Bolt-on K20 EK dyno: 2.5" vs 3" exhausts - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS RSX > All Motor RSX
Notices
Reply
Thread Tools
Old 07-11-2008, 03:28 PM   #1
D-Rob
Member
D-Rob's Avatar
D-Rob is an unknown quantity on c-rsx
Well, I got done tuning my car.
I put on a Thermal 3" exhaust yesterday, and it made quite an improvement over the previous SMSP 2.5" counterpart.
The solid line is from today (92 degrees in the dyno garage) and the dotted line is the old 2.5" exhaust (73 degrees in the garage).
Now only if I could add some intake length and move that pesky resonance hump further up. Seeing as my chasis is a little more restrictive to intake design with a K20 than RSX's, I may have to get creative one of these days.
Here is the full modlist:
K20A2
Stock from valve cover to oil pan
RBC manifold
11" intake with velocity stack/filter combo
Tri-Y long tube header
3" Thermal exhaust
Tuned with K-Pro on my shop's dyno
As always, comments and question alike are always welcome.
- Derek
'98 Honda Civic DX Coupe: K20-Powered, Full-Race Motivated: 637whp / 413wtq @ 23si on E85 / 11.0 @ 139mph
InnovativeMotorWorks
ClubRSX K-Pro Dyno Tuning Special! <-- It's BACK! Click!
D-Rob is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-11-2008, 03:35 PM   #2
k24_dc5
Senior Member
k24_dc5 is an unknown quantity on c-rsx
Looks like I need to go 3inch.
How much tuning was done when you went from the 2.5inch to 3inch exhaust?
k24_dc5 is offline   Reply With Quote
Old 07-11-2008, 03:36 PM   #3
rEDlinEDc5
I Don't Even
rEDlinEDc5's Avatar
rEDlinEDc5 is an unknown quantity on c-rsx
numbers/graph looks good considering the mods you have
17x9 +22/+33 hellaFUNKtional
"Straights are for fast cars, Turns are for fast drivers."
My ShowOff Documentaryhttp://forums.clubrsx.com/showthread.php?t=586236
Originally Posted by RSXwhiteBOY View Post
ive seen u leave people behind like a black guy racing against white people.
San Diego Ridiculously Good Looking Crew Member #2
rEDlinEDc5 is offline   Reply With Quote
Old 07-11-2008, 03:40 PM   #4
D-Rob
Member
D-Rob's Avatar
To be honest, it only needed another 5% fuel all over generally speaking. VTEC engagement moved down alot, too, so the high cam VTC map needed ALOT of adjustment.
- Derek
Old 07-11-2008, 04:14 PM   #5
Temptazn_Mark
www.MarkLinRacing.com
Temptazn_Mark's Avatar
Temptazn_Mark is an unknown quantity on c-rsx
wow, good gains
Temptazn_Mark is offline   Reply With Quote
Old 07-11-2008, 04:25 PM   #6
chunky
frank and beans!
chunky's Avatar
chunky is an unknown quantity on c-rsx
who made the header? What size flange on the header? What was the minimum inside diameter of the SMSP and Thermal? Just b/c an exhaust uses a 2.5" pipe, doesn't mean that there aren't parts inside the muffler/resonater that less than 2.5".
2002 ep3 - you may call her estella, current: IPS K2 Mark III coming soon, Click to see full mod list
All Motor crew: lucky #7
You can take me out of the race, but you can't take the race out of me.
chunky is offline   Reply With Quote
Old 07-11-2008, 04:32 PM   #7
D-Rob
Member
D-Rob's Avatar
It's actually the SSR knock-off being sold by Batlground Engineering on K20A.org. I purchased the header when I did the swap a couple months ago.
It is a 2.5" flange outlet.
The SMSP was a true 2.5" inner diameter with Magnaflow straight-through 2.5" ID resonator and muffler. In fact, I am still using the 2.5" resonator section right after the connection to the header, and have to flare up to 3" about 12" past the header flange.
So technically, I have a 2.5" to 3" exhaust.
- Derek
Old 07-11-2008, 05:28 PM   #8
luvmyrsx
Mostly stock, Mostly
luvmyrsx's Avatar
luvmyrsx is an unknown quantity on c-rsx
Nice gains. Lower air temps would have netted you even more. I dynoed a 3 inch in March and got gains of 7 whp and 15 wtq.
Didn't lose anything on the bottom end either did you? I wonder how many dynos it will take to prove to people that there are gains to be had with a three inch on a stock K20a2?
What kind of dyno is it?
luvmyrsx
'02 RSX-S
Firepepper Red Pearl
335 whp 219 wtq
Crsx Injen Cai, Kpro, IMG, custom stainless catback, JRRH, high flow cat, JRSC, 3.0 inch pulley, Jmercado's bracket, Jmercado's aftercooler, other stuff
luvmyrsx is offline   Reply With Quote
Old 07-11-2008, 05:34 PM   #9
D-Rob
Member
D-Rob's Avatar
luvmyrsx
Agreed, my IAT's were 110 degrees average, and I kept the ECT at 185-ish degrees for the runs.
And no, no losses down low at all. In fact, the car feels a good bit better cruising in the 3,000 RPM range now, and laying into the throttle slightly.
It is a brand-new (as of the end of May) DynaPack Evolution 3000 model.
- Derek
Old 07-11-2008, 06:41 PM   #10
chunky
frank and beans!
chunky's Avatar
- Derek
hah. Good ol Mike. He's no longer with batlground anymore though.
Interesting results. Was the muffler on the SMSP a straight through muffler?
Old 07-11-2008, 08:48 PM   #11
D-Rob
Member
D-Rob's Avatar
Yep.
- Derek
Old 07-12-2008, 01:39 AM   #12
acuragsrx
SURJE.motorsports
acuragsrx's Avatar
acuragsrx is an unknown quantity on c-rsx
Yep.
- Derek
Son of a bitch, I can't believe this, I build a head and hit 229 and you add an exhuast and hit 222....bitch :-P
06' RYP S2000 - Everyday
06' VBP RSX Type-S - retired
SURJE.motorsports / Innovative Motorworks / J-K-tuning.com / Sound Innovations
Build thread: http://forums.clubrsx.com/showthread.php?t=571852
acuragsrx is offline   Reply With Quote
Old 07-12-2008, 06:10 AM   #13
teacher
Mangekyou Sharingan!
teacher's Avatar
teacher is an unknown quantity on c-rsx
he does have a swap in a civic..they tend to make more power....
SSM 04 Type S
All Motor Crew #14
Go: Drag Cartel Stage 4
teacher is offline   Reply With Quote
Old 07-14-2008, 02:14 PM   #14
02Blktypes
Broke...
02Blktypes is an unknown quantity on c-rsx
i dont see wut your saying. its swapped but its still a k20a2 with an rbc, velocity stack a header and exhaust. you can have that on an rsx to. so how does it being in a civic make it have more power?
02Blktypes is offline   Reply With Quote
Old 07-14-2008, 02:17 PM   #15
D-Rob
Member
D-Rob's Avatar
I think he means when K20-swapped Civics go on your normal DynoJet, the output is a little higher, as most swapped Honda's lack things like power steering and A/C, and also have smaller diameter wheels/tires, which result in a torque multiplication, thus giving a higher number.
This test was performed on my DynaPack, though, so no wheels/tires were present.
- Derek
Old 07-15-2008, 10:19 AM   #16
02Blktypes
Broke...
- Derek
i see what your saying. thanks.
Old 07-30-2009, 02:05 AM   #17
cookies28
Senior Member
cookies28 is an unknown quantity on c-rsx
Derek, were both 2.5" and 3" exhausts straight-through? What about resonators? Thanks.
cookies28 is offline   Reply With Quote
Old 07-30-2009, 08:20 AM   #18
rsxtypes0818
DC5 Krew
rsxtypes0818's Avatar
rsxtypes0818 is an unknown quantity on c-rsx
wow that is a pretty big improvement
Dc5ing it in vero beach. representing the K20 Krew. 232Whp 169tq tuned by B.R.I.A.N
rsxtypes0818 is offline   Reply With Quote
Old 07-30-2009, 11:22 AM   #19
enJOY120
I WILL DESTROY YOU!
enJOY120's Avatar
enJOY120 is an unknown quantity on c-rsx
- Derek
Yep.
- Derek
enJOY120 is offline   Reply With Quote
Old 07-30-2009, 11:24 AM   #20
hadi
Q8 fastest SC CTR
hadi's Avatar
hadi is an unknown quantity on c-rsx
nice gains man, i always love your work
but i have question, while back ago, i switched to full 3" inch exhaust with bottle neck on the header flange. and i was surprised my power and torques was dropped so bad. around 10whp and 15wtq after full re-tune. i wonder what is the coz of that ?
2003 JRSC CTR, 363whp 267wtq @ 9psi w/50 shot (11.4 @ 119.1mph w/1.72 60ft). sold
2008 Grand Cherokee SRT-8, HHP stg 1 camshaft, aFe stg 2 intake, Diablo sport tune, Eibach rear springs, Perelli P Zero 275/315.
hadi is offline   Reply With Quote
Old 07-30-2009, 11:29 AM   #21
HardcoreRsxS
EFI Tuning Professional
HardcoreRsxS's Avatar
HardcoreRsxS is on a distinguished road HardcoreRsxS is on a distinguished road HardcoreRsxS is on a distinguished road
Hadi,
You need a gradual increase from the header to the exhaust
HardcoreRsxS is offline   Reply With Quote
Old 07-30-2009, 11:32 AM   #22
hadi
Q8 fastest SC CTR
hadi's Avatar
thanx for the quick answer, i do this with my new K24 built.
Old 07-30-2009, 07:36 PM   #23
hasonline
New Member
hasonline is an unknown quantity on c-rsx
Originally Posted by HardcoreRsxS View Post
Hadi,
could you explain this to me Mike? i couldn`t understand properly.. do you mean that there shouldn`t be a bottleneck or it should be a setup like Darek`s 2.5" to 3" (having 2.5" resonator than the piping becomes 3"?)
thanks
hasonline is offline   Reply With Quote
Old 07-30-2009, 07:51 PM   #24
stlrollin6
everyone shut it
stlrollin6's Avatar
stlrollin6 is an unknown quantity on c-rsx
you got three cars??
stlrollin6 is offline   Reply With Quote
Old 07-30-2009, 10:04 PM   #25
D-Rob
Member
D-Rob's Avatar
LOL. No.
This thread is super-old from when my personal car was naturally aspirated.
- Derek
Reply
Bookmarks
25 vs 3 , bolton , dyno , exhausts , k20
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
