new brakes - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Problems & Solutions RSX
Notices
Reply
Thread Tools
Old 08-23-2008, 01:40 PM   #1
paint3all88
Senior Member
paint3all88's Avatar
paint3all88 is an unknown quantity on c-rsx
new brakes
ok so i installed some Hawk Ceramic brake pads that i ordered from the parts store and everything was good for the first week or so
butttt now only when i brake and turn to the right at the same time it makes a really bad sqeeling sound
i am about to go back and take everything back apart but i was just wondering what i could possibly look for that would be the problem
any help would be greatly appreciated, thanks!
NHBP TYPE-S
paint3all88 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-23-2008, 01:41 PM   #2
CBRDC5
Hi there
CBRDC5 is an unknown quantity on c-rsx
Caliper bracket shim not completely on, backing plate hitting rust on rotor just a few places to start.
'02 DSM RSX-S
If i helped then +rep. If i didnt then -rep the person above me
CBRDC5 is offline   Reply With Quote
Old 08-23-2008, 01:45 PM   #3
paint3all88
Senior Member
thanks a lot man! ill check those out
NHBP TYPE-S
Old 08-23-2008, 03:34 PM   #4
mwolbaum
Member
mwolbaum is an unknown quantity on c-rsx
Make sure you are generous with the brake grease
mwolbaum is offline   Reply With Quote
Old 08-25-2008, 08:24 AM   #5
lordkain
GO Habs GO!
lordkain's Avatar
lordkain is an unknown quantity on c-rsx
Yah i find if you dont put enough the squeeking will still continue... i found that out this past weekend... lol
I would rather live my life as if there is a God and die to find out there isn't, than live my life as if there isn't and die to find out there is.
Albert Camus
lordkain is offline   Reply With Quote
Old 08-25-2008, 01:00 PM   #6
paint3all88
Senior Member
ok so i checked the caliper shim and brake grease is generously on there but the sqeal is now just when i stop in general on light braking.
im thinking its jusrt like a new brake sqeal, is that possible?
NHBP TYPE-S
Old 08-25-2008, 01:33 PM   #7
deanob
fucks.given =< 0;
deanob's Avatar
deanob is an unknown quantity on c-rsx
Did you use proper lube at the pad guides as well as the sliders? Also anti-squeal usually solves most if not all squeaking unless of course the pads are down to 10% pad.
08 Evo X MR
15 STi
04 EP3 SIR [SOLD]
00 S2000
deanob is offline   Reply With Quote
Old 08-25-2008, 01:37 PM   #8
paint3all88
Senior Member
noooo i had no clue there was a proper lube for pad guides or the sliders!
what kind of lube or is it just anti sqeal
NHBP TYPE-S
Old 08-26-2008, 06:41 PM   #9
Your_Daddy
02 Acura RSX BASE
Your_Daddy's Avatar
Your_Daddy is an unknown quantity on c-rsx
"Paste lube" (black color) is for all metal surfaces.(sliders,pins,etc.) "Sil-Glyde" (clear) for all rubber surfaces.(boots,bushings,etc.) DO NOT USE PASTE LUBE ON RUBBER PARTS!!!! It eats rubber over time. DO NOT GET PASTE LUBE ON THE PAD OR ROTOR!!! it will squeal like crazy.Paste lube is good up to like 10k degrees.So dont think it will just burn off.....IT WONT.
Your_Daddy is offline   Reply With Quote
Old 08-26-2008, 07:03 PM   #10
drumnatural
I can drive up your rsx
drumnatural's Avatar
drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though
Honda recommends Dow Corning Molykote M77 or Daikalub
528D grease for the pad shim, back of the pads, and the pad retainers. These are considered a "moly" which is molybdenum disulfide. U can find the same stuff at pep boys, etc.
P/N 08C30-B0234M is recommend for the caliper pins/boots and piston seal/boots. P/N 08C30-B0234M is nothing more then 100% silicone grease which can be bought at any pep boys, autozone, etc.
The grease names I pulled right from the Helms manual. You should use it to ensure you are properly greasing all the locations.
Also Hawk Ceramic pads have shims glued onto the pad. U don't reuse your OEM shims.
You treat your car like your girlfriend...Tender loving care along with giving her some WOT
[SIGPIC][/SIGPIC]
drumnatural is offline   Reply With Quote
Old 09-01-2008, 11:37 AM   #11
paint3all88
Senior Member
thanks guys
i am not able to work on my car at this point because i am busy and all with school and work but do you think it is bad to drive like this? it only squeals when the brakes are really hot.
i know i really need to pick up a helms manual by the way lol, i had one for my integra and it saved me planty of times!
NHBP TYPE-S
Old 09-08-2008, 08:05 PM   #12
ron64
New Member
ron64 is an unknown quantity on c-rsx
Ok...I have a question about my breaks also. The breaks were replaced in march with no problems. Now I also have no cruise control, so about 3 weeks ago I looked under the dash to see if maybe the pedal was canceling the cruise and looked at the switches above the pedals...I did pull up on break pedal. So I go to leave the house and the breaks are stuck, and will release when I pull up on the pedal with my foot...but the breaks slowly apply themselves while I am driving and I have to continually pull up on the pedal while driving when I notice the breaks are applying. I have break dust all over the front wheels!! Any idea on what I may have done or how to fix this??? 2004 RSX.
Ron
ron64 is offline   Reply With Quote
Old 09-09-2008, 11:53 AM   #13
paint3all88
Senior Member
have you bled the brake lines to check for air in them?
NHBP TYPE-S
Old 09-09-2008, 12:06 PM   #14
Cmqqn85
Senior Member
Cmqqn85's Avatar
Cmqqn85 is an unknown quantity on c-rsx
Check the squealer on the rear pads. Does it have one or two (squeal tabs)? Is it on top or on the bottom? I put on my red stuff awhile back on had the squealer facing the bottom and it did what yours did now. I switched the pads around and problem solved. Just a suggestion
01 S2000 - Silverstone
90 Accord JDM H22- "Project DD"
91 Civic Hatch ~ K24/K20 ~ Track Whore (winter project)
Cmqqn85 is offline   Reply With Quote
Old 09-09-2008, 04:30 PM   #15
Taeorrist
Whoop-d-doo
Taeorrist's Avatar
Taeorrist is an unknown quantity on c-rsx
did u do anything to ur rotor? usually its good to resurface the rotors when replacing the pad... and hawk pad, aint that performance brake pad? i dunno what brand it was but one of my customer brought in a honda, with performace pads on'em. everything was o~K but the brake dust wouldnt get burnt off and it caused the brake to squeel. and if u installed the pads properly, then YES its ok to drive like that. mine's been squeeling and squeaking, but o wellz fuck it as long as there's no uneven wear on the pads i dont mind the noise.
Taeorrist is offline   Reply With Quote
Reply
Bookmarks
brakes
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
