Car makes grinding noise on start up - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Problems & Solutions RSX
Notices
Reply
Thread Tools
Old 02-07-2009, 03:00 PM   #1
EuroRSX
Master Member
EuroRSX has been a little shit in the past
Hey people, I guess this winter was the worst for my car, its probelm after problem. However, I am having an issue with my car on its start-up. Whenever its cold, the car makes a grinding noise (I will try and make a video of it) but its only on the initial cold start up. If I shut the car off and re-start it, it doesn't make that noise again. I have an auto start on my car so I really didn't notice it till about Novemeber, plus it doesn't always make that noise.
I checked my oil level and its fine, and I have narrowed it down to two possibilities: oil at some part (maybe cylinder wall) is completely drained, or my starter has a hard time disengaging from the flywheel.
Any input or if someone had this issue and knows a solution, I would greatly appreciate it.
BTW I had a compression test done around December and it passed.
Mods: K-Pro, IPS K2's with P1 retainers/springs, Hondata IMG, RBC IM, Hytech header, Toda exhaust, Injen CAI, Enjo MM, 6000K HIDs, BC N+, SPC camber, BFGoodrich KDW T/A 2, BC SS, S2K shift knob, Ferrari horns =D
Upcoming mods: Bigger injectors, clutch, and LSD (maybe) ...and DONE!
EuroRSX is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-07-2009, 03:18 PM   #2
GARCIA_DC5
Member
GARCIA_DC5's Avatar
GARCIA_DC5 is an unknown quantity on c-rsx
Yea mostlikely its the starter
GARCIA_DC5 is offline   Reply With Quote
Old 02-07-2009, 03:20 PM   #3
rensoyka
Breast inspector by appt.
rensoyka's Avatar
rensoyka is an unknown quantity on c-rsx
it could be related to the starter.
I have the same problem. If I crank the car without starting, then it starts up fine. If I start it without the warm up crank, the sound is not nice. I am convinced that this is related to the timing chain tensioner, low oil pressure in the tensioner from cold oil prevents the chain slack from being taken up at initial startup and the chain vibrates. I will replacing it next month when I put in a new clutch, it will be interesting to see the condition of the tensioner and if a new one solves the problem. I know a lot of people have had similar symptoms that went away when they replaced the starter. I also want to see what the flywheel teeth look like, but I still think it's the tensioner.
'06 black type-s.
rensoyka is offline   Reply With Quote
Old 02-07-2009, 03:25 PM   #4
Liquid_Turbo
Senior Member
Liquid_Turbo's Avatar
Liquid_Turbo is an unknown quantity on c-rsx
Yah from what I've read in past threads when this happened to me,
If:
Crank and start = grind
but
Crank, no start, then crank & start = no grind
It's tensioner.
If Crank and start = grind
Crank, no start, then crank & start = grind
It's the starter (or possibly both).
Liquid_Turbo is offline   Reply With Quote
Old 02-07-2009, 04:22 PM   #5
EuroRSX
Master Member
If it is the tensioner shouldn't it always make a grinding noise if I crank right away and its cold out? I mean I wouldn't understand the logics behind why it would and wouldn't grind everytime. I might try swapping the starter out when it gets slightly warmer, but then that's when my problems usually go away. BTW, say if it is the chain and I am presuming this issue is kinda serious, what would happen if I didn't change the chain out? I probably will do it over the summer when I get a new clutch.
Old 02-07-2009, 04:28 PM   #6
rensoyka
rensoyka's Avatar
my chain doesn't vibrate during the first part of cranking due to the low rpms. once the car fires up and the rpms climb to 2000+ for the cold idle is when it goes. it only lasts for fraction of a second until the tensioner gets a good grip on the slack. the only thing a vibrating chain can do is snap (unlikely) or skip teeth on the cam gears. from most of the threads I have read, most people who have their timing jump have it happen at start-up, not high revs.
'06 black type-s.
Old 02-07-2009, 04:33 PM   #7
EuroRSX
Master Member
Err I meant chain tensioner
Old 02-07-2009, 04:36 PM   #8
EuroRSX
Master Member
Oh then nvm, I guess its the starter in my situation cause it happens right after I crank when the rpms aren't even at or past 1000. Thanks for the quick responses people, I appreciate all the input.
Old 01-04-2010, 06:38 AM   #9
ivtecdaly
Honda-Tech Vet '05
ivtecdaly is a jewel in the rough of c-rsx ivtecdaly is a jewel in the rough of c-rsx ivtecdaly is a jewel in the rough of c-rsx ivtecdaly is a jewel in the rough of c-rsx ivtecdaly is a jewel in the rough of c-rsx ivtecdaly is a jewel in the rough of c-rsx ivtecdaly is a jewel in the rough of c-rsx ivtecdaly is a jewel in the rough of c-rsx
no, not to hijack
but my car is doing the same thing, second morning in a row its done it since i have had it. (car out of gear) and clutch needs to be changed
02 types 74k mi
ivtecdaly is offline   Reply With Quote
Old 01-04-2010, 12:31 PM   #10
1ILLac
Senior Member
1ILLac's Avatar
1ILLac is an unknown quantity on c-rsx
Same thing here, On a really cold start up it sounds like a grind/belt squeal really quick then goes away. Doesn't happen everytime its cold, but occasionally.
1ILLac is offline   Reply With Quote
Old 01-04-2010, 01:08 PM   #11
ahern090
Master Member
ahern090's Avatar
ahern090 is a jewel in the rough of c-rsx ahern090 is a jewel in the rough of c-rsx ahern090 is a jewel in the rough of c-rsx ahern090 is a jewel in the rough of c-rsx ahern090 is a jewel in the rough of c-rsx ahern090 is a jewel in the rough of c-rsx ahern090 is a jewel in the rough of c-rsx ahern090 is a jewel in the rough of c-rsx
i guess reviving an old thread is better than starting a new one.....
check the starter. i have the same problem and i know thats why..
just replace it when it takes a shit like i am or u can be "proactive" and change it now.
Short On Mod Cash Crew Member #37
ahern090 is offline   Reply With Quote
Old 01-04-2010, 01:09 PM   #12
grizzy225
Senior Member
grizzy225's Avatar
grizzy225 is an unknown quantity on c-rsx
I have that weird ass noise too. When my car sits for couple days and its cold makes a weird noise like a #2 pencil being draged quickly on a desktop. Lasts only about 1-2 seconds. No idea why. Maybe ill catch it on a record one of these days.
grizzy225 is offline   Reply With Quote
Old 01-04-2010, 01:12 PM   #13
Killyaself
( ͡ ͜ʖ ͡)
Killyaself's Avatar
Killyaself is a rep WHORE
Killyaself is a rep WHORE Killyaself is a rep WHORE Killyaself is a rep WHORE Killyaself is a rep WHORE Killyaself is a rep WHORE Killyaself is a rep WHORE Killyaself is a rep WHORE Killyaself is a rep WHORE Killyaself is a rep WHORE Killyaself is a rep WHORE Killyaself is a rep WHORE Killyaself is a rep WHORE Killyaself is a rep WHORE Killyaself is a rep WHORE Killyaself is a rep WHORE Killyaself is a rep WHORE Killyaself is a rep WHORE Killyaself is a rep WHORE
I noticed the exact same noise this past week. both times the car was sitting for a couple of days
Originally Posted by YaoMingFTW View Post
damn how big is her dick
Killyaself is offline   Reply With Quote
Old 01-04-2010, 01:15 PM   #14
mallen600
Pancakes
mallen600's Avatar
mallen600 is a jewel in the rough of c-rsx mallen600 is a jewel in the rough of c-rsx mallen600 is a jewel in the rough of c-rsx mallen600 is a jewel in the rough of c-rsx mallen600 is a jewel in the rough of c-rsx mallen600 is a jewel in the rough of c-rsx mallen600 is a jewel in the rough of c-rsx mallen600 is a jewel in the rough of c-rsx mallen600 is a jewel in the rough of c-rsx
Somebody has a thread on here how to fix this. The actuator that turns the flywheel doesn't pull back fast enough when it is really cold and it grinds for a second after the car starts. Mine has been doing it for 2 winters now, but only when its below 20 outside. Now I have remote start so at least I don't have to hear it anymore.
TN CREW #6[/b]ABP Crew Member #79[/b]
Zombie Eradication Team #68
BB Crew
***PIC OF BUFFALO HERE***
mallen600 is offline   Reply With Quote
Old 01-04-2010, 03:14 PM   #15
aZnCdn
Tail of the Dragon Addict
aZnCdn's Avatar
aZnCdn is an unknown quantity on c-rsx
Ya my car does this as well when is below 50F and my car is parked outside all night.
aZnCdn is offline   Reply With Quote
Old 01-04-2010, 03:25 PM   #16
Sinister-S
SuwoopinK20Z
Sinister-S's Avatar
Sinister-S is on a distinguished road Sinister-S is on a distinguished road
My car has been doin the same thing. Its awful and only does it when its been sitting in cold weather
2006 Type S|Buddy Club|DC|Fujitsubo|ESMM|Ingalls|Hondata|A Spec|Mugen|Injen|Spoon|JDM|FALKEN|
Boost is coming....
Sinister-S is offline   Reply With Quote
Old 01-07-2010, 01:49 AM   #17
760dc5
I<3Dc5
760dc5's Avatar
760dc5 is a jewel in the rough of c-rsx 760dc5 is a jewel in the rough of c-rsx 760dc5 is a jewel in the rough of c-rsx 760dc5 is a jewel in the rough of c-rsx 760dc5 is a jewel in the rough of c-rsx 760dc5 is a jewel in the rough of c-rsx 760dc5 is a jewel in the rough of c-rsx 760dc5 is a jewel in the rough of c-rsx
mine does this tooo lol
here goes another 2nd and 3rd gear grind petition
Lifes simple, you makes choices and you dont look back".
760dc5 is offline   Reply With Quote
Old 01-07-2010, 02:22 PM   #18
NeonSlvRSX
So Amazin'
NeonSlvRSX's Avatar
NeonSlvRSX might be well recognized one day on c-rsx NeonSlvRSX might be well recognized one day on c-rsx NeonSlvRSX might be well recognized one day on c-rsx NeonSlvRSX might be well recognized one day on c-rsx NeonSlvRSX might be well recognized one day on c-rsx NeonSlvRSX might be well recognized one day on c-rsx NeonSlvRSX might be well recognized one day on c-rsx
mine does it too, sounds like its my serpentine belt. I guess its not. Anyone know how much this would be to fix? And is this detrimental to our cars, because honestly it doesn't bother me too much. It only last a second.
2007 Acura TL Type-S
Moroccan Red Pearl
NeonSlvRSX is offline   Reply With Quote
Old 01-08-2010, 08:09 PM   #19
Nguyen35
Smash
Nguyen35's Avatar
Nguyen35 is an unknown quantity on c-rsx
112 for replacement starter at auto zone with trade in of core.
Labor can range i'd say around 200 to 300
You can fix it yourself by following helms manual.
818
Originally Posted by jared View Post
and if i would of saw it, i would of been overly impressed
threadstarter = fag = ban
Originally Posted by P3t3R_Racer View Post
Wow, this statement coming from a 5-speed Base owner. Please get a life.
Nguyen35 is offline   Reply With Quote
Old 01-09-2010, 06:20 PM   #20
elunicoguapo
03' ABP type-s
elunicoguapo is an unknown quantity on c-rsx
My car has been doing the same noise and only when it's cold, not that it gets cold often here in FL. So I talked to a mechanic buddy of mine and let him hear it himself this morning, turns out it is the [B]Starter[B] for sure!
elunicoguapo is offline   Reply With Quote
Old 01-09-2010, 09:45 PM   #21
neuspeeddc5
100K Club as of 10/10/09
neuspeeddc5's Avatar
neuspeeddc5 is an unknown quantity on c-rsx
mine is doing it now at 103K
Greddy l Neuspeed l Koni l Depo l Mugen l DC Sports l Hondata l Progress l Apexi l Megan l CHARGESPEED
100K Club
member since 2004
neuspeeddc5 is offline   Reply With Quote
Old 01-09-2010, 10:03 PM   #22
TypeS7
mex edition steve
TypeS7's Avatar
TypeS7 is on a distinguished road
check this out and try to see if it helps out with the problem.
http://www.honda-tech.com/showpost.p...4&postcount=13
Short On Mod Cash Crew Member #12
2003 NHBP rsx-s: Turbo in the works, bunch of JDM rice parts.
2000 Civic LX sedan: daily beater
1989 MK3 Toyota supra turbo: money pit #2
Instagram:types7
TypeS7 is offline   Reply With Quote
Old 10-09-2012, 09:56 AM   #23
JCracing
New Member
JCracing is a jewel in the rough of c-rsx JCracing is a jewel in the rough of c-rsx JCracing is a jewel in the rough of c-rsx JCracing is a jewel in the rough of c-rsx JCracing is a jewel in the rough of c-rsx JCracing is a jewel in the rough of c-rsx JCracing is a jewel in the rough of c-rsx JCracing is a jewel in the rough of c-rsx
i have a honda civic and it sound like all you guys mention and first start in the morning hear a grinding noise .....sometimes it cranks up some time misses... so cranking up the second time work without noise and the whole day without problem..... it happends 2 times in 7 times ..... so should i worry abour it cause its so annoying and it worrys me at some point..... and does anyone know the problem???? please let me know thanks
JCracing is offline   Reply With Quote
Old 04-27-2013, 10:52 PM   #24
mat.tremblay99
New Member
mat.tremblay99 is a jewel in the rough of c-rsx mat.tremblay99 is a jewel in the rough of c-rsx mat.tremblay99 is a jewel in the rough of c-rsx mat.tremblay99 is a jewel in the rough of c-rsx mat.tremblay99 is a jewel in the rough of c-rsx mat.tremblay99 is a jewel in the rough of c-rsx mat.tremblay99 is a jewel in the rough of c-rsx mat.tremblay99 is a jewel in the rough of c-rsx
my car started doing this this week and this thread helped alot, thanks guys.
There is some really good information here.
mat.tremblay99 is offline   Reply With Quote
Old 04-28-2013, 10:06 AM   #25
larryboy
Long Live RSX
larryboy's Avatar
larryboy is an unknown quantity on c-rsx
I had this a few months ago and I told the dealer it was the starter. He did not listen and changed the actuator instead. I brought it back, he replaced the starter and it was fixed.
Nihonsei. 02/RSX/5Spd/K20A3, NBP, K&N SRI, Eibach ProKit Springs, SPC F/R Camber, Power Stop Drill/Slot rotors, Alpine MRV450 5Ch amp, Kenwood Sat Radio, Kenwood KDC-X959, iPod aux cable, Kenwood 10CD changer, Infinity 6000cs, JBL GTO 6.5 3-way, Alpine Type S 12" Sub/QLH Box, 17x7.5 Enkei ZR-1, Michelin Pilot Sport A/S3, 225/45/ZR17, Acura Switchblade Key, FormulaONE Tint, Boomerang Armrest, Viper Alarm, Wheel Locks, VIN Etch, Gutterguard Grill, Splash Guard, Fenderwell Trim, Pin Stripe, MT-51R battery, 104K mi.
larryboy is offline   Reply With Quote
Reply
Bookmarks
car , grinding , makes , noise , start
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
