#301 |
CLUB RSX.com Supporter
^^2 years damn that's a pretty good track record. How much for the cryo treatment?
Full-Race stage 3.7* 10second/no weight reduction street RSX!!!***Evans Tuned*** 689whp484lbft
#302 |
Make sure you have the launch limiter set for at least 7000rpm and you'll pull amazing 60fts.
#303 | |
0 to 1320...
WWW.TEAMXXXRACING.COM
race team | online parts store '02 RSX-S Turbo :: 11.466 @ 122.91 AIM - teamXXXracing |
#304 |
Boost Slut Krew Member #1
Yeah it's set at exactly 7,000 right now..
11.79 @ 120MPH - Bandimere Speedway, CO SuperFlow Dyno Tuned - 91 - 440whp 330wtq @ 18lbs - Thanks Brian! ![]() DynaPack Dyno Tuned - 91 - 525whp 340wtq ![]() My In-Depth Build Threads:http://forums.clubrsx.com/showthread.php?t=674689 |
#305 |
11.81 @ 123
interesting . What tranny did you have treated and what kind of power you putting down? you have twindisc?
MANual Power Steering Krew #1
#306 | |
GM Engineer Wannabe
"If it ain't broke, you're not trying hard enough." |
#307 | ||
0 to 1320...
The cyro process doesn't put a coating on the gears... doesn't look any different after. basically you take the completely assembled main and countershaft out of the casing (i also did forks and FD (not the diff)) and send them to get treated or you can just do certain gears and syncronizers. "The Cryo treatment process uses sub-zero temperatures down to –300ºF to modify the micro-structure of the material. Cryogenic treatment promotes additional transformations in metals. It ultimately improves the performance of the metal."
#308 | ||
fapfapfapfapfapfapfapfap
I'm interested in hearing more about this cryo treatment. Do you know of any others running cryo treated gears with higher hp?
AUTOCROSS KREW (5 seasons) ∙ SNOWBOARDING KREW (2 seasons) ∙ DETROIT FAN CLUB (Foreva!!) Quote:
![]() only from an 09er
#309 | |
GM Engineer Wannabe
![]() 150 bucks is nothing AND i'll already have my gears out.
#310 | |
yeah for 150 bucks you might as well give it a shot. Where in MI?
#311 | |
GM Engineer Wannabe
Too bad I won't be getting an LSD until next work term (wheels and tires this term)
#312 |
10.801@137.72
And tons and tons of seat time. This guy can drive!
#313 | ||
Well he did say 100+ passes so I believe that
#314 |
GM Engineer Wannabe
http://www.300below.com/
"We have been in business since 1966, constantly evolving from our roots in Detroit, Michigan." I just went to the "contact us" section and it said they are now in IL. Maybe that's just headquarters or something?
#315 |
0 to 1320...
I go through a local company to me in Worcester, MA... http://www.nitrofreeze.com/cryogenic_treatment.html
#316 |
Jeremy how much boost do you run in 1st? I was still unable to pull 1.6 60's last Wednesday even with the 3rd gear burnouts... which were badass lol. I was consistantly pullin 1.79 , 1.80 , 1.81... I tried messing with tire pressure but where I originally had it at 9psi seemed to work best. I run 14lbs of boost in 1st and 17lbs in 2nd and higher. Wondering if I should raise or lower my boost to help with the first 60'? It has a rough time holding traction @ only 14lbs in first it feels like. Curious if I should try less or more boost in first..
#317 | |
0 to 1320...
#318 |
Buddy Club N+
#319 |
11.79 @ 120MPH / Bandimere Speedway 5,800ft Elevation, CO / Stock Block / PPG Gears Built Trans / PeakBoost GT3582R Turbo Setup / 440whp & 330wtq / 2,850lbs Full Weight
Here is video from the other night. If you listen on the 11.79 pass you can tell up until it gets past torque peak 1st gear struggles to hook so I think I need to play with my boost setting in 1st if I wanna see lower 60's? Let me know what you guys think. Video: http://videos.streetfire.net/video/T...009_710421.htm Timeslips, I'm car 759. ![]() ![]() ![]()
#320 |
0 to 1320...
are you adjusting your suspension when you go to the track? suspension setup is very critical to gaining traction. lower your front coils, raise up your rear coils and make the rears fully stiff.
#321 |
I haven't adjusted it specifically for the track no. But I have the rears set to essentially 1 click below stiff and the fronts about halfway stiff.
#322 | |
#323 | |
#324 |
Hmm. 12psi hot like after you've done a pass or two on them or 12psi before you mounted them? Mine were at 9 cold and around 11 when I checked after one of the passes.
#325 | |
Lol, that was a blast.
| Bookmarks |
| Tags |
| 1 or 4, mile, times, turbo |
| Thread Tools | |
