Removing Axel - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Problems & Solutions RSX
Notices
Reply
Thread Tools
Old 07-02-2008, 07:54 PM   #1
Phoenix80
Aaron
Phoenix80's Avatar
Phoenix80 is an unknown quantity on c-rsx
Question Removing Axel
OK, I'm stumped. I'm trying to pull my passenger side axel off and it just won't come off. The Helms manual says to "tap it" out. Well... I've tried that along with pulling it out and prying it out with the handle of a breaker bar and the damn thing won't budge.
I searched all over the site and I haven't seen anyone mention a removal process or any real issues with taking it out except one person who said it was pretty tough.
Any thoughts, ideas, or suggestions would be very much appreciated.
Thanks!
2006 Honda S2000
Track Tuned Satin Silver RSX-S - TRADED 10/16/2009
Phoenix80 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-02-2008, 08:12 PM   #2
TheUncleSame
Senior Member
TheUncleSame has been a little shit in the past
Thanks!
which end are u having the most difficult with? passenger side to mid shaft or mid shaft to tranny case?
make sure u put enough pressure on the axle to loosen up the C clip. Goodluck.Youcould remove the midshaft and remove the midshaft from the tranny case leaving u with a very long axle/midshaft combo...put that thing on a bench and try to wrestle with it.
The Unco
TheUncleSame is offline   Reply With Quote
Old 07-02-2008, 08:20 PM   #3
2010 admin
Guest
Posts: n/a
Go to Autozone and rent a slide hammer. One pop and the axle is out (using it on the pilot bushing in this case).
Old 07-02-2008, 08:27 PM   #4
Phoenix80
Aaron
Phoenix80's Avatar
I'm just trying to get the axel out from the mid-shaft. The whole reason I need it out is to replace the CV Boot, which tore and spewed grease all over the place.
2006 Honda S2000
Old 07-02-2008, 08:28 PM   #5
Phoenix80
Aaron
Phoenix80's Avatar
Interesting looking tool there - and I've heard of a slide hammer but I've never used one. How exactly does it work?
2006 Honda S2000
Old 07-02-2008, 08:29 PM   #6
the p-nut gallery
Installer / Machinist
the p-nut gallery's Avatar
the p-nut gallery is on a distinguished road the p-nut gallery is on a distinguished road
I'm uploading some pics for you now. I always take out the intermediate shaft as well as the pass axle at the same time.
  1. Remove the 36mm Axle Nut
  2. Remove the 17mm Castle nut and pin on the LCA lower ball joint.
  3. Use a Ball joint puller to seperate the ball joint from the LCA. (Be Careful)
  4. Remove the endlink on the sway bar on the side you are working on.
  5. Get under vehicle and remove the splatter shield over the intermediate shaft. (3) 10mm bolts.
  6. Remove the (3) 14mm bolts that hold the Intermediate shaft into the bolck.
  7. Make sure brake hub and knuckle are not putting pressure on the axle so it can move outward.
  8. Using a prybar or large screwdriver push the intermediate shaft and axle out of the housing in a straight line. (DO NOT PULL ON THE OUTBOARD CV JOINT YOU CAN DAMAGE THE UNIT!!!)
the outboard joint can be replaced while on the vehicle. Most passenger side axles are hard to remove from the intermediate shafts, and most intermediate shafts just slide extremely easy from the transmission housing.
the p-nut gallery is offline   Reply With Quote
Old 07-02-2008, 08:51 PM   #7
Phoenix80
Aaron
Phoenix80's Avatar
GOT IT!!! I used my breaker bar for leverage and smacked the bar with a hammer - popped right out like it was nothing.
now... how in the hell do I get the CV joint off the damn axel
2006 Honda S2000
Old 07-02-2008, 08:53 PM   #8
Phoenix80
Aaron
Phoenix80's Avatar
p-nut & all - thank you very much for the replies.
2006 Honda S2000
Old 07-02-2008, 09:25 PM   #9
the p-nut gallery
Are you just replacing the boot on the CV joint? If so just cut the band on the boot and remove it unless you have the "ear" type band then you can re-use it. You can get replacement bands from autozone or a like parts store. Make sure you replace lost grease in the joint and make sure the spider gears (orbital) are not damaged and are in the correct place before you seal it up incase you have pulled them from their original positions during removal.
Old 07-02-2008, 09:37 PM   #10
Phoenix80
Aaron
Phoenix80's Avatar
yeah, I have the whole axel out now. I'm just trying to figure out how to get the CV joint off so I can throw the new boot on there. Helms says to put the axel in a vise and use a slide hammer to pull the CV joint off of the axel. So I guess that's what I'm going to try tomorrow.
2006 Honda S2000
Old 07-06-2008, 12:22 AM   #11
togo
Member
togo is an unknown quantity on c-rsx
you don't have to pull the cv joint out if you r replacing both boots, just cut off the boots and take the inner joint apart then slip the outter boot in from the inner joint side
togo is offline   Reply With Quote
Old 07-06-2008, 09:57 AM   #12
VTEC_Inside
Mmm, 3rd lobe...
VTEC_Inside's Avatar
VTEC_Inside is an unknown quantity on c-rsx
Whats wrong with Axel?
Honda, The Heartbeat of Japan...
2006 Acura CSX Touring 160hp 141lb/ft
2004 Acura RSX Type S 6spd 200hp 142lb/ft
1989 Honda Accord Coupe LX 5spd 2bbl 98hp 109lb/ft
Slushies are something to drink, not drive...
Nikon Crew Member #23 | Gripped D700/D200, 2.8 from 17-200
VTEC_Inside is offline   Reply With Quote
Reply
Bookmarks
axel , removing
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
