#1 |
New Member
What type of manual transmission fluid?
I losted my manual guide for my Rsx type S, and my clutch is getting stiffer and grinds due to high mileage. What type of manual transmission fluid does a Rsx type S takes? What kind should I use?
| Sponsored Links | |||
Advertisement | |||
#4 |
Master Member
the manual will most likely tell you honda mtf
but i've been using it and its starting to blow my balls with the 3rd gear pause/stop, might consider getting amsoil syncromesh fluid |
#5 |
ya'll got hot wing?
amsoil has lasted me a long time, longer than oem fluid and much longer than Redline. you could also try the new ACURA MTF.
Forgotten more than you ever learned. Armenian crsx crew member #? Function Over Form. GMThe heartburn of America |
#7 |
Team Drastic
Use about half a bottle of Lucas Oil automatic transmission aid, and the rest with Honda/Acura MTF for the 6speed. It will shift nice and smooth, if you wish you can opt to use syncromesh with my technique it worked that way as well with my old LS.
#8 | |
I can drive up your rsx
As posted before either the new Honda MTF(green label?), Amsoil, or Pennzoil/GM synchromesh. I myself love Amsoil. Solved my 3rd gear "pause" and I have never once grinded 2nd.
You treat your car like your girlfriend...Tender loving care along with giving her some WOT [SIGPIC][/SIGPIC] |
#9 | |
Team Drastic
But even though this is not technically correct, it is working great in my K, and my old LS is still shifting great nearly 3 years later. So I don't for see any problems down the road. |
#11 |
Kevin★05 DC5-S
i use amsoil syncromesh fluid and
13 Subaru BRZ 1/17/13 97 Mazda Miata M Edition - SOLD 7/23/1205 NBP RSX-S - SOLD 10/9/10 Visit my blog for DC5 |
#13 |
Master Member
If you can get GM friction modeified synchromesh that would be your best bet. I use amsoil now and its pretty good but I'm sure the friction modified synchromesh will be fine
Short On Mod Cash Crew Member #37
| Bookmarks |
| Tags |
| fluid, manual, transmission, type |
| Thread Tools | |
