy&SigKrew Rsx Vs All Asshole Crew Member #35 | [SIGPIC][/SIGPIC]
| Sponsored Links | |||
Advertisement | |||
#52 |
New Member
i have a TO4E Turbo set up, plan on running only 8psi, do i need a ecu upgrade? or is a a/f controller good enough? I really need to now this answer.
E-mail: Whyskate1@aol.com Phone: 910-257-6101 Thanks 4 ur time!!! |
#53 |
S372
Richard,
hey man heres the link to the thread i told you about. http://forums.clubrsx.com/showthread.php?t=586448 i am still doing some research on the injector size for you i will let you know when i fin something out.
--Life is not a journey to the grave with the intention of arriving safely, in a pretty and well preserved body; but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming,"Wow ---- What a ride!!!"-- |
#54 |
S372
Richard,
i would do the 550's man the 440's would work i just worry about the duty cycle thats just my opinion.
#56 |
DET: 39-40
Dang, nice writeup dude, I just read through all of it. I now realize how expensive a turbo build can be, even the Log Style 400 WHP Kit you came up with is well over the amount I was expecting.
Nice work.
#57 |
Senior Member
Very useful writeup. Thank you. I have one question, I am in your ballpark with the DD function for the car minus the track car part. So my question is, what are the most KEY (most minimum) parts to be upgraded if I get the turbo you have described? (trying to be on the economical side, damn economy is gone to the poooper)
#58 | |
Automotive Noob
![]() This thread helps a lot. Would it be too much if you could help me create a list of parts for a custom kit if my budget range is $3500?
2006 BOM type-S http://forums.clubrsx.com/showthread.php?t=594531 Front Grill Badge Fujita F5 |
#59 |
S372
No problem man pm me and we can either talk over im or on the phone which ever is easier for you.
#60 |
The Blue Bomber
ok so I got 2 questions.
#1 - if a turbo says "horsepower: 150-250" that means the horsepower it will increase above your vehicles current base hp right? #2 - as well im sure the a/r size on the cold side of the turbo is important in some aspect, the a/r size on the hot side determines your bottom-end torque or top-end hp rating right? (ie: larger a/r means higher top-end hp, where lower a/r means better bottom-end torque but less hp on the upper rpms |
#61 | |
Senior Member
#2 - for the turbine (hot side) a/r, the higher the number the higher the top end but longer spool up. Lower the number means it'll spool up quicker. |
#62 | |
The Blue Bomber
if a turbo lists a set of numbers for a HP rating that is the total HP your car would make with that turbo? (ie: im looking to make 300-350 hp in my RSX so a Garrett GT2252 which says HP:150-260 would not allow me to reach my goal then right?) and usually a quicker spooling turbo will not produce as much top-end hp than a larger slower spooling turbo right? (ie: my turbo spools up really quickly at the lower rpms and am getting full boost by 3k, but around 6k I start to lose about 3psi) ... or would that be a whole different problem entirely? |
#63 | |
Senior Member
To your second question, yes a faster spooling turbo smaller turbo will produce less top end than a bigger slower spooling turbo. However, to your question on losing psi towards redline, I think some of the greddy kits were doing that, I'm not sure. I don't understand why you would drop psi, because when you think about it, unless you have a boost leak somewhere, you shouldn't drop boost if you're still full-throttle. |
#64 | ||
The Blue Bomber
im currently running a custom pieced setup: Revhard mani & dp - turbonetics evo wastegate set to 10psi greddy FMIC and piping - turboxs bov PSR intake plenum extender and TB plate Vacuum dist block 650cc injectors Generic Garrett T3/T4 Turbo .50 a/r cold - not sure the hot side Kpro non-recirc dump pipe I drilled and tapped the IM so I could run a steel-braided line for the brake booster highflow 3" cat into 2.5" piping for the exhaust it needs to be retuned, so that could also be the issue. unless I got a leak, not sure how to check without just retighening everything
Rotrex crew -- fug A/C Quote:
#65 |
The Blue Bomber
ok, so Ive done some searching and I cant really find any answers to my questions.
I have a Revhard setup with a Turbonetics TO4E-60 turbo. my Kpro needs retuned but ive noticed that it will get up to 8lbs boost and the higher the rpms I get the more the boost will drop. (ie: 5k = 8 lbs, 7k = 5 lbs) could I have boost leakage somewhere? all my connections look tight. should I recheck all my charge piping as well? ive only checked the vacuum connections. I have a 9 lb spring with shims to = 10lbs but cant seem to get that much. its an open dump wastegate and I still have a converter (its a highflow converter with a thin wafer in it) also, I have a P2R plenum extender installed, could that be affecting my boost loss? any help is GREATLY appreciated, im still new to alot of stuff but im pretty mechanically inclined. I cant afford another snail or a full race kit so dont waste your time suggesting that, I need help with making my current setup work. |
#66 |
Senior Member
i read everything u wrote, and i starting to understand how a turbo works.
i know there is prob alot of other fourms that explains this but i cant find it. i basically thinking about getting a turbo i just want to feel a turbo. i was thinking of getting my rsx to reach 300-350. i want to do the least work as possible to the engine. and im on a low budget. any ideas?? lols |
#67 |
they call me Marsh
holy damn thats a lot of good info!! lol
#68 |
Member
Im pretty sure this question has been asked but how much Hp can a stock k20 handle safely ? i dont mean to ask a stupid question or anything but i was really confused i searched on google and i kept getting different numbers off of different forums . i would really if y'all could help me out .
Thanks . |
#70 | |
New Member
#71 |
Master Member
awesome tnx brotha...
So I read that higher torqued engines and turboed engines do not benefit so much from a lightweight flywheel. So it was suggested to stick with an oem type s flywheel. I have an ep3 that is gonna be turbo'd, will any year oem type s fly work for my ep? |
#72 | ||
Master Member
just to give you a number, lots of guys are putting over 500 whp on stock blocks. the transmission will give out much before the motor. Quote:
07 Nissan Frontier SE 4x4 07 GSXR-600 Race bike 02 YZ125 K-Pro Tuners - The #1 Site for Real Calibrations by Real People K20A2/K24A4 PARTOUT |
#73 | |
Master Member
havent bought the clutch yet but I knew to get an rsx-s specific cc stg 4 clutch...so are all 02-06 type-s fly's the same weight, if not whats a good weight fly to go with for a k24a2 turbod ep3??? |
#74 |
Master Member
i believe so. i think about 19 lbs? you could probably find the answer in a quick search
#75 |
Bańned
02-06 type-s flywheels are 16lbs
Wheel gap can be compared to a vagina. The more fingers you can stick in the worse off you are Don't PM me. I don't give a fuck about who you are and no, I don't have nudes |
