change thermostat - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL > Problems & Solutions
Notices
Reply
Thread Tools
Old 01-15-2009, 06:36 PM   #1
nhl420
STL Member
nhl420's Avatar
nhl420 is an unknown quantity on c-rsx
change thermostat
how hard is it to change my thermostat. My car was overheating on my way to school and no heat. I looked at my coolant and its fine. The only other thing i can think of being wrong is a bad thermostat.
nhl420 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-15-2009, 09:09 PM   #2
VTEC_Inside
Mmm, 3rd lobe...
VTEC_Inside's Avatar
VTEC_Inside is an unknown quantity on c-rsx
Overheating and no heat? AND coolant is fine?
Where are you checking your coolant level?
If it was overheating because of a stuck thermostat then you would still have heat assuming there is coolant in there.
Something doesn't add up here.
Honda, The Heartbeat of Japan...
2006 Acura CSX Touring 160hp 141lb/ft
2004 Acura RSX Type S 6spd 200hp 142lb/ft
1989 Honda Accord Coupe LX 5spd 2bbl 98hp 109lb/ft
Slushies are something to drink, not drive...
Nikon Crew Member #23 | Gripped D700/D200, 2.8 from 17-200
VTEC_Inside is offline   Reply With Quote
Old 01-15-2009, 09:18 PM   #3
04DC5TypeS
J to the ames
04DC5TypeS's Avatar
04DC5TypeS is an unknown quantity on c-rsx
I would check to make sure you dont have a crack anywhere in your radiator just to be sure
04 NBP Type S SOLD
07 BMW SGM 328xi
04DC5TypeS is offline   Reply With Quote
Old 01-15-2009, 09:33 PM   #4
nhl420
STL Member
nhl420's Avatar
i will check my radiator but i cant until i can get my car to my school. And i do have coolant. The level of coolant was between min and max when the engine was hott. But my coolant gauge slowly climbs from c to above h if you let it cool down for an hour. But there was no heat it sucked. I just thought my gauge was broken until two mile later i started to see smoke coming from my radiator.
Old 01-15-2009, 10:19 PM   #5
VTEC_Inside
Mmm, 3rd lobe...
So you just looked at the overflow container?
Open the rad cap, almost guaranteed you are low on coolant.
Old 01-16-2009, 04:52 PM   #6
sTiCkY
Master Member
sTiCkY's Avatar
sTiCkY is an unknown quantity on c-rsx
So you havent noticed any fluid on the floor of where you park?
I love
sTiCkY is offline   Reply With Quote
Old 01-17-2009, 03:16 AM   #7
nhl420
STL Member
nhl420's Avatar
hey i fixed the problem and no there wasnt any coolant on the floor or under my car. It turns out it was the thermostat just like i thought. It was getting stuck open and stuck closed. So i replaced it and that is a pain in the ass by the way. that top bolt is so damn hard with the intake manifold in the way but its all good now
Old 01-18-2009, 03:22 PM   #8
YouTalk
Type-S
YouTalk's Avatar
YouTalk is an unknown quantity on c-rsx
Does anyone think its better to just leave the thermostat out??
Just Living The Dream......
YouTalk is offline   Reply With Quote
Old 01-18-2009, 05:17 PM   #9
Toyonda
Member
Toyonda is an unknown quantity on c-rsx
No, do not leave the thermostat out. Your car will run optimally at operating temperature such as 185*-200*. If you leave the thermostat out, your car will take much longer to get to that temperature which can cause unnecessary wear on your engine and perform worse until it gets warm.
Toyonda is offline   Reply With Quote
Old 01-19-2009, 09:37 AM   #10
sxy2003
Bundy :cry:
sxy2003's Avatar
sxy2003 is on a distinguished road sxy2003 is on a distinguished road
I don't think there's any wear implications if you leave it out. It will, however, be annoying as hell, because you will have no heat for a really long time. I would say aroun 20-25 minutes before it kicks in.
sxy2003 is offline   Reply With Quote
Old 01-19-2009, 11:25 AM   #11
bluej511
Name's Vic
bluej511's Avatar
bluej511 is a hardcore rep whore
bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore
You must be an idiot if you don't think shit is going to wear worse without a thermostat. Stupidest comment ive seen in a long time. Your thermostat closes and opens, keeps coolant from going in and out of the block.cylinder head WHEN IT NEEDS to. If you leave it out, its just going to flow coolant all the time, might keep the car too hot might keep the car too cold. Its there for a reason bottom line.
Armenian crsx crew member #6
02' RSX-S 179k mi, 14.5 @97. Sold after 12years.
13' Trek Madone 5.2. 2012 Swift Sport
bluej511 is offline   Reply With Quote
Old 01-19-2009, 02:20 PM   #12
VTEC_Inside
Mmm, 3rd lobe...
Without a thermostat the engine will run too cold period. The only exception would be in scenarios where it would be too hot even with a thermostat, ie hard core beating the shit out it racing in mid-summer.
Old 01-19-2009, 03:02 PM   #13
bluej511
Name's Vic
bluej511's Avatar
Yea exactly, and anyone who things running and engine cold is good then wow need to get your facts straight. If the engine runs too hot theres damage right there, if the engine runs too cold then bam yes theres damage there too. You're motor won't burn off deposits running too cold. You'll put extra heat and stress on the aluminum and other parts and bam theres more trouble. Its there for a reason, even people who race leave there thermostats in put run engine ice or some shit like that.
Old 01-19-2009, 03:15 PM   #14
dc5_st
Word
dc5_st is an unknown quantity on c-rsx
lol harsh.
dc5_st is offline   Reply With Quote
Old 01-19-2009, 03:21 PM   #15
bluej511
Name's Vic
bluej511's Avatar
hey in these times you gotta be harsh. A lot of people make false comments and don't even think before they write things. Fair is fair, sometimes you gotta be mean to be nice.
Reply
Bookmarks
change , thermostat
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
