Help Codes P0507 And P2279...... - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Problems & Solutions RSX
Notices
Reply
Thread Tools
Old 08-07-2008, 01:58 PM   #1
npag16
INSANE MARINE
npag16 is an unknown quantity on c-rsx
Okay Gents. I Have Already Cleaned The Iacv And Put It Back Together And Were Getting The Same Thing That Started. The P0507 And P2279 Are Still Being Thrown Up. I Know It Says It's An Intake Manifold Leak, But Where Do I Start With That. I'm Going Down To Georgia And Need It Fixed. Any Help Asap. Thanks!!!!!
npag16 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-07-2008, 02:31 PM   #2
rensoyka
Breast inspector by appt.
rensoyka's Avatar
rensoyka is an unknown quantity on c-rsx
potential sources of intake leaks:
1. PCV valve or hose (on the passenger side of the intake manifold)
2. EVAP purge valve or hose (on top of the throttle body)
3. Throttle body gasket
4. Intake manifold gasket or cracked or loose intake manifold
5. Intake air bypass control thermal valve or hose (by the valve cover)
6. Brake booster hose (connects to the intake manifold)
7. Idle air control valve gasket (on the bottom of the throttle body)
'06 black type-s.
rensoyka is offline   Reply With Quote
Old 08-07-2008, 03:17 PM   #3
npag16
INSANE MARINE
What Would Be The Best Way To Find These Leaks Cause You Cant Hear Them, So What Other Ways. Thanks For The Reply
Old 08-07-2008, 03:40 PM   #4
Kevin949
Big Pimpin
Kevin949's Avatar
Kevin949 gets around and is known
Kevin949 gets around and is known Kevin949 gets around and is known Kevin949 gets around and is known Kevin949 gets around and is known Kevin949 gets around and is known Kevin949 gets around and is known Kevin949 gets around and is known Kevin949 gets around and is known Kevin949 gets around and is known Kevin949 gets around and is known Kevin949 gets around and is known Kevin949 gets around and is known Kevin949 gets around and is known Kevin949 gets around and is known
carb cleaner. spray anywhere you think there is a leak or whatever, if the idle drops then there's a leak.
Kevin949 is offline   Reply With Quote
Old 08-07-2008, 05:11 PM   #5
rensoyka
rensoyka's Avatar
if you haven't had work done on any of those parts, then it's likely a loose or split hose. if any work has been done in those areas, check for incorrect installation, especially when it involves any kind of gasket.
'06 black type-s.
Old 08-07-2008, 08:23 PM   #6
npag16
INSANE MARINE
okay gents. we got it working and shes running smoothly now. i guess i just needed to give it a little time on the cleaning of the IAC. thanks everyone.
Reply
Bookmarks
codes , p0507 , p2279
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
