Go Back   Club RSX Message Board > PERFORMANCE BASICS > Turbo
Reply
Thread Tools
Old 10-03-2009, 10:39 AM   #326
bkk6284
GM Engineer Wannabe
bkk6284's Avatar
bkk6284 has disabled reputation
What's the advantage to doing a burnout in 3rd as apposed to 1st? Badass factor? lol
"If it ain't broke, you're not trying hard enough."
bkk6284 is online now   Reply With Quote
Old 10-03-2009, 10:53 AM   #327
K20 on b00st s0n
Stock
K20 on b00st s0n has disabled reputation
you can spin the tires faster
K20 on b00st s0n is offline   Reply With Quote
Old 10-03-2009, 11:03 AM   #328
blueshark123
10.801@137.72
blueshark123's Avatar
Higher mph = more heat = more traction
blueshark123 is offline   Reply With Quote
Old 10-03-2009, 11:12 AM   #329
bkk6284
GM Engineer Wannabe
bkk6284's Avatar
Makes sense
Old 10-03-2009, 12:36 PM   #330
bkk6284
GM Engineer Wannabe
bkk6284's Avatar
Originally Posted by WooTIHaveATypeS View Post
11.79 @ 120MPH / Bandimere Speedway 5,800ft Elevation, CO / Stock Block / PPG Gears Built Trans / PeakBoost GT3582R Turbo Setup / 440whp & 330wtq / 2,850lbs Full Weight
Here is video from the other night. If you listen on the 11.79 pass you can tell up until it gets past torque peak 1st gear struggles to hook so I think I need to play with my boost setting in 1st if I wanna see lower 60's? Let me know what you guys think.
Video: http://videos.streetfire.net/video/T...009_710421.htm
Timeslips, I'm car 759.
http://i971.photobucket.com/albums/a.../Timeslip1.jpg
http://i971.photobucket.com/albums/a.../Timeslip2.jpg
http://i971.photobucket.com/albums/a.../Timeslip3.jpg
http://i971.photobucket.com/albums/a.../Timeslip4.jpg
One day I will have enough money for slicks, LSD, and track time.
Very nice runs.
I like that song btw.
Old 10-03-2009, 05:28 PM   #331
RSXING AZ
CLUB RSX.com Supporter
RSXING AZ's Avatar
RSXING AZ is cool, not as cool as some thoughRSXING AZ is cool, not as cool as some thoughRSXING AZ is cool, not as cool as some thoughRSXING AZ is cool, not as cool as some thoughRSXING AZ is cool, not as cool as some thoughRSXING AZ is cool, not as cool as some thoughRSXING AZ is cool, not as cool as some thoughRSXING AZ is cool, not as cool as some thoughRSXING AZ is cool, not as cool as some thoughRSXING AZ is cool, not as cool as some thoughRSXING AZ is cool, not as cool as some though
Hmm. 12psi hot like after you've done a pass or two on them or 12psi before you mounted them? Mine were at 9 cold and around 11 when I checked after one of the passes.
12psi cold which was like 15psi after the run.
Full-Race stage 3.7* 10second/no weight reduction street RSX!!!***Evans Tuned*** 689whp484lbft
RSXING AZ is offline   Reply With Quote
Old 10-03-2009, 05:37 PM   #332
WooTIHaveATypeS
Boost Slut Krew Member #1
WooTIHaveATypeS's Avatar
WooTIHaveATypeS is a rep WHORE
WooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHOREWooTIHaveATypeS is a rep WHORE
Hmm, may have to try that then.
11.79 @ 120MPH - Bandimere Speedway, CO
SuperFlow Dyno Tuned - 91 - 440whp 330wtq @ 18lbs - Thanks Brian!
DynaPack Dyno Tuned - 91 - 525whp 340wtq
My In-Depth Build Threads:http://forums.clubrsx.com/showthread.php?t=674689
WooTIHaveATypeS is offline   Reply With Quote
Old 10-03-2009, 06:02 PM   #333
RSXING AZ
RSXING AZ's Avatar
Yeah just give it a shot and see if you like it. You might gain a little mph out of it too!
Old 10-03-2009, 07:18 PM   #334
WooTIHaveATypeS
With 12psi in them, do your slicks wrinkle at all under the weight of the car?
Old 10-03-2009, 09:40 PM   #335
RSXING AZ
RSXING AZ's Avatar
Yeah but no where near the wrinkle of 7psi lol. I remember when I ran the car that night at 7psi, boy did she shake when I hit the brakes.
Old 10-04-2009, 09:58 PM   #336
SideWinder
fapfapfapfapfapfapfapfap
SideWinder's Avatar
wicked! Those burnouts look sick! You should have someone take some good quality photos of you doing that. Nice new time btw, to think you almost sold it, lol
Has anyone ever tried doing burnouts in 4th gear then just for the hell of it or is there really no point?
AUTOCROSS KREW (5 seasons) ∙ SNOWBOARDING KREW (2 seasons) ∙ DETROIT FAN CLUB (Foreva!!)
Originally Posted by K20egcw View Post
Like somebody said above, he was at the all motor shootout and got 2nd place. So hes got alot more "cool" points then 99% of people here. Plus he probably makes more money street racing in 1 night then you guys make at work in 1 week
only from an 09er
SideWinder is offline   Reply With Quote
Old 10-05-2009, 04:00 AM   #337
WooTIHaveATypeS
Thanks man.
4th gear on the stock 6 only goes to like 120 so you could porbably do it on that trans. Doing the burnout in 3rd on the PPG trans at like 122mph you can feel it kinda lag for a sec before they break loose, I think 4th would be a little overkill if its even doable.
Old 10-05-2009, 04:47 AM   #338
MELLO
11.81 @ 123
MELLO's Avatar
MELLO Golden Rep WhoreMELLO Golden Rep Whore
MELLO Golden Rep WhoreMELLO Golden Rep WhoreMELLO Golden Rep WhoreMELLO Golden Rep WhoreMELLO Golden Rep WhoreMELLO Golden Rep WhoreMELLO Golden Rep WhoreMELLO Golden Rep WhoreMELLO Golden Rep WhoreMELLO Golden Rep WhoreMELLO Golden Rep WhoreMELLO Golden Rep WhoreMELLO Golden Rep WhoreMELLO Golden Rep Whore
Talked to the guy at M & H and with their slicks they are supposed to be ran at 10psi - 8 psi .. So I always ran mine at 10 and was fine. They wrinkle a bit but thats normal.
MANual Power Steering Krew #1
MELLO is offline   Reply With Quote
Old 10-05-2009, 06:02 PM   #339
WooTIHaveATypeS
I will run them at whatever psi helps me to get 1.6 60's lol. I've tried anywhere from 7 to 9psi ill try maybe 11 to start next time.
Old 10-05-2009, 06:12 PM   #340
Drewk20z1
Drewls6/K24A8
Drewk20z1's Avatar
why dont you run at your higher boost setting?
crews are gay
Drewk20z1 is offline   Reply With Quote
Old 10-05-2009, 11:49 PM   #341
WooTIHaveATypeS
What do you mean? I run 14 lbs in 1st and then 17lbs in 2nd and up. It already has some struggle holding traction in 1st just at 14lbs.
Old 10-06-2009, 10:04 AM   #342
Drewk20z1
Drewls6/K24A8
Drewk20z1's Avatar
i guess why werent you running at 525 whp
crews are gay
Old 10-06-2009, 03:49 PM   #343
WooTIHaveATypeS
Oh, that's not a difference in boost. Just two different dynos. June 2008 I got tuned on a dynapack and made 525. In may of this year I retuned on a Superflow roller dyno and it made 440whp. I think next year I'm retuning on a dyno dynamics or dynojet.
Old 10-08-2009, 11:19 AM   #344
WooTIHaveATypeS
Blue you should edit post #1 for my 11.79.
I tried to go to the track last night but the track prep was a fucking joke so I got pissed off and left lol.
Old 10-21-2009, 07:57 PM   #345
SideWinder
SideWinder's Avatar
Question
I was looking through everyone's setups in the 10's and low 11's and while everyone is running similar setups in terms of horsepower, weight, transmission, and slick sizes, I couldn't help but notice this:
10.84@128 - JO TECH/ Puerto Rico/ CP 9:0:1 Crower rods/Custom turbo kit pt-67/ 525whp@24psi/ 26x10 / rsx type s tranny w/lsd
the member in puerto rico was running a lot less horsepower, nearly 100whp less in fact than most (granted that can vary depending on which dyno he was tuned on). But more noteably he was still on the stock 6-speed and bigger slicks (instead of the 24.5x8.5x15 that everyone else is running). So I guess I'm wondering are all of these features a lot better for accelerating the rsx? Or are their other major factors involved (like driver mod or is it gutted? I don't see a weight listed).
Just wondering...
only from an 09er
Old 10-21-2009, 08:39 PM   #346
JayRSXS
Master Member
JayRSXS's Avatar
11.86 @ 116 / JayRSXS / Tx (Shitty Track) / K20Z1 86 MM Stock / Peakboost GT3076.82 / No Dyno But Pushing 13 Psi / Full Weight (Including Spare, Jack, Floor Jack, Tool Box, and Sub) / M&H Slicks 24.5x8.5x15 / Stock 05 Type-S Trans
Im VERYYYYYY curious as to what my car is putting down.
Boost Slut Krew Member #20
11.86 @ 116.97 1.77 60ft.... First Run Ever!
HaLFAmAzinG120 (2:31:52 PM): fuck me like you hate me!
HaLFAmAzinG120 (2:31:56 PM): oh wrong IM sorry
LoSt1nY3RpAnTIEz (2:32:23 PM): O.O
JayRSXS is offline   Reply With Quote
Old 10-21-2009, 11:30 PM   #347
RSXING AZ
RSXING AZ's Avatar
Just wondering...
I remember when details started to surface regarding the specs of this car. People were saying it had no a/c, no p/s completely gutted and what not. Some people claimed stock weight. I don't know the guy or if any of this is true, but it would make perfect sense. I was thinking about this a long time ago and if it was even possible for 525whp to move a heavy RSX into the 10's on just over 500whp. I can tell you my car which has nothing removed for weight does not fell like a 10 second car at all when I have the boost around 18psi which is right around 500whp. For comparison sake, have you ever heard of any FWD Honda that weighs 2900lbs run 10.8 with 525whp? I haven't........
Old 10-22-2009, 01:12 PM   #348
SideWinder
SideWinder's Avatar
Sure it would make a lot of sense if the whole thing was stripped and gutted. It would make the most sense anyways. However I'm just curious if the other factors I mentioned helped overall since they were different from the norm (particularly the bigger wider slicks).
It's probably been discussed before but I wanted to learn
only from an 09er
Old 10-25-2009, 12:36 AM   #349
blueshark123
10.801@137.72
Could also be driver. Shit I ran my 10.8 on my 6th pass ever on race gas. I am by no means a great driver. Im sure with a better driver my car could have been propelled into the low 10s especially with 26 inch slicks.
Old 11-02-2009, 08:49 AM   #350
JSeoul
Master Member
New times with the GReddy kit yesterday. Thought I would share since I was very excited in doing this at a not-so-great track.
60': 1.799
1/8 et: 8.117
1/8 mph: 86.16
1/4 et: 12.594
1/4 mph: 112.28
12.594@112.28 - JSeoul / PA / stock k20z1 / GReddy kit / 310whp 242wtq / 24.5x8.5x15 MH Slicks/ Quaife LSD
JSeoul is offline   Reply With Quote
Reply
Bookmarks
1 or 4, mile, times, turbo
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
